Mysterious Coolant Leakmajk 02-19-2006, 09:12 PM HAY I have JIMMY 1998 and today my wife going i n the shoping When sheis back i take lok outside, and i se some litl coolant under the radiator pump and transmision on the ground. I start the engine and goin under the vehicle and i se weth the transmision and transfer case. is small collant on them I cant see where is the leak I wase going driving araund,and when i come back, i park in diferent place. I turn the engine of, and i cant see nothing After 5 minuts i wase look again and i see again coolant under the same place on the ground. Whats the problem, weather pump, incase gasket or head gasket Any ideas Thanks rlith 02-20-2006, 06:57 AM More than likely it's coming from the weep hole on the waterpump which indicates impending failure of the pump. majk 02-20-2006, 03:52 PM ok I wase going to the mehanic, and when he open the hod and poll up the jimmy, he found the problem lek. Is intake gaskets broken THANKS ANYWAY Automotive Network, Inc., Copyright ©2012
