Originally Posted by ballarman2
What drains the battery faster while the car is off? Turning on the stereo with the key on, or turning on the radio with out turning the key? Should i connect the red wire to a hot fuse or straight to the batter?
Having the key on without the engine running isn't so much about the drain, as it is about screwing up your ignition system. With the key on, you're putting power into the coil, condenser, points, etc. That can burn out those components.
If you're bound and determined to run a high powered stereo in your Bug, go with a second battery wired in parallel (+ to + and - to -).
To run the stereo with the engine off, wire it directly to a constant hot terminal.
