Huge integra oil problem?turbo?
redintegra98
03-14-2006, 02:53 AM
I have a 98 integra ls that has a lot done to it. Right now it is stuck at 300 whp until i can get this oil problem fixed. Nobody I know has been able to figure this out, including 2 dyno shops. The problem is so much oil pressure is building up that when I get into boost oil fills my catch tank in less than a couple of days of driving it and overflows out of the filter. I cannot even run the catch tank to the im because the amount of oil been vented is so bad that it could smoke out a whole highway when boosting. I have had a compression check on the car and it came out perfect. I am not sure if I am having crank case problems or temperature problems. If so, how can I fix it. If you need anymore information I can give it to you. I have to say that if you figure this problem out you are a car God!!!!
heres some of the upgrades if they may help in figuring this out.
(Je pistons, eagle h beam rods, crower turbo cams, ferreo or something like that valves, crower springs, crower retainers, air resarch t3/t4 (13 lbs of boost), skunk 2 im, rc 650cc injectors, jg 62.5 throttle body.
blitzcivic
03-16-2006, 03:47 AM
well i dont know if this could help you but i was working on a accord ex w/vtec and the car was loosing a quart of oil every 5days but it was only when you drove the car hard mainly when the vtec engaged. i spoke with the honda dealer and they said a common problem was the vtec solinoid has a screen that can become clogged and will build pressure and blow oil out the side if the head. i ended up doing a head job replacing the the head gasket and the vtec screen. it fixed the problem. you may want to start just by checking the sreen in the vtec solinoid. hope this may help you. good luck.
kris
03-16-2006, 09:35 AM
You have way too much crank case pressure. How are your catch can lines ran?
blitzcivic
03-16-2006, 01:12 PM
well as far as my car im not having any crankcase pressure problem. i did a little reading in my engine books, and found that crankcase pressure can sky rocket if there is not a proper ring seal. i understand you did a compression test and it turned out good numbers. but you can still have a bad ring when the motor is under high pressure and the rings have expanded from the heat. you can try a leak down test but it will be difficult to duplicate your driving condition enough to have the rings at the same point during driving conditions. just one thing when you hit boost and you get a cloud of smoke out your exhuast it showing that you oil ring is failing. one of you rings may be cracked or damaged.they may have to be changed and check you cyl. walls for groves.
redintegra98
03-16-2006, 01:56 PM
Thanks for the responses guys. I did forget to mention that with the compression check I did get a leak down test and it turned out ok (assuming shop actually did it) but you are right about it been possibly different when driving. This is strictly ls motor(I know vtec head would have been better but just wanted to see what it could do) so won't be having problem with vtec solenoid. I have also changed the head gasket 3 times. I completely agree that I have way too much crank pressure at this moment in time. As for the rings it is definitly possible. When I get into boost without the catch tank hooked up to the intake manifold I don't burn oil(Well a tiny tiny bit) but nothing compared to when the breather is directly hooked up to the im (when I smoke a car, i literally smoke it). So for right now it seems that my rings are ok because if oil was getting into my compustion chamber I would be smoking anyway. This tells me that I need to do something to get rid of the crank pressure because my pcv system(not sure if technically correct) is not venting the crank pressure enough. If this is the case what can I do about it. Are there any bolt ons for hondas or acuras to do this.
thanks for the responses, I really appreciate them.
As for right now the catch tank is run to the breather on the valve cover and then just has a filter on the other side. (not run to im because car will smoke).
kris
03-16-2006, 08:43 PM
You hvae WAY too much crankcase pressure. Your catch can setup is very inadequate. Fix it the right way, and chances are you will solve your problems.
kris
03-16-2006, 08:47 PM
The purpose of the stock PCV system falls under 3 categories:
1) Performance
2) Emissions standards
3) Reliability
Performance
It is well known that performance gains can be had if the crankcase is under a slight source of vacuum which helps reduce crankcase windage losses. Many domestic users have seen decent gains by using either an electric or mechanical pump to help evacuate the pressure generated in the crankcase and even generate a vacuum present. Regaining lost power through the introduction of vacuum pressure evacuating the crankcase will not be as noticeable on a small displacement 4 cylinder as compared to a larger displacement 8cyl domestic. Despite this, it should still be of importance to explore the various configurations and attempt to "free-up" any power hidden in our engines which can easily be tested on a dyno.
Emissions Standards and Reliability
In order to comply with US emission standards honda had to use a closed PCV system which eliminated oil vapor from escaping into the atmosphere either from the valve cover or the crankcase breather. Oil vapors being introduced into our cylinders hurts performance and increases the probability of detonation occurring. The stock PCV system allows for the introduction of oil vapors into our intake manifold which hurts performance and reliability(a stock intake manifold is usually caked with collected oil and soot over the years).
