84 caprice question
chris_do_it_big
02-28-2006, 05:50 PM
I recently pulled my 84 out the garage to drive it this past weekend and what i noticed was whenever it hit about 20-25 mph it wouldnt go any faster and it made a sort of idling noise/loud noise like something was being stressed under the hood. ...checked oil, coolant, and all the other fluids...so what could the problem be....
bobss396
03-01-2006, 12:15 PM
If it happened all of a sudden, I'd suspect either the converter lockup solenoid or a totally clogged exhaust. You can unplug the solenoid plug from the tranny & take it for a ride. It's located on the driver's side of the transmission towards the front. The exhaust will whistle or try to escape elsewhere if it had a clogged cat or collapsed inner pipe. You won't be getting much pressure out of the tailpipe either.
Bob
chris_do_it_big
03-04-2006, 10:55 AM
okkay i will try that
TommySS
03-05-2006, 05:02 PM
Request more info. Need mileage and maintenance status.
chris_do_it_big
03-05-2006, 07:06 PM
Mileage...145056
As far as maintenance goes...i just got the car about 2 or 3 months ago but i never had the chance to actually mess around wit...i got new distributor and cap, changed oil, filter, spark plugs ...the normal tune-up...but besides that i have not done anything to it because this was the first actual problem
TommySS
03-05-2006, 08:03 PM
If the engine revs ok, the cat is probably ok. I'd have the trans checked. If you got that far on the original, it's time.
