Sienna Remote Programing
stevenleevo
07-03-2002, 12:44 PM
:flipa: :argue: :finger4: Any one know how to program remote for toyota Sienna ? Please help...we just got a replacement remote but have no idea how to program it.
Big Yellow Monkey
01-10-2004, 04:51 PM
Yup. I posted these instructions a little while back. Hope they help ya!
http://www.automotiveforums.com/vbulletin/showpost.php?p=1353161&postcount=4
-Biggie!
caproms1
01-31-2004, 01:35 PM
I just bought a used 2002 Sienna XLE and it did not come with a remote. It has two rear power doors, but on all the remotes I've seen so far, there is only one button for the power door. Is that the remote I should buy? Anyone know?
thanks,
-Mike
nuclearjack
04-19-2004, 11:40 AM
Are you only looking at these remote? as in on the web or are you holding them? my dad has a 2001 Sienna XLE and on the front are the three buttons and on the back is a sunken button that controls the drivers side power door. no Idea why that did it that way.
Big Yellow Monkey
04-19-2004, 12:21 PM
I'm holding the remote in my hand, and it has 2 buttons on the front (lock and unlock), and a sunken red "panic" button on the back. I don't have power sliding doors, as I only have a CE. It's a 2003 Sienna CE. Those are the remotes for which the code works. To double-check, it's only guaranteed to work for remotes with the following FCC code on the back:
FCC ID=CO43VT14T
Hope this helps...
And if you need a programming code, do what I did - find some remotes for sale on ebay for your specific vehicle, that come with programming instructions. I paid $8 US+$7 US shipping for a PAIR of remotes with programming instructions. The Toyota dealership we bought the van from wanted about $230 CDN PER REMOTE, after programming fees. Just a slight difference.
Or find a friend who works at a Toyota dealership. Or just say your remote stopped working so you need to get it "re-"programmed.
-Biggie!
nuclearjack
04-26-2004, 03:32 AM
sorry for the confusion I was talking about the power door remotes they have the second power door button on the back/
cockeyedgull
05-19-2004, 09:04 AM
I've got a 2001 LE and had no sucess with the instructions kindly shared by big yellow. I don't have a power sliding door. When I got the remote from e-bay the sellor sent the same instuctions big yellow posted, word for word. I have yet to hear anyone having sucess with these instructions.
Could there be something missing, or are they only for the CE. I wonder if when Big yellow got them from e-bay if they asked whether he drove a CE or an LE. And someone on another board, where these exact instructions are also circulating, mentioned that something might need to be grounded when programming certain models. Any more info anyone can share would be appreciated.
-Mark
spotco2
09-01-2004, 02:22 AM
The RS3200 was not used after about 97.
Here is a link to the correct programming procedure
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=33723&item=7919451481
Felliott
11-29-2004, 12:42 PM
I just received good instructions for programming a remote on my 2004 Sienna. These look pretty authentic, like they came out of a Toyota service manual. Still, I had to modify one step to get them to work. I bought two transmiiters on Ebay, and only one set of instructions really seemed to work.
If you want to see these instructions, email to me with Sienna in the subject, and I will send you a PDF file. If you know how to post a PDF on the web, please let me know, as I don't know if I will get inundated with requests.
Good luck.
Felliott
11-29-2004, 12:44 PM
You can email me direct at FEnext1@aol.com.
Latif
12-11-2004, 11:33 PM
Hi All,
I have 1998/LE Sienna that I have just purchased a remote on eBay.Remote ID is GQ43VT7T,1470.K1361 .I needed programming instructions. I have found some instructions on different Toyota models and years but they don't help me to work for 1998 Sienna/LE. Is any one would help me please? I’ll be thanking this act of kindness.
Latif
Jonathan Isenberg
02-01-2005, 06:55 PM
I struggled with programming my 98 toyota sienna keyless entry remote and finally got it. I bought a keyless entry on ebay and they sent instructions I have at home. It involved finding the right module in the center console underneath the radio and using a jumper wire to ground the right pin. If you are still looking for these directions, email me at jonathan@foxisland.org and I'll give them to you or post them.
