Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 02-25-2006, 11:44 PM   #1
High Octane Tint
High Octane Tint Normal reputation
4.3 S-10 Jerking - Skipping when accelerating
I have a 2002 S-10 4.3 5 speed, the problem I am having is that when I accelerate my truck jerks, almost like it missing, it idles perfect, the rpm guage never changes, I have ran fuel additive to ensure it's not water in the line, this is my second tank of fuel so I dont think its a "bad gas" issue either. It only does it when you get on the gas fairly good. I'm going to change the fuel filter and see if that helps but any ideas from the forum would be great. BTW, the truck has 50K on it. Thanks again for your time.
High Octane Tint is offline   Reply With Quote
Old 02-26-2006, 10:53 AM   #2
Cam1959
Cam1959 Normal reputation
Re: 4.3 S-10 Jerking - Skipping when accelerating
could be weak spark not working under load. maybe change spark plug wires, cap, rotor, coil. check wires feeding coil for loose or dirty connections.
1983 S10 4WD carbed 2.8L automatic w A/C
Cam1959 is offline   Reply With Quote
Old 02-26-2006, 09:27 PM   #3
eti engineer
eti engineer's Avatar
eti engineer Normal reputation
How many miles do you have on it??
eti engineer is offline   Reply With Quote
Old 02-28-2006, 08:34 AM   #4
brandon200317
brandon200317 Normal reputation
Way to read... he said he has 50K on it
brandon200317 is offline   Reply With Quote
Old 03-04-2006, 10:52 PM   #5
lilbigjohn007
lilbigjohn007 Normal reputation
I have an 89 blazer w/4.3 and having similar problem. Mine idles and runs fine when its cold when it warms up it idles rough and sometimes jerks and backfires through the throtle body while accelerating. I've replaced the EGR valve, the EGR solinoid, MAP sensor, and still having problems.
lilbigjohn007 is offline   Reply With Quote
Old 03-05-2006, 09:59 AM   #6
Bads Crew
Bads Crew's Avatar
Bads Crew Normal reputation
I would look at the cap and rotor first. The stock GM cap sucks. Go with one with the brass tips. Cap and Rotor Review I would also change the fuel filter and run a bottle of fuel injector cleaner in my gas after changing the filter. If the truck has TBI they are knon to blow base gaskets under the throtle body. you can try tighting the bolts holding it to the intake. If its not TBI read this thread Spider
Bads Crew is offline   Reply With Quote
Bookmarks
Google
Web AF
