nitrousthe_game_rock 02-23-2006, 12:17 PM What size of shot (if any) is good to run on a 99 dohc neon? the motor only has 60,xxx miles and runs well. das2123 02-23-2006, 12:32 PM What size of shot (if any) is good to run on a 99 dohc neon? the motor only has 60,xxx miles and runs well.You can run a 50 shot pretty easily and stay reliable. A 75 shot is pushing it, and a 100 shot, you better have some damn good internals and a strong engine. I don't have experience with this, but this is info I have read on other forums and trust the people I got the info from. vamc 02-25-2006, 12:02 AM 50 shot wet. Wet system b/c its safer, less power, but safer to run. Safty first. srtkiller 03-05-2006, 09:58 PM you can run a 50 to 70 shot all day i did on my 98 just make sure it is a wet kit and youll be fine just run at least 91 92 gas allso you wont lose power on a wet kit if u really wanna feel it go to a direct port vamc 03-05-2006, 10:08 PM Wont the heat crack the head at a certon point? das2123 03-06-2006, 12:48 AM Wont the heat crack the head at a certon point?Just don't abuse it and you should be fine. vamc 03-06-2006, 05:15 PM True the_game_rock 03-07-2006, 07:14 PM you can run a 50 to 70 shot all day i did on my 98 just make sure it is a wet kit and youll be fine just run at least 91 92 gas allso you wont lose power on a wet kit if u really wanna feel it go to a direct port why get a wet kit? I was going to get a dry whats the difference? besides where the nitrous runs vamc 03-07-2006, 07:26 PM Wet is safer! When it is mixed with the fuel, its more stable. I got a ma. in science. Its safer, trust me. das2123 03-07-2006, 08:45 PM Wet is safer! When it is mixed with the fuel, its more stable. I got a ma. in science. Its safer, trust me.I think a wet kit is better for 100 shot and up, if he is only running a 50 to 75 shot then a dry kit would be fine, don't you think? vamc 03-07-2006, 09:32 PM mmmmmmmmmm, you have me thinking now........5 min later......100shot and up,,,yes...50-75...for a short time. I.E. drag strip or so. but if your using it constently on, let say the highway, no. But if he does use it on the highway constently, heat will be a problem. Nos burns very hot, it can hurt the o2 sencer and kill the cat.-for the constent usage. thats what i think. Do you sir agree? What do you think? das2123 03-07-2006, 11:11 PM mmmmmmmmmm, you have me thinking now........5 min later......100shot and up,,,yes...50-75...for a short time. I.E. drag strip or so. but if your using it constently on, let say the highway, no. But if he does use it on the highway constently, heat will be a problem. Nos burns very hot, it can hurt the o2 sencer and kill the cat.-for the constent usage. thats what i think. Do you sir agree? What do you think?Agreed...as long as it isn't abused, the 50-75 dry shot should be fine. But if someone is going to wanna hit the switch everytime a ricer pulls up next to them, then the wet kit is the safer option for them. dtjackten 03-07-2006, 11:42 PM dry shot is fine if he is only going to the track and running it, but like you said if he is going to use it everytime he wants to race someone on the highway, with a dry setup he will blow that engine right out threw the hood!!! but a wet will be alot safer to run and will make the engine last alot longer over time because of the fuel added to the Nitrous...... das2123 03-08-2006, 09:02 AM Keep in mind the_game_rock, you will be gassing up more with the wet shot because as mentioned, you are adding fuel to the mix. the_game_rock 03-08-2006, 09:59 AM Keep in mind the_game_rock, you will be gassing up more with the wet shot because as mentioned, you are adding fuel to the mix. just a 50 shot das2123 03-08-2006, 11:25 AM just a 50 shotDon't abuse it and you should be fine. vamc 03-08-2006, 03:14 PM Just watch your engine temp. Be careful out there. the_game_rock 09-11-2006, 10:36 AM cant use a dry kit on a neon b/c the fuel pressure regulater is in the gas tank at least a zex kit Automotive Network, Inc., Copyright ©2012
