Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 03-02-2006, 05:19 PM   #1
OverBoardProject
Banned
OverBoardProject Normal reputation
How to improve your ride quality
One reason why our vehicles ride so nicely when they are new is because the leaf springs are all slippery. So they slide over each other as they flex.
As the slippery surface wears away the ride gets worst and worst. There are ways to combat this.
The easy method involves simple hand tools, and a can of spray lube. WD40 won't work for this, it must be some sort of spray grease.
position the jack under the frame, and crack loose the lug nuts. Jack up that side and support it. remove wheel.
Now wedge a flat head screw driver between 2 of the leafs
spray some lube in there.
remove the screw driver and do the same to the other leafs.
On the front 1/2 you'll see a clamp like this
remove it, and do the same thing. Then clean up the threads and put it back.
Put the wheel back on and lower the jack. Don't forget to torque the wheel to spec's.
Do the same thing to the other side.
It makes such a big difference that I'd like to take the extra time to do this job every time that I rotate the tires.
If your on the market for new springs you can replace them with a set that has these grease able inserts installed.
I'm looking for a do it yourself insert set, but haven't found any that I like yet.
OverBoardProject is offline   Reply With Quote
Old 03-02-2006, 05:41 PM   #2
Bads Crew
Bads Crew's Avatar
Bads Crew Normal reputation
Re: How to improve your ride quality
Great Post.. I'm a recycler. When I change the gear oil in the rear or front diff I will save the old and put it back in the container. The top of the plastic gear oil containers have the pointed end that you snip off. I will spread the leafs and squirt the gear oil between them.
Bads Crew is offline   Reply With Quote
Old 03-02-2006, 05:49 PM   #3
OverBoardProject
Banned
thanks Bads, and thats a Great Idea.
I'll have to do that nexe time.
Old 03-03-2006, 01:08 AM   #4
OverBoardProject
Banned
I was just told that you don't have to remove the clamp on 2wd trucks
Old 03-03-2006, 03:19 AM   #5
mike1224
mike1224's Avatar
mike1224 Normal reputation
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
how often should this be done?
2000 Chevy S-10 2.2L K&N FIPK GEN2 CAI Ravin Z55 Exhaust
2005 Hyundai Elantra GT 2.0L stock for now.
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
mike1224 is offline   Reply With Quote
Old 03-03-2006, 08:30 AM   #6
OverBoardProject
Banned
If possible every time that you have the tire off. It only takes seconds to spray everything.
And if you notice the ride getting harsh you really could just crawl under and spray them from the other side.
I'm starting to rotate my tires more often and this will help motivate me.
Bookmarks
Google
Web AF
