1999 jimmy remote programming
bfwb31
02-27-2006, 09:57 PM
i need to know how to program my new remotes for my keyless entry on my 1999 gmc jimmy 4x4 . please help asap.
thank you bfwb31 :banghead:
bfwb31
03-02-2006, 06:03 PM
PLEASE SEND INFO TO HELP ME PROGRAM THESE REMOTES.:banghead:
Onblsht
03-04-2006, 12:34 AM
PROGRAMMING INSTRUCTIONS
All Extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Transmitter Programming:
1) With the driver door closed, hold down the power UNLOCK button on the door panel.
2) Turn the ignition switch to the ON position.
3) Turn the ignition switch to the OFF position.
4) Turn the ignition switch to the ON position.
5) Turn the ignition switch to the OFF position.
6) Release the power unlock button on the door panel. The remote control door lock receiver will respond by cycling the locks to indicate the receiver is in the programming mode.
7) Hold down the lock and unlock button on the transmitter for about 30 seconds. The locks will again cycle to confirm programming.
- REPEAT step 7 for each additional transmitter.
8) Turn the ignition to the ON position in order to exit the transmitter programming mode.
bfwb31
03-05-2006, 08:22 PM
thanks for the info on the remotes it work great .............
thank you for the help , :) :grinyes:
