Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 03-13-2006, 04:12 PM   #1
Froggysquasher
Froggysquasher Normal reputation
Send a message via AIM to Froggysquasher
Difference in USDM type r and JDM type r
what are the differences in these 2 cars? thanks!
Froggysquasher is offline   Reply With Quote
Old 03-13-2006, 04:41 PM   #2
WReX
WReX Normal reputation
Re: Difference in USDM type r and JDM type r
JDM has different front end, LSD trans, right hand drive and a ton of other things....just forget them at the moment
26 PSI anyone?
WReX is offline   Reply With Quote
Old 03-13-2006, 04:44 PM   #3
BLU CIVIC
調整器
BLU CIVIC's Avatar
BLU CIVIC +50BLU CIVIC +50
Send a message via AIM to BLU CIVIC Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
more hp due to less strict emissions
The name's Adrian
BLU CIVIC is offline   Reply With Quote
Old 03-13-2006, 04:44 PM   #4
BLU CIVIC
調整器
BLU CIVIC's Avatar
The name's Adrian
Old 03-13-2006, 04:50 PM   #5
kicker1_solo
kicker1_solo's Avatar
kicker1_solo 0
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
I don't know all of the differences but after searching for 2 minutes I found this info
udsm ITR front end= round head lights 98+ front end with type r lip
edm, jdm itr font end: bar style head lights
on the jdm motor you will find
- LSD
- 2.5" collector of header
- JDM and USDM have different sized letters on DOHC and VTEC
- PR3 on head
- P73 on distributor
- bronze shift linkage
- dual valve spring
- JDM - B18C vs B18C5 - USDM
-most JDM type R motors will have a green stripe of paint on the back side of the distributor
96 & 97 JDM ITR heads have the same cams as 97/98/99 USDM cams. 00 USDM cams are the same as 98Spec JDM ITR cams and JDM CTR cams, they basically have 3 degrees more duration on the intake cam, the exhaust cams for all ITR/CTR are the same regardless of year/country. 96 spec ITR heads had a hand port and polish, 98spec ITR were machine polished
JDM GSR has a 10.6:1 compression ratio, and 180hp 126lb-ft.(??)
JDM GSR has the p72 head and cams and IM&TB, different pistons, rods, and crank.
USDM ITR motor has 10.6:1 compression 190hp (??)tq.
ported and polished PR3 head, different TB and larger bore TB
coated pistons, different rods, and crank.
2002 Lexus RX300
1995 VW Jetta VR
1985 Toyota 4x4
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
kicker1_solo is offline   Reply With Quote
Bookmarks
Google
Web AF
