Tire Size
Double_Down
03-13-2006, 07:34 PM
hey guys, sorry if this has been asked a thousand time before. i just bought an 05 TB 4x4 with the L6. i am just wondering, if i now have p235/75/r16's, can i use 245's on the same wheel? also what affect would i get if i moved from 75 to 70? Thanks for the help.
john
rodeo02
03-14-2006, 01:23 PM
I've heard of up to 265/70R17 fitting, but you *might* need wheel spacers to prevent rubbing on tight turns. Kinda depends on the specific brand, trial and error.
Joel
ScarabEpic22
03-19-2006, 01:16 AM
Moving from a P235-75/R16 (weird size, did you buy it from someone who replaced the tires with a different size because no TB came from the factory with P235 tires, only P245-70/R16 and then some P245-65/R17 tires) to a P245-70/R16 will fit, as I have this size on my 02 TB and replaced the tires with Toyo Open Country A/Ts 7K ago at 53K. No rubbing, but talk to the dealer about if your speedo will change.
Double_Down
03-22-2006, 05:59 PM
Thanks guys,
the 235's are the ones on it from the dealer and the door panel says they are the stock size. i decided to go with some 235/75R15 firestone destination a/t's. i was going to go with the deuler a/t revo's but i can't afford them. Thanks for the input
domvoyer
04-03-2006, 10:56 AM
http://www.dakota-truck.net/TIRECALC/tirecalc.html
This is a good comparison tool to change the size of the tires, and see if the speedo will change, etc..
go take a look.
