96 Neon Trouble Code 72
onerchprk
03-11-2006, 11:30 AM
I am getting an error code 72 from my 96 neon 2.0 dohc. I was wondering if the fix on this page http://forums.neons.org/viewtopic.php?t=104105&highlight=catalytic+converter+resistor will work if i did the resistor thing? I need a quick fix till i can get a cat. Thanks
das2123
03-11-2006, 03:29 PM
I am getting an error code 72 from my 96 neon 2.0 dohc. I was wondering if the fix on this page http://forums.neons.org/viewtopic.php?t=104105&highlight=catalytic+converter+resistor will work if i did the resistor thing? I need a quick fix till i can get a cat. ThanksThat would only help if you are removing the cat and driving around w/o one. It doens't trick the PCM into thinking it's a good functioning cat, rather that there is one there. I wouldn't waste the time, just get a replacement cat and you will be fine.
onerchprk
03-11-2006, 05:15 PM
The cat is hollow. That is why i am getting that code. I do not have a lot of money till the 3rd of next month.Just looking to get it emm tested...
das2123
03-11-2006, 08:25 PM
The cat is hollow. That is why i am getting that code. I do not have a lot of money till the 3rd of next month.Just looking to get it emm tested...Do you have to get tested before the 3rd of next month? If so, give the chip a try.
onerchprk
03-13-2006, 09:58 AM
Yes i do... My plates on it expire on the 15th...
