2000 Ford Ranger XLT-Gas Problems?frockwood2002 02-21-2006, 03:17 PM We Have a 2000 ford Ranger 4x4 with few problems. the one problem that gives me trouble is it chokes. My husband says it is water in the gas, but if that is the case it is a very picky truck because i have tried gas from all differant gas stations. When he puts heat in , it will work fine for a while till it gets low on gas then it will start choking again. The check engin light has been on several times and gone back off and when it does there is not problems. It just came back on the other day and now it is choking worse then ever. This has to be something it is progressing to. Today I filled the tank and on the way home it choked all the way up a slight incline. some one please give me an idea of what it is. I am going to change the plugs and wires but would love some input on this thing.Thanks. Lucy. Psychopete 02-21-2006, 04:28 PM We Have a 2000 ford Ranger 4x4 with few problems. the one problem that gives me trouble is it chokes. My husband says it is water in the gas, but if that is the case it is a very picky truck because i have tried gas from all differant gas stations. When he puts heat in , it will work fine for a while till it gets low on gas then it will start choking again. The check engin light has been on several times and gone back off and when it does there is not problems. It just came back on the other day and now it is choking worse then ever. This has to be something it is progressing to. Today I filled the tank and on the way home it choked all the way up a slight incline. some one please give me an idea of what it is. I am going to change the plugs and wires but would love some input on this thing.Thanks. Lucy. Beats me :). The first thing I would do, would prolly be taking it to autozone and getting the codes scanned for free. (I hopes that you'll buy replacement parts) I know some car are picky about the gas cap. If it's not completely sealed, it will run like crap. I am not sure if that is your problem, anything I've owned has been from the 90s, but one thing to try might be to retighten the gas cap when you're having issues. It would seem that when you put heat in there, maybe the cap is getting tightened a little tighter, creating a better seal. Also, the progression of it getting worse could be contributed to the seal on the fuel cap getting worse. I really honestly don't know if that rule applies to these trucks. Definately get the codes scanned, when you see the CEL come on, the computer is trying to tell you there's a problem that needs addressed. Pete 2000mudder 02-22-2006, 03:40 AM make sure you get double platinum plugs unless you go to ford and get direct replacements. i would replace fuel filter and also there is a filter on the pickup tube in the gas tank that might be getting clogged. there might even be something in the tank that is only getting caught in the filter when the fuel level gets down be the pick up tube??? Automotive Network, Inc., Copyright ©2012
