Trouble codes....
world champs
02-22-2006, 07:52 AM
Is the only way to check for trouble codes on a 2000 intrepid through a diagnostic check at a garage or one of your own hand held ODB machines? Does the 3 turns on the key and leaving in the on position work? Just wondering.
quickdraw1959
04-18-2006, 07:33 PM
Yes, Auto Zone will hook up their ODB Comp and tell you the codes for free.
akim
04-19-2006, 05:38 PM
yeah three key turns work
wafrederick
04-20-2006, 01:38 PM
The only way to check the codes on an OBD II vehicle is with a scan tool.You cannot 3 turns of the key on an OBD II vehicle,it will only work on an OBD I vehicle.Stay away from Auto Zone,they use a code reader and do not know about car computers
jamlam
04-20-2006, 10:06 PM
Hate to burst your bubble but you can use 3 turns of the key on some OBD II systems. And as long as you record the codes that is received advance using a handheld you will be able to do a little research and perhaps fix the problem yourself without several hundred dollars at the dealer.
