Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Xterra > How-to's & Installation
How-to's & Installation Share your techniques with other owners.
Old 02-22-2006, 05:25 PM   #1
CMJ76
CMJ76 Normal reputation
2000 xterra 4x4 front hub assembly
Today I decided to change my rotors and brake pads.While removing the front hub assemly I broke a white plastic part that had a spring around it . The part was a round metal piece that went into the hub with a spring and a white plastic piece that the spring sat in. Does anyone know what this part is called what it does and where I can get one ? Any information would be greatly appreciated. I called Nissan and they wanted me to buy the whole hub assembly.I hope I don't have to for one part.
CMJ76 is offline   Reply With Quote
Old 02-23-2006, 08:04 AM   #2
nissandoc
nissandoc's Avatar
nissandoc Normal reputation
Re: 2000 xterra 4x4 front hub assembly
its part of the fixed cam assembly and its not available separately, only the complete hub. not the dealers fault, just the way nissan sells them. i would try salvage yard before buying new.
nissandoc is offline   Reply With Quote
Old 02-23-2006, 09:39 AM   #3
OffroadX
OffroadX Normal reputation
Send a message via AIM to OffroadX
How did you break it? Did you try to take part of it off before you removed the snap ring? It's all supposed to come off in one assembly, but the only manual-hub-swap how-to out there shows it incorrectly.
Unfortunately, it can't really be repaired. I had mine come apart on me once, and the plastic broke in two pieces and I actually did manage to wrangle the damn thing back together but it was a ROYAL pain in the butt and you're likely to break it further in the attempt.
I've recently sold off my supply of spare hubs, but I think I have an extra cam assembly I could part with. I'll try and remember to check.
Brent
When did you last check your spare tire's pressure?
OffroadX is offline   Reply With Quote
Old 02-23-2006, 06:01 PM   #4
CMJ76
Will It Do Any Damage With Out It (the Plastic Piece) ?
Old 02-23-2006, 11:09 PM   #5
OffroadX
Yeah, you should have all the guts in there, otherwise there will be considerable in/out play potential in the CV. The snap ring won't have anything to seat against.
I just looked, I don't have the spare cam assembly after all...
Old 10-16-2006, 02:50 PM   #6
chubbybubba1
chubbybubba1 Normal reputation
Do you have the spline washer that goes behind the c clip? Or does Nissan sell just the clip?
chubbybubba1 is offline   Reply With Quote
Old 10-16-2006, 09:50 PM   #7
OffroadX
Splined washer is 40219-8B400, the snap ring is available in 7 different thicknesses to set the proper CV end play, .2mm increments from 1.1mm to 2.3mm.
Old 10-17-2006, 12:48 AM   #8
chubbybubba1
Thanks Brent. Nissan has 2 on the way for me now. I just like having the part number ready, instead of trying to explain over the phone what I need.
Old 10-24-2006, 04:02 PM   #9
chubbybubba1
ok. Got the spline washer. Last thing. Before I reassembled the hub, I used a micrometer and it said the thickness of the c clip was 1.28mm. There are 7 choices of clips. My question Brent, would you go with the 1.1mm or the 1.3mm? The 1.5mm might be to thick. I think the 1.3mm, assuming my micrometer must be off just a hair. It has a self calibrating (zero out) button that I used prior to the measurement.
Thanks in advance. Mike
Old 10-24-2006, 07:57 PM   #10
OffroadX
I'd say the 1.3, though it's cheap enough to get both...
Bookmarks
Google
Web AF
