New Expo Owner Needs Door Codebighops2000 03-02-2006, 10:43 PM I just bought a 2002 Expo and the idiots didnt knowthe door code is there any way that I can retrieve this information or change the code without paying the dealership 75 bucks Redwanr50 03-03-2006, 06:07 PM I understand there is a hard code that is programmed into it that cannot be changed. This is located on the security system (PATS) under the dash. Not sure of the location but I looked this up quite a while ago for ny nephew and his Explorer. Once you get the code off this box then you can use it to access the system and recode the setting to whatever you want. I found this info by doing a search on the internet using Ford Expedition Security Code Reset or something along that lines. Good luck. pennypicher 03-03-2006, 11:08 PM Suppose to be right under the colum on a cover of some sort. Then if I remember right in your book it tells how to change to your own number. bighops2000 03-05-2006, 06:09 PM It was on the security box under the dash. Thanks.yall Automotive Network, Inc., Copyright ©2012
