Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 02-21-2006, 10:49 AM   #1
lavaiie
lavaiie Normal reputation
1989 4.3tbi to 350
Hey guys i have a 89 s10 with a 4.3tbi auto trans. I want to swap outthe 4.3L and replace it with a 350 or maybe a 305. is there a specific year on the 350 that i can use or any? i have located a few. Can someone tell me what all do i need as far as mounts and wiring and if it is even possible? thank you!
lavaiie is offline   Reply With Quote
Old 02-22-2006, 08:21 PM   #2
stoned_pimp420
stoned_pimp420 Normal reputation
Send a message via Yahoo to stoned_pimp420
Re: 1989 4.3tbi to 350
you'll need motor mounts, the tranny will bolt directly up to the V8, you won't be able to run an A/C without some serious hell as far as fabrication. and in most cases you will need to remove the belt driven fan and replace it with an electric fan. I should know all of the details considering I've done this swap a few hundred times.
I'm back after a long mental evaluation and heavy medication!
If you can't be a good example, you can always be a horrible warning!
stoned_pimp420 is offline   Reply With Quote
Old 02-23-2006, 01:20 AM   #3
dmbrisket 51
dmbrisket 51's Avatar
dmbrisket 51 Normal reputation
Send a message via AIM to dmbrisket 51
well being a tbi you need the moter and mounts, youll possibly need to cut your driveshaft as ive not yet had a tranny sit in the same place, you need a dinky radiator (aftermarket) and an e fan (taurus or my preference, aftermarket again) you should get the computer from a 350, but the stroke and bore on a 4.3 is the same as a 350 and youve only got 2 injectors it will run, just not the best, your distributor and accesories, including ring gear and starter should swap over, i suggest a tranny service while your at it, and summitracing part number add-713123 (bought a shit tone of those over the years) its your moter mount, its not fun, and its not easy, but its worth it, and being a tbi, some flat top pistons and a dialed in rv cam goes good in it
dmbrisket 51 is offline   Reply With Quote
Old 02-27-2006, 10:35 AM   #4
lavaiie
thanks alot. I wanted to put some new headers on the 350. Im shopping at summit will these fit in the s10 (HED-69520) and im picking this out for the e fan FLX-365. any last suggestions or advice?...this is my first motor swap
Old 02-27-2006, 02:06 PM   #5
dmbrisket 51
yeah, do manifolds not headders, unless you want to seal them up every 4 to 6 months
Bookmarks
Google
Web AF
