97 intrepid 3.5l start and stall
cjsuds13
03-10-2006, 12:09 AM
have changed plugs,wirers,injectors and pcm.it starts runs for 3 seconds and dies. has 150lbs <>15lbs per cylinder compresion.:banghead: lights flash after this happens for 5 minutes.no secuity in this car. black key,secuity i believe has a gray key.
PCM and BCM were to blame for this
sneakybert
03-10-2006, 12:29 AM
This sounds like the vehicles secuity alarm may be disabling the fuel pump . Have you tryed disabling the alarm with the key fob ? Try cycling the key in the drivers door lock clylinder.
wizardb
03-13-2006, 01:51 AM
count the light flashing there will be spaces kinda like morse code that is giving the code numbers of what it is seeing and then can check manual for the translation. also check fuel pump it may be going out where it has proper pressure to start and then wont hold it after starting.
cjsuds13
03-24-2006, 09:50 PM
90 flashes and is constant, no morse code. fuel preasure stays constant even after shut down.:banghead: stent car to dealer, 3 days ago, no word from them yet.
