Need some advice....Sp3cops70 03-15-2006, 11:13 AM Where do I get some fog lights for my GPGT 97??? cheap? WHat temperature thermostat?? What about light bulbs for my third rear light?? Thanks in advance... BNaylor 03-15-2006, 11:36 AM Where do I get some fog lights for my GPGT 97??? cheap? WHat temperature thermostat?? What about light bulbs for my third rear light?? Thanks in advance... Walmart (cheapest) or Autozone, etc. Stock 27 watt fog light lamp is #880 or are you referring to aftermarket fog lights? 3rd Brake Light lamp is 1156LL or 1157LL. The stock thermostat is 195 degrees. Sp3cops70 03-15-2006, 11:53 AM Well as far as the fog lights....I would like to get the wal mart ones for those are the cheapest ones....correct. BUT I also do not want them to look to different...meaning smaller or bigger then the original ones. WHat do you think?? Sp3cops70 03-15-2006, 03:49 PM Bumpage.... richtazz 03-16-2006, 07:07 AM If you're looking for replacement assemblies, it's a subjective issue. Try to find ones with lenses that are close in size to the originals so they fill the hole in the facia properly. Stick with the stock temp (unless your car is modded and/or you run a re-programmed PCM) and a name brand T-stat like AC-Delco or Gates, cheapo off-brand stats are trouble just waiting to happen. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
