Re: Removing center trim to remove radio 01 Pathfinder
I've done this on my '02, and I'm almost positive it's the same for an '01.
Remove the middle air vents (the 2 vents come off in one piece). Your best bet is to pry them off with a regular screwdriver, but wedge a piece of cloth in between the unit and dashboard, and your screwdriver so you don't crack/break anything. After you get the piece out, you'll see two screws at the top holding in the trim. Remove those, pry that piece off (screwdriver method works fine here, too), and then you'll see how the radio is held in place. Hope this works.
-RJL
