Dies out after it startsMyNeoN95 03-06-2006, 07:26 PM 95 SOHC 2.0L After starting the car it dies right out. I did the engine light codes and it's 25(AIS),Automatic Idle Speed. What is this, What can I do to fix it? Thanks for any responds. das2123 03-06-2006, 09:58 PM A code 25 can be any of these: *An open or shorted condition detected in one or more of the idle air control motor circuits. *Actual idle speed does not equal target idle speed. *MAP sensor signal does not correlate with TPS signal. *IAC fully seated. Check for possible vacuum leak. You need to get it scanned so you can get the "P" code or just check all your wiring and make sure all the sensors are seated and clean. Also check for vacuum leaks. Automotive Network, Inc., Copyright ©2012