A stock PCV system is far from an optimal configuration in terms of performance and reliability. The best arrangement is to create a vacuum inside the crankcase of 14-15 inches/Hg (7psi). You do not want to create higher vacuum than 15 in/Hg because you will begin to suck oil from valve guides, piston rings, and bearings which will have dramatic consequences. Inducing a vacuum in your crankcase will lower oil pressure slightly which may be alarming but shouldn't be because the oil volume is still present. 2-5 % increase in whp is not uncommon with a properly setup vacuum drawn crankcase pulling 15in/Hg.
This Vacuum will quickly remove unburnt Air/Fuel from blow-by gasses. Blow-by contaminates engine oil, contributes to sludge buildup, and causes corrosion. Turbocharged and Supercharged cars have significant amounts of blow-by because of the pressure created inside the cylinders. Your first priority should be to attempt to create a vacuum in the crankcase to remove the blow-by or at minimum make it as easy as possible for this pressure to escape.
Evacuating the crankcase pressure can be done directly from the block or valve cover. It doesn't matter which method you prefer.
Test Engine:
B18c1
/// Freshly built Engine- leak-down #s 2-3% across the board
-- 9-1 CP pistons/Eagle Rods/Victor X Intake manifold/Lovefab sidewinder/
Arp Head-studs
-- 3" Down-pipe/3" Moroso Spiralflow resonator/3" mandrel exhaust/open
dump-tube/ Tial 40mm waste-gate
-- Freshly Built Head/ Supertech valves/ Titanium retainers/Dual Valve springs
-- Fresh Garrett 4 bolt t3/t4 turbo// 0.60 AR Compressor/ 0.63 Turbine
housing
-- Custom 2.5" intercooler pipe/ Custom Spearco 3.5"X12"X20" intercooler
-- Tuned with Hondata
Test Equipment:
Calibrated Dewyer Magnehelic Pressure Gauge
0-5 psi range // Accuracy +-2% ///
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTU1NnM0MTNkZmQzMXk1NDE%3D.jpg
Open Breather Ventilation
This method is adequate for ventilating crankcase gasses in turbocharged/supercharged cars because the extra blow-by will force its way through any filter quite easily. You want to make sure you provide as many sources as possible to allow the pressure to escape with ease.
For H, F, and D series engines you can use the stock PCV line(excluding the PCV valve), Breather Line, and tap an extra 1-2 ports in the valve cover if wanted. You can attach a filter directly to the line or connect them to 1or2 catchcans with a breather filter on top.
You want to place the catchcan in the highest possible location you can locate in your engine bay. This will allow the catchcan to collect blow-by gasses without consuming excessive oil and allow a drainback line to easily flow oil/gas mixture back into the engine(if you choose to use this feature).
The sole purpose of a catchcan in an open breather system is to "trap" oil and blow-by gasses so they do not contaminate your engine bay and the environment. The surface area in the lines and the catchcan facilitate this. Increasing the surface area by using steel wool or other means will certainly help capturing these gasses but will also restrict them from escaping. The best compromise is to use a baffled catchcan such as one Moroso manufactures.
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTQ4NnM0MTNkZmQzMXk1NDE%3D.jpg
On B series engines it is preferable to ventilate the crankcase gases through 2 ports located on the back of the block. This arrangement can be accomplished by removing the PCV chamber behind the Intake manifold bracket and sealing the stock Crankcase ventilation hole. If you are running the stock Intake manifold you will want to also plug the PCV port on the Intake Manifold as well.
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTU2NnM0MTNkZmQzMXk1NDE%3D.jpg
The Crankcase ventilation hole can be sealed with one of these 3 methods:
1) Aluminum Freeze Plug (34.4mm-34.6mm)
2) Aluminum circular plate epoxied with Devcon Liquid Aluminum
http://www.devcon.com/devconfa...id=34 (http://www.devcon.com/devconfamilyproduct.cfm?familyid=108.0&catid=34)
3) http://www.z10eng.com/ makes a plug.
It is important that you seal this opening with an Aluminum plug and not a rubber one!
Remove the ports with a 14mm Allen(Snap-on) and install these 2 washers and ports as shown below(Honda part numbers shown):
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMzU0MTg0NnM0MTNkZmQzMXk1NDE%3D.jpg
Use reinforced high temp hose 5/8" ID. Their will be a port on the top of your block which normally connects a line to your PVC chamber. You can either seal this or T it off one of your ventilation lines. The last thing to do is place a small filter on your breather port located on your valve cover.
