Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 03-05-2006, 12:55 PM   #1
surpera1
surpera1 Normal reputation
87 s-10 swap 2.8 to 4.3 advice
my old 87 s-10 came with the pos 2.8.had it since brand new and blew a head gasket ran hot anf f-d it up good.hahahahaha.anyway what sucks is i never dogged it and always babied it.died at 87000 miles.you believe that ? so im thinking about slapping in a 4.3.they came out on the s10 in 88.will it drop right in ?will the same tranny be ok ? im not trying to build a hot rod.i just want a good motor.i would like the air and cruise control to still work.the truck wont even be used much-but i would like it to run.looking for a price estimate to have this work done.im not a mechanic.also looking for recommendations.thanks
surpera1 is offline   Reply With Quote
Old 03-06-2006, 11:39 PM   #2
dmbrisket 51
dmbrisket 51's Avatar
dmbrisket 51 Normal reputation
Send a message via AIM to dmbrisket 51
Re: 87 s-10 swap 2.8 to 4.3 advice
not worth it, every thing from fuel pump, transmission, and wiring is invalved, just as much $$ to put a 350 in
dmbrisket 51 is offline   Reply With Quote
Old 03-07-2006, 06:31 AM   #3
surpera1
i was kinda thinking about grabbing the engine and transmission from a later model.youre saying i could put a 350 in for the same money ? wow.would it fit ok ? can you give me a cost estimate ?im not really trying to build a hot rod-but if it cost the same - why not ? boy that thing would get up and go.hahahahahah.that 2.8 is a piece of ****.so im definitelt not going back in with one of those.
Old 03-07-2006, 09:37 AM   #4
OverBoardProject
Banned
OverBoardProject Normal reputation
Look into either a V8, which is the same amount of work as a 4.3L, or a 3.4L from a Comaro, which is a direct bolt in
Here's some links on the 3.4L swap
http://s-series.org/module-htmlpages...1-print-1.html
http://users.spec.net/home/emxjc/
http://www.off-road.com/jeep/cheroke...28-34swap.html
OverBoardProject is offline   Reply With Quote
Old 03-07-2006, 12:07 PM   #5
dmbrisket 51
cost on the swap is between 2 and 3k if your an average joe, but that is a 4.3 to 350 swap, im not sure on numbers from a 2.8 to 350, your best option is what obp reccomended. that is to do a 3400 swap... either the 4.3 or 5.7 takes a different 700r4 then the one you have, you need the moter tranny, wiring, and fuel pump to the small block, also every one braggs a 3400 fits, but they are a rare bird to find, a 3.1/3100 fits also (did that one in the firebird) and i used every thing from the 2.8 except the block, the heads, computer and wiring was all 2.8 (did have to call jet and have a chip cut for the larger volume of air commen in...
Bookmarks
Google
Web AF