Jonathan
Jonathan Isenberg
02-02-2005, 07:25 PM
Alright, here are the details I purchased for programming the remote for a 98 Toyota Sienna (remote has 3 buttons lock, unlock, panic):
1. With they key out of the ignition switch, locate the Wireless Door Lock ECU. The WDL ECU is located in the center console. You have to remove the drawer that is at the base (has slots to store CD's and other stuff) below the radio, lighter/12v outlets, and ashtray. The drawer comes out without any screws (on mine anyway) by pushing and pulling in the right places. There should be 3 units with connectors/wires plainly visible, the WDL ECU is the upper right one. (I have pictures I took of mine I can email you if you email me at jonathan@foxisland.org) The WDL ECU should have 15 pins/spaces for wires to plug into it.
2. With the ECU still connected, locate terminal number 9, PRG (will be empty-no wires going into it) and terminal 1, GND (black-white wire going into it). On mine, terminal 1 was the lower left corner, while terminal 9 was 2nd from the upper left. The directions say that you should see wires going into the back of cavities 1,4,5,6,10,11,14,& 15. Positions 2,3,6,7,9,12,& 13 are empty (although I remember that on mine there was one difference from that.).
3. Using a small wire (we'll call it a "jumper wire"), insert one end to terminal #1 and insert the other end through the empty terminal #9 cavity to touch the PRG pin of the ECU. The vehicle confirms programming mode by automatically requesting the power door locks to lock. Leave the wire connected for the rest of the procedure. Now, I couldn't get another wire in beside the ground wire in terminal #1. So I got a long wire and connected it straight to the negative terminal on the battery to act as a ground instead and connected that straight to pin/cavity #9. That worked for me.
4. Depress, then release, any button on the remote. The vehicle confirms registration by requesting the power door locks to lock once again.
5. To program an additional remote, repeat step 4 (up to 2 remotes).
6. Disconnect the jumper wire to exit programming mode.
That worked for me, you can email me if you have any problems, but that worked for me.
Jonathan Isenberg
02-02-2005, 11:13 PM
Ahh, I was just re-reading my directions and noticed a mistake (hopefully it would have been pretty easy to figure out anyway), the Wireless Door Lock ECU is the unit on the upper left, not right as I stated in step 1. Sorry about that!
clane5
04-13-2005, 08:55 PM
Using Jons instructions and pics I was able to locate the correct module for my 1999 Sienna, however it is different than the 98 and here are the steps I had to do. It took me some trial and error and expirementing to get it right, so hope fully this will save someone some headachs. I know it works on a 1999 Sienna, but it should work up to the 2003's. BTW thanks a bunch Jon!
Step 1: With they key out of the ignition switch and drivers door open and unlocked, locate the Door Receiver Control. The Door Receiver Control is located in the center console. You have to remove the drawer that is at the base (has slots to store CD's and other stuff) below the radio, lighter/12v outlets, and ashtray. The drawer comes out without any screws (on mine anyway) by pushing and pulling in the right places. There should be 3 units with connectors/wires visible; the Door Receiver Control is the upper left one. The Door Receiver Control should have a 7 pin/space for wires to plug into it.
Step 2: With the Door Receiver Control still connected, locate terminal number 3, PRG (will be empty-no wires going into it) and terminal 1, GND (black-white wire going into it). On mine, terminal 1 was the far left as you look at the unit and terminal 3 was 3rd from the far left. Using a small wire (we'll call it a "jumper wire"), insert one end to terminal #1 and insert the other end through the empty terminal #3 cavity to touch the PRG pin of the Door Receiver Control. When you make a successful connection the door locks cycle, confirming that you have entered into programming mode. Leave the wire connected for the rest of the procedure. I used a 14 gauge wire and it fit snuggly into terminal 3 and snuggly in the notch next to terminal 1.
Step 3: Depress both lock and unlock buttons on the remote simultaneously for approximately 1 second and release
Step 4: Immediately after that depress the lock button on the remote for approximately 2 seconds and release. The door locks should cycle once to confirm that the remote has been successfully programmed.
Do Steps 3 & 4 for all remotes.
