Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 03-14-2006, 07:51 AM   #1
Puruco
Puruco Normal reputation
97 Blazer wiper circuit board
Does anyone know of a source for the wiper circuit board for a 97 Blazer? Also, could someone either post a picture of where on the car it is located or at least describe where it is? Thanks. Mine are now doing a new thing where they just go on whenever they feel like it. Reminds me of "Christine."
Puruco is offline   Reply With Quote
Old 03-14-2006, 10:01 AM   #2
mike2004tct
mike2004tct's Avatar
mike2004tct Normal reputation
Re: 97 Blazer wiper circuit board
The pulse board sits on top of the wiper motor, which is under the hood on the firewall.
They cost $25-40.00 depending on where you buy them., available at most major chain parts stores. I bought mine at Napa for $30.00 2 years ago.
It's an easy replacement job. Remove the plastic cover on top of the wiper motor, remove the connector(s), then remove the circuit board (pulse board).
re-install the new pulse board, reconnect, add some RTV to the cover and attach it. 30 minutes max.
This was a special policy recall from GM for '97 Blazers. Unfortunately, it expired in Feb. of 2004, and I didn't find my notice until March of '04 and GM wouldn't honor it.
It's my opinion, don't take it personal.
'04 T&C, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
mike2004tct is offline   Reply With Quote
Old 03-14-2006, 10:09 AM   #3
Puruco
Thanks a lot, Mike.
Old 03-14-2006, 10:37 AM   #4
sournw01blazer
sournw01blazer Normal reputation
Smile Re: 97 Blazer wiper circuit board
at NAPA it's $28.04
sournw01blazer is offline   Reply With Quote
Old 03-14-2006, 12:58 PM   #5
muddog321
AF -Advisor
muddog321 Normal reputation
Need the right size torx bit for this and do not over tighten when installing cause the board will flex - use that RTV around the edges to seal.
muddog321 is offline   Reply With Quote
Old 03-14-2006, 03:41 PM   #6
mike2004tct
T20 Torx bit.
I should restate how the pulse board cover is situated. While it is mounted on the top of the wiper motor, it will actually appear to be facing you as you look at the firewall (appears to be mounted to the side of the wiper motor)
Old 03-14-2006, 05:54 PM   #7
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 +50
Have your dealer Run your vin no. it may be under recall.
If not a drop of solder will fix 99 % of them.
Look for a crack on the circuit board usually where 12 volt power feeds into it on back side of power plug prongs.
MT
MT
MT-2500 is offline   Reply With Quote
Old 03-14-2006, 08:30 PM   #8
mike2004tct
MT
The pulse board issue was a "special policy" service bulletin for '97s, not a recall, that ran from Feb. '03 and expired Feb.'04. It only covered vehicles that were less than 7 years old or less than 70,000 miles. The bulletin was mailed to the original owner, or to the registered second owner if the original warranty was transfered.
Old 03-14-2006, 10:36 PM   #9
JC327
JC327's Avatar
JC327 Normal reputation
Whatever you do, do not buy it from a dealer. The main Chevy dealer here wanted $120.00 for that baby.
JC327 is offline   Reply With Quote
Old 03-15-2006, 02:11 AM   #10
Rmbodie
Rmbodie's Avatar
Rmbodie Normal reputation
I did not try NAPA , don't have one close to home . Dealer item according to Advance and Autozone . Repaired mine myself since dealer price was outragous . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
Rmbodie is offline   Reply With Quote
Bookmarks
Google
Web AF
