Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder/Terrano/QX4
Old 03-06-2006, 05:38 AM   #1
zbukhari
zbukhari Normal reputation
Question Nissan trouble P1491
Pathfinder 2000 SE 110K. The "Service Engin Soon" light comes on and goes off. I got it free checkup from local auto part store and the following "Nissan troble code P1491 Manufacturer Specfic Powertrain Trouble" showed up. I was told not to worry about it and the code was cleared free of charge. After week or so the light came back on, same results P1491. I however did some research and the following "CodeVacuum Cut Valve Bypass Valve" explanation given for P1491. Can any one please help me to understand this? Can I fix it my self? Thanks.
Z
zbukhari is offline   Reply With Quote
Old 03-06-2006, 07:25 AM   #2
lewisnc100
lewisnc100 Normal reputation
Re: Nissan trouble P1491
Here's a link to where the valve is located (this is on a 97, not sure if the 2000 is in the same spot): http://groups.msn.com/LewisPictures/...oto&PhotoID=29
Check the harness for damage etc. To test remove the valve, when applying 12V to the two connectors the air passage should be open, no 12V and the air passage is closed.
1997 Pathfinder XE
Air Lift Air Bags, Warn Hubs
2000 Windstar SEL
lewisnc100 is offline   Reply With Quote
Old 03-08-2006, 02:52 AM   #3
zbukhari
Thanks, will try this solution.
Z
Old 08-24-2006, 12:45 AM   #4
zbukhari
Exclamation Re: Nissan trouble P1491
Does any knows the location of "Vacuum Cut Valve Bypass Valve" for Nissan Pathfinder 2000 SE? Thanks!
Z
Old 08-25-2006, 07:11 AM   #5
lewisnc100
Did you look where the diagram link above showed it? Maybe they moved it for the 2000.
1997 Pathfinder XE
2000 Windstar SEL
Bookmarks
Google
Web AF