Step 4: Remove jumper from Door Receiver Control and the locks will cycle. Test all remotes, if everything is working properly, put your draw back together and you have save yourself a trip to the dealer and $40 - $100 in labor charges to program your remotes.
hokie
04-16-2005, 11:56 AM
I just programmed my SIENNA XLE 04 with some procedere I found for a highlander ...
1. Start with the following conditions: You are in the drivers seat.
a. Key is out of the ignition
b. Driver door is open (all other doors closed)
c. Driver door is unlocked (other doors don't matter)
2. Insert and remove the key from the ignition twice within 5 seconds.
3. Close and open the drivers door twice within 40 seconds.
4. Insert the key into the ignition and remove it.
5. Close and open the drivers door twice within 40 seconds.
6. Insert the key into the ignition.
7. Close the door
8. Turn the key in the ignition on and then off.
9. Remove the key from the ignition.
10. The power locks should automatically cycle once to indicate that you have successfully entered program mode.
11. Within 40 seconds of the entering program mode.
a. press both transmitter lock and unlock buttons SIMULTANEOUSLY for a duration of from 1 to 1.5 seconds.
b. within 3 seconds, press the transmitter lock button for more than 1 second and release.
c. If the transmitter has been sucessfully programmed, the power locks will automatically cycle once. If they cycle twice, the remote has not been accepted.
d. If multiple remotes are to be programmed, repeat steps A-C.
12. Open the driver's door to leave programming mode
You should be done, check the remotes!
Hope this is of help for someone else as well to save some bucks ...
Drive save!
JLauto05
06-30-2005, 04:29 AM
need keyless remote programming inst for 99 XLE w/power sliding door
JLauto05
06-30-2005, 04:32 AM
thanks in advance for anyone who can help me and others save hundreds of $$ by posting the programming instructions for a 99 Sienna XLE WITH POWER SLIDING DOOR =)
jberenyi
10-06-2005, 09:15 PM
Please email me the 2004 Sienna Remote programming instructions. Thanks!!
jberenyi@yahoo.com
Dad3
07-28-2007, 01:43 PM
:grinyes: I just bougth a remote from EBay and these instructions from this site worked for my 2005 Sienna XLE Limited with sliding side doors and rear hatch. Just go to the site and pick the make, model and year. Good Luck
http://www.programyourremote.com/
Luciana Melo
12-14-2010, 03:43 PM
Hi,
Could you send me the instructions for programing the transmitter for my Toyota Sienna 2004?
I really appreciate all your post that help us save lots of $$$$!!!!!
Thanks a lot!
My email address is: lucianamelo@gmail.com
Onblsht
12-16-2010, 12:27 AM
There are a few different remote types available for the 2004 Sienna, but they all use the same programming type:
http://originalkeyless.com/searchquick-submit.sc?keywords=%2204+Sienna%22
drivers seat.
within 5 seconds.
seconds.
seconds.
7. Close the door
mode.
seconds.
steps A-C.
12. Open the driver's door.
ldkronos
12-21-2010, 08:10 AM
Does anyone know how to program the remote on the 2011 Sienna? They use the same model remote as the older years, but something seems to have changed in the instructions. I tried the instructions from the older model, but I never get the lock/unlock confirmation.
SurfinGator
03-17-2011, 06:12 PM
I don't know about a 2011, but this is the correct program instructions for the 1999-2003 Sienna any body style power doors or not. The other post had you removing the key too many times. If it doesn't work, you did it wrong.
drivers seat.
within 5 seconds.
seconds.
seconds.
7. Close the door
mode.
seconds.
steps A-C.
mulm
05-20-2011, 12:05 PM
I followed some instructions posted and was able to program a remote for my 2004 Sienna XLE/AWD. When I compared to this post there was one difference with the step after the holding of the lock unlock buttons simultaneously. My instrucitions said to immediately press the unlock buy itself. The instructions here said wait 3 seconds and press the lock button. Try both ways in case one way did not work. I have the type 3 remote with five buttons. The two passenge sider door buttons worked. There is a type 4 remote that has six buttons so you can open the lift gate. Now I need to get a key cut and programmed. All I have is a submaster and no record of key number. I hope the Dealership can help cut by using my vin number or something. All I have is a submaster so I dont want to cut the key off of that because I would like for it to be a master key.
