Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Camaro Discussions
Old 02-21-2006, 12:07 PM   #1
tcfco2005
tcfco2005 Normal reputation
CALLING ALL TBI GURU's
I have a 383 motor that im throwing in my car...Right now i have a 305tbi in it.
The desktopdyno said it should be making around 450-475 hp so most likely its only about 400-425 hp...the engines rpm redline will be around 6000rpm's The heads on the 383 are Dart Pro 1 heads. 200 CC intake runners, 72 CC chambers and 2.02 1.60 valves...
so what i need to know is what intake do yall think i should run and will a 454 TBI unit be enough to feed this thing or will i need to get it ported..I know i will need bigger injectors than the 454's stock ones.What exactly is the flow for tbi's...by flow i mean like on a tpi they fall on there face at upper rpms, so what about the tbi..I will also have to buy all of the chip burning things but thats another story.
1991 RS
305 T.B.I.
700-R4
tcfco2005 is offline   Reply With Quote
Old 02-21-2006, 03:24 PM   #2
Nate355RS
Nate355RS's Avatar
Nate355RS Normal reputation
Re: CALLING ALL TBI GURU's
Your going to be right on the very edge of what TBI can do, and probably a little bit over it if you make what the desktop dyno says. Cause TBI only has two injectors it's power potential is limit compared to multiport, just get the biggest injectors you can find and hope it's enough.
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Nate355RS is offline   Reply With Quote
Old 02-21-2006, 03:33 PM   #3
97cavalier
97cavalier's Avatar
97cavalier Normal reputation
the 454 injectors should do and bore the 454 intake a little bigger. should be a monster after that.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
97cavalier is offline   Reply With Quote
Old 02-21-2006, 10:55 PM   #4
Nate355RS
Nate355RS's Avatar
I reread your post and I missed a couple things. TBI can support 400-425 easily if set up right. I believe with 2 90pph injetors the max power you could possibly make would be 450-460hp, and as long as it's tuned right and given enough fuel, TBI won't have the same struggles up top as TPI. I've never tried to tune a 400hp TBI so I don't know how hard it would be, but I can imagine it would be a nightmare compared to my 305. It would be a good idea to let an expert handle it cause it'll take many many many hours to learn how to tune that beast. I think 400hp is plenty to get deep into the 12's
Old 02-21-2006, 11:55 PM   #5
Savage Messiah
Savage Messiah's Avatar
Savage Messiah Normal reputation
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Why not switch to fuel injection?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Savage Messiah is offline   Reply With Quote
Old 02-22-2006, 12:08 AM   #6
tcfco2005
TBI is FI
Thanks for the help Nate305rs...ive been reading up on eprom and burning your own chips and all that good stuff over at thirdgen.org and im buying all the equipment next week...im going to just practice with my 305 right now just to learn how to do it...And nate are you also saying that the tbi has a higher rpm range that the tpi cause thats what i thought but i couldnt find it anywhere...?
1991 RS
305 T.B.I.
700-R4
Old 02-22-2006, 06:32 AM   #7
Genopsyde
The President
Genopsyde's Avatar
Genopsyde Normal reputation
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
you'll need to change the fuel pump also, the stock TBI one is a low pressure pump.
1986 Fiero
1990 300ZX TT
1991 Camaro RS 355
1998 Tahoe 4x4
1999 F355 Spyder
Genopsyde is offline   Reply With Quote
Old 02-22-2006, 09:29 AM   #8
tcfco2005
ya i was going to throw in a tpi fuel pump..and will i need to get a fuel pressure regulator or will the jet tbi regular be enough?
1991 RS
305 T.B.I.
700-R4
Old 02-22-2006, 10:22 AM   #9
Nate355RS
Nate355RS's Avatar
It says that the Jet regulator is good up to 20 psi, if your going to push 400, depending on your injectors, you should have to be around 25 psi maybe a little less or more.
Old 02-22-2006, 07:08 PM   #10
Savage Messiah
ok, then change that to a more efficient fuel injection
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 02-22-2006, 08:14 PM   #11
Nate355RS
Nate355RS's Avatar
454 tbi and 90pph incetors cost MUCH less than "more efficient fuel injection", all you have to do is use the brain on top of your shoulders to figure it out and tune it. Even if you can't quite get the hang of it, pay someone to do it and you'll still be less than the cost of multiport. So I guess the more cost "efficient" FI would be TBI. Also EBL will be coming around soon and its baud rate will rival if not beat modern ecu's plus it'll pretty much tune your set up for you.
Old 02-22-2006, 09:18 PM   #12
tcfco2005
ya thats the main reason im sticking with tbi...cause its cheaper....less stuff for me to buy and change..
And whats this EBL stuff and how long till it comes out...i like the sound of it already...
1991 RS
305 T.B.I.
700-R4
Old 02-22-2006, 09:26 PM   #13
Genopsyde
The President
Genopsyde's Avatar
that's why i'm sticking with TBI as well, it's a lot easier and cost a lot less. I'm starting with the holley 670 which is just a bit bigger than the 454, and I think it has 75lb injectors. I won't move up to the 90lb until after I change to a bigger fuel pump.
1986 Fiero
1990 300ZX TT
1991 Camaro RS 355
1998 Tahoe 4x4
1999 F355 Spyder
Old 02-22-2006, 09:32 PM   #14
Nate355RS
Nate355RS's Avatar
Got no clue when Embedded Lockers, HUD, and the Ultimate TBI code (EBL) will be finished and ready for sale but here is the jist of it, it's a little technical starting off but it gets easier to understand as the thread goes on. http://thirdgen.org/techbb2/showthre...hreadid=321767
Old 02-22-2006, 09:57 PM   #15
Genopsyde
The President
Genopsyde's Avatar
that's just too much reading for me right now.
1986 Fiero
1990 300ZX TT
1991 Camaro RS 355
1998 Tahoe 4x4
1999 F355 Spyder
Bookmarks
Google
Web AF