I ran this above setup for approximately 1 year with no problems. My car was daily driven hard boosting 17-18 psi. I tested this setup using the following configurations:
1) Drain-back feature to the one of the original lines
2) Back to the oil pan
3) Without the drainback feature.
When I removed the drainback feature I would fill the catchcan half full every 2-3 weeks. The evacuation lines would dis-color but never suck oil even when I used the stock Honda fittings without an anti-siphon tube. The contents of fluid collected inside the catchcan was mostly unburnt fuel and contaminants with very little oil. If you are experiencing excessive oil consumption in the catchcan I suggest you place your catchcan higher or do a leak-down test.
I suggest manually draining the catchcan instead of using the drainback feature to eliminate gasoline and contaminants from re-introducing themselves to your oil.
Bottom Line
Cost: 20-150 dollars(dependent upon open filter lines or use of catchcan)
Performance: Good(as long as their is enough ventilation)
Reliability: Good.
Environment: Horrible(no catchcan)- poor(Catchcan)
Intake Manifold Vacuum Assisted Ventilation
In Turbocharged vehicles the Intake manifold sees both vacuum and boost pressure unlike in naturally aspirated cars. The PCV valve acts as a check valve blocking any pressure in the rare occasion their is backfire in the Intake Manifold. I have heard that some individuals placing a check valve in-line and allowing the Intake manifold to assist in ventilating the crankcase. The check valve insures that boost pressure doesn't enter into the crankcase through this line.
Ideally one would want to induce a gradual amount of vacuum up to 15 in/hg under full load. Connecting the evacuation line to the intake manifold would do the exact opposite of this. On a boosted vehicle the Intake Manifold will read 25in/hg at idle and 20-15in/Hg in low load conditions and quickly disappear when any moderate to high load conditions appear.
In a stock vehicle this is acceptable because the PCV valve meters the vacuum as shown:
Idle, Low load--- high vacuum pressures fully retract the pintle causing only a small vacuum draw on the crankcase.
Mild load conditions--- vacuum present in the intake manifold is not as strong so the pintle sits in the middle of the pcv valve allowing more vacuum to evacuate the crankcase.
High load + WOT conditions--- their is almost no vacuum present and the pintle is almost completely extended allowing the most amount of gasses to be drawn into the intake manifold.
Engine backfire--- the pintle fully extends and seals to eliminate any gasses from flowing from the intake manifold to the crankcase.
Not only are you pulling excessive vacuum at low load conditions you are contaminating the Intake charge with oil and unburnt fuel blow-by.
I cannot recommend this setup to anyone.
Intake slashcut evacuation
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTU0NnM0MTNkZmQzMXk1NDE%3D.jpg
Using a slashcut tube to create vacuum is an old trick which works on the Bernoulli effect as air rushes past the tube at high velocities. Make sure you place the slash-cut opening in the opposite direction of the airflow.
One method for evacuating the crankcase is to allow the Intake(pre-turbo) to draw out these gasses. In my tests their was a linear load dependent vacuum drawn using this method. None to insignificant amount of vacuum drawn at idle and low load conditions, moderate load created 0.25 psi(0.5") of vacuum, and high load/WOT created a maximum vacuum of 0.5 psi (1") vacuum. One does not need to use a check valve with this approach as their is never any reason for pressure to force its way into the crankcase.
Their is a positive and negative aspect to this approach. The great thing about this method is that it is the only method which allows one to completely eliminate any blow-by gasses from contaminating the environment. The downside is that it contaminates the Intake charge with oil/fuel/contaminants.
Judging from the amount of contaminants I collected in my open breather catchcan every 2-3 weeks it would be absolutely insane to use this method without a sealed(no open breather element) and baffled catchcan in-line between the crankcase /valve cover and the intake. Keep in mind that most of the contaminants will be sucked into the intake as opposed to only some contaminants trapped in an open breather catchcan while the rest pollutes the environment.
Some good news is that the Intercooler piping and intercooler will act as a very large catchcan and trap most of these contaminants before they reach the engine. The bad news is that I suggest you periodically clean the inside of your intercooler and intercooler pipe.
Bottom Line
Cost: 20-150 dollars(dependent use of catchcan and welding)
Performance: Good(as long as the compressor housing/Intercooler are cleaned
periodically and a catchcan is used)
Reliability: Good.
Environment: Excellent(provided that you use no other open breather elements)
Mechanical Vacuum
The only people right now that make this for Hondas is:
http://www.z10eng.com/.
The great news is that this is the best setup from a performance/reliability perspective bar-none. The bad news is that it is extremely expensive and you have to run their complete oil pump setup thus loosing your AC compressor. My conversation with one of the owners a while ago led me to believe these guys are extremely knowledgeable and will customize your complete setup specifically to your needs. You can choose between a dry sump, wet sump oil system, or even add on a mechanical fuel pump. The vacuum generator can be manually adjusted for desired amount.
