Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 02-25-2006, 12:10 PM   #1
DoubleE1
DoubleE1 Normal reputation
'90 clutch problem
I need some input on this problem. It started with a light smooth chatter type sound as the pedal was released (in all gears). So I tried to bleed it. It still did it for a few more times and now I can't get it to go into any gear with it running. The fluid level is fine.
Any Ideas before I check the clutc plate? I don't want to drop the tranny if I don't have to.
Thanks,
Double E
DoubleE1 is offline   Reply With Quote
Old 03-05-2006, 05:19 AM   #2
slowneasy
slowneasy Normal reputation
Re: '90 clutch problem
I had a hydraulic problem with my 95. I flush the system out with isopropyl alcohol. Let the alcohol work over night. Flush the alcohol out with fresh fluid. Have some one work the peddel while you work the bleeder screw so as not to let air back in the system. I would replace or repair the hydraulic system before replacing the clutch because you have a disengagment problem. A worn out clutch disc would cause an engagment or slipping problem.
slowneasy is offline   Reply With Quote
Bookmarks
Google
Web AF
