Buzzing sound in dash and clock reset
Google
Web AF
MyWife
03-11-2006, 02:29 PM
I have a '97 Passat Wagon V6 that no dealer can find a problem with, but perhaps you can help. When I turn the car on there is a buzzing sound in the dashboard (behind the speedometer) and the odometer and clock reset themselves. This does not happen every time I start the car, but frequently. I have seen similar posts on the web describing the exact same thing, but no answers. Anyone know what’s causing this?
Thanks!
veedubmechanic
03-11-2006, 05:43 PM
sounds like the instrument cluster is faulty. pretty common problem
MyWife
03-11-2006, 06:43 PM
Thank you! Would a faulty instrument cluster be consistent with the oil & water temp. gauges and tach dropping to zero during start up (which is when the clock and trip odometer reset)?
veedubmechanic
03-13-2006, 12:35 PM
check the 20a fuse in the engine compartment next to the battery.
also check the fuse next to the coolant resivour
MyWife
03-13-2006, 04:48 PM
I've checked those fuses and both are OK. Still think it's the instrument cluster?
Thanks!
Google
Web AF