Expect to free up more whp then the standard 2-5% because this setup goes way beyond simply inducing vacuum in the crankcase.
Bottom Line
Cost: Variable. Expect around 2 grand.
Performance: Excellent.
Reliability: Excellent.
Environment: Poor.
Electric Vacuum pump
I have studied and tested the idea of using old electric brake booster vacuum pumps which were made for old GM vehicles to induce vacuum in the crankcase. Using an off the shelf electric vacuum pump to draw a specific amount of vacuum is tangled with complex problems.
These pumps run 16in/hg of vacuum at 13.7 volts and 19in/hg at 16 volts. Remember you don't want to draw more than 14-15" of vacuum and it is preferable that the vacuum is gradually increased in a linear fashion with load which these will not do without some tricky electronics.
I have studied both mechanical and electronic approaches to solving these dilemmas to no satisfaction. After all the problems I had wrestling electrical gremlins in an electric water pump I simply don't trust my engine on this device. Another cause of concern I have is when my alternator failed while I was driving I recorded very unusual voltage numbers jumping from 10-16.8 volts in odd patterns which could case problems for an electric vacuum pump.
Exhaust slashcut evacuation
This is based upon the same Bernoulli effect mentioned before but uses exhaust gasses to draw out crankcase gasses instead.
Their are 2 ways of doing this:
1) Weld a slashcut tube in your waste-gate dump-tube
2) Weld a slashcut tube in your exhaust
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTU4NnM0MTNkZmQzMXk1NDE%3D.jpg
In the first test I connected my Dewyer Magnehelic Pressure Gauge to the slashcut in my wastgate to measure the vacuum draw. As expected I only saw maximum vacuum drawn when the wastgate was open after reaching my maximum boost pressure set on my boost controller. The amount of vacuum went up from 0.25psi(0.5") to 0.4(0.8") vacuum. The numbers shown here were very similar to those shown with the Intake slashcut with the exception of being present when the wastgate started to open.
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTU3NnM0MTNkZmQzMXk1NDE%3D.jpg
I chose to connect my valve cover breather and top port (oem- not modified plugs) on my block to the waste-gate slashcut tube. Check valves aren't really needed here but you can use one if it make you feel better.
For my second test I welding in a slashcut tube in my downpipe(12" from turbo). At first I had problems melting my high temp tubing with the heat from the downpipe and exhaust so I soldered together some copper pipe to solve this problem. I placed a check valve in-line on the top 6 inches of hose and wrapped it in reflective heat wrap as you can see.
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTUxNnM0MTNkZmQzMXk1NDE%3D.jpg
At Idle the Dewyer Magnehelic Pressure Gauge showed 0.1-0.2psi of vacuum. Driving around town was more unpredictable. The gauge would oscillate between positive pressure(when i tested without the check valve) to 0.5 psi (1") to 1.1 psi ((2.2"). It rarely displayed positive pressure but I could find no simple pattern either rpm or load dependent. Typically it would bounce around 0.6psi to 1psi.
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTUwNnM0MTNkZmQzMXk1NDE%3D.jpg
Here is a picture of the hose connected to the valve cover port without being tested. You definitely want to run a one way check valve in-line here.
I purchased the check valve for 1 dollar at a local junkyard. You can find the check valve in-line on the brake booster line on any honda.
Another source for a check valves and slashcut tubes(In case you don't feel like cutting your own is Moroso:
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNjczMTc2NnM0MTNkZmQzMXk1NDE%3D.jpg
Bottom Line
Cost: 20-80 dollars (dependent upon if you have it welded or not)
Performance: Great.
Reliability: Great.
Environment: Poor.
List of engine locations of Evacuation lines
I already have given a detain description of the PCV system found in B series engines. Below are examples for other engines:
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTUzNnM0MTNkZmQzMXk1NDE%3D.jpg
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTUyNnM0MTNkZmQzMXk1NDE%3D.jpg
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODU2NTQ5NnM0MTNkZmQzMXk1NDE%3D.jpg
redintegra98
03-16-2006, 09:28 PM
That was exactly what I was looking for. I have to admit I was clueless when it came to the honda pcv system. I will check out those guys at z10 to see how they can help me. I have been looking a while for a company that made these products for hondas. Moroso looked like they were getting into this kind of stuff, but couldn't even get an oil pan or valve cover to work right (don't ask). It is apparent that I need to do something before I ruin a lot more stuff. As I do some researching and budgeting for these different methods I will keep you posted.
Thanks alot for the information and the pictures!!!! I now have somewhere to start. (U DA MAN)
If anybody else has anything else to add please do.
