Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 03-12-2006, 03:51 AM   #1
Twinturbo4x4Lux
Twinturbo4x4Lux Normal reputation
more power from a 1g-gteu
i recently had to replace the 1g-gteu in my 81 hilux caus the turbo's decieded to give up the gost, and i found that the new engine isnt as powerful as i would like as it has the stock c12 turbos on it and my old engine had turboloader k-24's, does anyone know of a good cheap way to get more power out of the stock turbos without to much trouble
Twinturbo4x4Lux is offline   Reply With Quote
Old 03-12-2006, 03:59 AM   #2
Twinturbo4x4Lux
Re: more power from a 1g-gteu
if anyone has any ideas it would great
Old 03-12-2006, 08:29 PM   #3
Yellow 13
Yellow 13's Avatar
Yellow 13 Normal reputation
Send a message via AIM to Yellow 13
It usually takes awhile to get a response here, But Id say shim the waste gates or get a boost controller. Im not to familar with that engine though.
Yellow 13 is offline   Reply With Quote
Old 03-12-2006, 08:42 PM   #4
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
TcmaBoy Normal reputation
Have you thought of swapping from CT12s to CT12As?
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
TcmaBoy is offline   Reply With Quote
Old 03-12-2006, 11:34 PM   #5
projectsupramk3
projectsupramk3's Avatar
projectsupramk3 Normal reputation
Send a message via AIM to projectsupramk3
You need to give the post alittle more time than eight minutes for a response. Give up the gost?? It's not a K24 turboloader, it's "turbolader" which is German for turbocharger.
So let me get this straight, your old 1G had a Blitz twin K24 kit on it, the turbos blew, and you put another bone stock 1G in because of this? Then you wonder why the two Toyota pea shooters at stock boost (maybe 200hp) don't have as much power as those turbos (which should do 350 with no problems)? What did you do with the old turbo kit? Why didn't you simply rebuild the turbos and be done with it?
CT12A's will not bolt onto the 1G CT12 manifold, different bolt pattern for virtually every flange.
projectsupramk3 is offline   Reply With Quote
Old 03-16-2006, 02:27 AM   #6
Twinturbo4x4Lux
i had thought about having them rebuilt but the mechanic pulled them off and showed me the shafts had play in em and it was blowing a load of oil out the exhaust and said it would be just as cheap to get a whole new engine,as far as i know the old turbo's are sitting in my garage next to my old engine with the manifold dump pipes and everythin to go with it, do u think it would be worth having the turbo's rebiult and put back on caus i dont know much about diferent types of turbos
Old 03-16-2006, 05:00 AM   #7
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
If you have a set of Blitz KKK series turbos it is most definatly worth having them rebuilt. They are as good as it gets. The "turboloader" thing threw me off. I didn't make the connection.
Old 03-16-2006, 09:27 AM   #8
Twinturbo4x4Lux
i might do that then, caus i wasnt sure how good the kkk turbo's were but i do know that blitz have a good name behind them, i will let you know how it goes and might get it put on the dyno before and after caus i jus got a apexi air flow converter for free that i have to get tuned in on the dyno apparently and hopefully then my hilux will really get up and go,
Bookmarks
Google
Web AF
