Just got an 02 and need some install help
ricergurl
07-03-2002, 10:09 AM
i just got a 02 civic,my first 5spd well its not anything like the 5th gen im used to so how do i get the pocket that holds the radio out so i can put the after market cd player install kit and cd player in with out messing anything up?...even putting the hyperwhites in was difficult...help please:)
b16a3sol
07-03-2002, 06:11 PM
here are instructions for how to take out the factory HU - click here (http://www.2k1civic.com/diy/radio.cfm) .
for other DIY stuff for your civic look at www.2k1civic.com/diy . they have a lot of stuff in there that should help you out with about anything you could do on your own. good luck.
ce01cvcex
07-03-2002, 07:06 PM
ok, i am a member on 7thgencivic.com or 2k1civic.com, whatever you want to call it (its the same site). anyway. depending on what options you have, this is how you do it. first, you have a bottom console infront of the shifter, either with or without an ashtray, it doesnt really matter which. you'll need to pop it out, it is held on by some clips, so some force is required. once you pop it out, you will need to disconnect the wires, if you have any. then, you'll need to remove the 2 screws in the bracket at the top of the opening. (requires some gymnastics moves, as this is a tight opening) anyway, after removing the 2 screws, you will be able eto pop out the main console where the HU is. it also has clips so you'll have to pull pretty hard. just dont break them. you could use a small flathead screwdriver with a rag wrapped around it to pry it out, just be careful not to crease your dash. then you simply unbolt the stock HU and replace it with your new HU. make sure you have a trim kit, so it doesnt look ghetto. also, you should check out the site www.7thgencivic.com there is alot of information on the 7th generation civic, ranging from diy's to parts, along with forums where you can ask others opinions about your ride, get tech tips etc. cheers
ricergurl
07-05-2002, 01:06 AM
thankz.. cuz i have my harness and dash kit all put together i just cant get the radio out.. this new civic isnt fun to work on i always think ill mess soemthing up.. course iv only had it 2 days...
