sti turbo installdonkeyboy 02-26-2006, 05:22 PM i just got an STI turbo and intercooler....i was wondering if anyone knew what is needed to put it on a wrx in terms of whether it needs tuning or not....or can it be bolted right on.... freakray 02-26-2006, 05:29 PM It will require some tuning, the STI turbo has a larger boost ability than the stock. donkeyboy 02-26-2006, 08:34 PM but wont the stock boost solenoid keep the boost at a stock level? i know it will produce more cfm...but it should maintain stock boost right? freakray 02-26-2006, 09:17 PM What's the point of changing the set up if you're going to keep the stock levels? donkeyboy 02-27-2006, 08:34 PM the sti turbo has a greater cfm rating per psi of boost...thusfar increasing air flow...plus it is more reliable of a turbo....also later on it will be running more boost with tuning...for now i jsut want to put it on...mystock turbo has some shaft play... Right_LiRrr 02-28-2006, 04:17 AM Just tune it and increase the PSI by a little bit. We all know how bugeyes onwards don't like stuff bolted onto them. (assuming you have one of these wrxs lol). We all know tuning is expensive but better to do it once and do it right. freakray 02-28-2006, 07:52 AM You'll only be moving more cfm if you increase the pipe diameters, if you don't replace all the pipes, you'll have the effect of a restrictor on the output of the turbo. Replace pipes, tune.....zoooooooom! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
