Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Passat > '97+
Old 02-23-2006, 10:47 PM   #1
moto_racer
moto_racer Normal reputation
Lightbulb '98 passat 1.8t swap for '02?
I have a 98 passat 1.8t, with an automatic transmission, and i want to change it for a 2002 passat 1.8t engine also with automatice transmission, but i want to change just the engine, or the block off the engine. so i have a ? if there is a difference and what i would have to change or modify. thanks.
moto_racer is offline   Reply With Quote
Old 02-25-2006, 03:46 PM   #2
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
veedubmechanic Normal reputation
Re: '98 passat 1.8t swap for '02?
The engine is basically the same. You will need the ecm and new engine harness. you will also need a different throttle body (electrical not throttle cable style.) May need a new transmission harness. Different cooling system so the coolant lines will be different (98 external water pump 02 timing belt driven w-pump)
ASE and VW certified. Just here to help
all check light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
veedubmechanic is offline   Reply With Quote
Bookmarks
Google
Web AF
