99 Ranger Serpentine Belt
ledhedsymbols
02-21-2006, 04:53 AM
I'm in the process of taking care of a few regular maintenance items. I replaced my 1983 Subaru Brat (just took too much energy to keep it on the road) with a 99 Ranger XLT styleside W/ offroad pkg and 3.0 V6. I removed the serpentine belt for replacement, and I can't get the new one on. I have never dealt with a belt this difficult to replace. I've checked and rechecked my belt routing against the diagram to verify it is correct. I only need about 1/4 inch more. I'm sure that I am bottoming out the tensioner. Is there some sort of trick that is unique to this vehicle that I don't know about?
Thanks in advance,
Micah
2000mudder
02-21-2006, 02:25 PM
you could have easilly got the wrong belt from the parts store. double check part number. is it possible it is not sitting in the groves correctlly?
ledhedsymbols
02-21-2006, 06:37 PM
I thought that was the case initially, so I went to the ford dealer and shelled out 35 bucks for the motorcraft belt. I'm sure it's the right one. I also checked and rechecked the pulleys to make sure it was lying in the correct grooves. Any other thoughts?
Micah
2000mudder
02-22-2006, 03:31 AM
cant think of anything else. i replaced mine and had no problems at all. sorry
ledhedsymbols
02-23-2006, 11:47 AM
Success!!! I'm not sure if it is something particular to the 3.0 Flex-Fuel engine, but I had to call a friend over for another set of hands. Then I loosened the mounting bolts for the alternator and AC compressor. Then I routed the belt, lubed up the idler pulley with a little bit of dish soap, had my buddy crank down on the tensioner, and it slid right under the pulley with just a little coaxing.
Micah
