Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 03-14-2006, 10:00 PM   #1
gpgt98
gpgt98 Normal reputation
Blower motor Resistor or Ignition Starter Switch?
I am having problems that sound very similar to the resistor problems but my
DTRLs go out when switch 1-2-3-4 are used as well as some lights by the ac. What I am wondering is, change both the resistor AND the ignition switch or just the Ignition Starter Switch. Thanks for any further info.
gpgt98 is offline   Reply With Quote
Old 03-15-2006, 06:23 AM   #2
maxwedge
A990 racer
maxwedge Normal reputation
Re: Blower motor Resistor or Ignition Starter Switch?
Check the dash grounds, check for current into the resistor from the switch in the inop postions, the ign switch would affect other accessories besides the blower.
maxwedge is offline   Reply With Quote
Old 03-15-2006, 07:05 AM   #3
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Make sure all the battery cable connections are clean and tight too.
Would you drive any better with that cell phone up your ...?!
richtazz is online now   Reply With Quote
Old 03-15-2006, 07:55 AM   #4
BNaylor
BNaylor's Avatar
BNaylor +50
Sounds like the contacts are carboned up in the ignition switch and harness assembly. Common problem. You have two symptoms consistent with this. The Daytime Running Lights (DRL) acting up and the HVAC blower problem.
You can try a blower motor resistor since it doesn't cost that much and is easier to change than the ignition switch assembly. If that doesn't work then the ignition switch. It is 50/50. Take your choice.
'08 Pontiac Grand Prix GXP (Liquid Silver Metallic) - LS4 5.3L V8
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 03-15-2006, 08:58 AM   #5
ICCS
ICCS Normal reputation
I had the same problem, lights go out when blower setting was on 1-4. I changed the ignition switch control module and all returned to normal. However now about two months later I'm having problems again.
This time, I have no air blowing on any setting 1-5. I do hear a click sound coming from under the glove compartment area when I switch from setting 4 to 5.
Any thoughts?
ICCS is offline   Reply With Quote
Old 03-15-2006, 09:32 AM   #6
BNaylor
BNaylor's Avatar
BNaylor +50
Any thoughts?
Sounds lke the blower motor or the electrical connector to it. The relay you hear clicking is the blower hi-speed relay for position 5 which is also located on the blower motor resistor assembly. You can remove the blower and bench test it by applying 12v to the input pins.
Timeslip 08/12/06
Bookmarks
Google
Web AF
