Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 03-08-2006, 09:22 PM   #1
Blazer1996
Blazer1996 Normal reputation
1990 Acura Integra Alternator
Does anyone know how to get the alternator out of a 1990 Acura Integra? I have the alternator disconnected and unbolted. The problem is finding a space wide enough for it to fit through. I can't get it around the axle or anything else. Hope someone knows how this is done.
Thanks,
JD
Blazer1996 is offline   Reply With Quote
Old 03-08-2006, 10:21 PM   #2
eckoman_pdx
Honda God
eckoman_pdx's Avatar
eckoman_pdx Normal reputation
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: 1990 Acura Integra Alternator
Thanks,
JD
You have to remove the axle to remove the alternator. Genius design, isn't it?
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
eckoman_pdx is offline   Reply With Quote
Old 03-11-2006, 08:42 AM   #3
Blazer1996
That's what I was affraid of.
Thanks for the input.
Old 03-12-2006, 02:45 AM   #4
eckoman_pdx
Honda God
No problem...always glad to help.
EPR Member 4 Life
Old 04-02-2006, 01:37 PM   #5
integragsrs
integragsrs Normal reputation
Send a message via AIM to integragsrs Send a message via Yahoo to integragsrs
do you think it might be possible to remove it by taking out the brake master cylinder and pulling it out that way??
integragsrs is offline   Reply With Quote
Old 04-03-2006, 01:09 PM   #6
knorwj
knorwj's Avatar
knorwj Normal reputation
Send a message via AIM to knorwj
only options to remove the alternator from a 2nd gen, are to drop an axle or disassemble the alternator in the engine bay and take it out piece by piece.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
knorwj is offline   Reply With Quote
Old 04-06-2006, 11:48 AM   #7
dwaynesouthside
dwaynesouthside Normal reputation
Thanks,
JD
Well I had to put in an alternator not to long ago and I had the same problem..I didn't want to take of the axle so this is what I did....First it depends on the size of your arm...Second your going to have two peopl..One on bottom to hold it and another on top to tighten it up....that is how I did it..Hope you can get it in
dwaynesouthside is offline   Reply With Quote
Old 04-07-2006, 09:01 AM   #8
charlief1
charlief1 Normal reputation
I have an "alternate" plan. Instead of going to the trouble to replace the whole alternator, it should be possible, and Much easier and cheaper, to replace only the brushes, which might solve your charging problem. I believe there is a little access hatch to allow this without complete remove and replace. Last year, my 90 Teg's charging light came on during a short trip, the battery died before I could get home and I had to get it towed. My great local shop charged $150 to install a new set of brushes and I've had no trouble since.
charlief1 is offline   Reply With Quote
Old 04-08-2006, 01:36 AM   #9
superbluecivicsi
AF - Advisor
superbluecivicsi Normal reputation
why dont you just drop the driverside motor mount and jack up the block???????????
bam!!!!!!!1
now your alternator is out
99 JRSC@9.5 psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
superbluecivicsi is offline   Reply With Quote
Old 04-08-2006, 02:51 AM   #10
knorwj
knorwj's Avatar
bam!!!!!!!1
because its so damn easy to drop the axles out of these cars. whats the point? 4 lug nuts, 1 nut on the axle, castleated (sp?) ball joint nut, and bam you got an axle out, now drop the alternator. You don't even need to screw with anything that would affect the alignment. 6 nuts and you can pop the axle out. The hardest part is jacking it up... besides I think you'd rip the opposite side motor mount (tranny mount) before you had enough room to remove the alternator. Not to mention the one by the header.
Old:
New:
Newer:
Old 04-08-2006, 03:03 AM   #11
superbluecivicsi
AF - Advisor
you dont need to jack it high. well, it might be considered tough if you dont have a nice jack to work with.
i bet i can drop the alternator out faster the mount way than if you did it the axle way..............................loser treats to hooters with a pitcher of beer and a cuban sandwhich with curly fries
Old 04-08-2006, 04:44 AM   #12
knorwj
knorwj's Avatar
hmmm I might be up for that bet considering i have alot of practice pulling my axles and I need to rebuild my alternator anyway...
Old:
New:
Newer:
Old 04-15-2006, 07:13 PM   #13
clampjockey
clampjockey Normal reputation
I have to agree with knorwj, the easiest way, and the way they are supposed to be removed, is to pull your axle. It's not as hard of a job as it looks, just be carefull not to rip the boot when prying on the axle. It's quite easy if you have an extra person to pry from the top while you are prying from the bottom.
clampjockey is offline   Reply With Quote
Old 04-15-2006, 10:37 PM   #14
superbluecivicsi
AF - Advisor
i still think 2x 17mm bolts on the driverside mount and if you have power steering makes an extra 2x 14mm bolts and then apply the jack is much much easier.
what ever way works.
Old 04-16-2006, 06:02 PM   #15
eckoman_pdx
Honda God
The only way I can see the axel way being a problem is if you have no air gun and your axel hub nut is seized on there and won't bust loose, no matter how big a breaker bar you have. Then, it can be hard as heck to break that nut loose...but if you hae an air gun bam....it's off in seconds anyway, even if it's seized...so it doesn't matter.
EPR Member 4 Life
Bookmarks
Google
Web AF
