1997 Lean bank 1, lean bank 2Baja SS 03-07-2006, 08:40 PM I'm having a heck of a time getting my Jimmy to pass the new NY emissions test. Code shows lean bank 1 and 2. So far I've replaced both o2 sensors, Maf sensor. check engine light still lights under 100 miles of resetting codes. Any suggestions as to where to look next ? Thanks old_master 03-07-2006, 09:24 PM Post the exact codes along with any service history you have, and we can try to troubleshoot it for you. Baja SS 03-08-2006, 07:06 AM Codes were P0171, P0174 I'm thinking there must be a vaccume leak somewhere but I sure cant find one. maxwedge 03-08-2006, 10:07 AM Well unmetered air is getting into the system from some place, no mods done? How does the engine run? Check for low fuel pressure? Baja SS 03-08-2006, 11:45 AM No mods were done by myself, And none show in the service records from the first owner. The engine rus fine just a little shake at idle. There was a time last winter when it would kinda bog down when taking off from stop, but that has stopped. maxwedge 03-08-2006, 12:00 PM You should have a full scan done to look at all the parameters and continue to look for vacuum leaks particularly around the intake. Automotive Network, Inc., Copyright ©2012
