Roof Rackpackman 08-10-2001, 01:20 PM Just a question to you guys out there that have the 'factory' Xterra roof rack. I was interested in getting that new Calmini deal for my truck but I have an "aftermarket" (like the Jeep Ckerokee) roof rack. Are there threaded bolt-holes on the roof, or are they just screwed to the roof supports? Packman Matt Peckham 08-10-2001, 01:41 PM they are bolted to the existing roofrack, I think is what you are asking. The only one available that will bolt TO the roof itself, AFAIK, is the Calmini. I think they are redesigning the front to have a bend to better match the lines of the Xterra. I am having a custom rack done... which bolts to the place where the stock rack bolts, thus, eliminating the stock rack from the equation. Matt packman 08-10-2001, 01:54 PM I guess I put it the wrong way, I have one of those cheapo plastic slider racks, not one of those high-speed Kargomaster ones. I just wanted to know if the Calmini rack muonted in the same holes as the Nissan aluminum rack. Matt Peckham 08-10-2001, 02:17 PM yes, it uses the original roofrack holes. packman 08-10-2001, 02:21 PM SWEET I guess it is time to break out the drill and the credit cards!!:D Matt Peckham 08-10-2001, 02:24 PM no drill needed. but do get the best T shaped massive Torx driver you can. the bolts that hold the roofrack down are heavily coated woth Lock Tite. and I ended up having to drill one out. the Torx wouldn't remove it, stripped the threads, and all 4 torx we tried wouldn't remove it either. go find a big T shaped one for 15.00 from a good hardware store. trust me, it's worth it. You've been down that road... you know where it leads.... Automotive Network, Inc., Copyright ©2012
