N-Body Trouble Codes
Ridenour
02-19-2006, 07:36 PM
Hey guys; per the suggestions of our members, here's a thread for all the trouble codes for our vehicles. This is something that people run into lots; and they have the code, but don't always know what it means or where to find out. So if you guys have codes, post em up. Here's some to start (courtesy of Hoags):
Code Code definition
P0101........ Mass Air Flow (MAP) sensor error
P0102........ Mass Air Flow (MAP) sensor circuit - low frequency detected
P0103........ Mass Air Flow (MAP) sensor - high frequency detected
P0106........ Manifold Absolute Pressure (MAP) sensor performance fault
P0107........ Manifold Absolute Pressure (MAP) sensor circuit low input
P0108........ Manifold Absolute Pressure (MAP) sensor circuit high input
P0112........ Intake Air Temperature (IAT) sensor circuit low input
P0113........ Intake Air Temperature (IAT) sensor circuit high input
P0117........ Engine Coolant Temperature (ECT) sensor circuit - low input
P0118........ Engine Coolant Temperature (ECT) sensor circuit - high input
P0121........ Throttle Position Sensor (TPS) range/performance fault
P0122 ........ Throttle Position Sensor (TPS) circuit low input
P0123........ Throttle Position Sensor (TPS) circuit high input
P0125........ Engine Coolant Temperature (ECT) takes too long to enter closed loop
P0131........ Upstream heated O2 sensor circuit - low voltage (Bank 1, Sensor 1)
P0132........ Upstream heated O2 sensor circuit - high voltage (Bank 1, Sensor 1)
P0133........ Upstream heated O2 sensor slow response (lazy sensor) (Bank 1, Sensor 1)
P0134........ Upstream heated O2 sensor insufficient activity (Bank 1, Sensor 1)
P0135........ Upstream heated O2 sensor - heater circuit fault (Bank 1, Sensor 1)
P0137........ Downstream heated O2 sensor circuit - low voltage (Bank 1, Sensor 2)
P0138........ Downstream heated O2 sensor circuit high voltage (Bank 1, Sensor 2)
P0140........ Downstream heated O2 sensor insufficient activity (Bank 1, Sensor 2)
P0141........ O2 sensor heater circuit fault (Bank 1, Sensor 2)
P0171........ System Adaptive fuel too lean
P0172........ System Adaptive fuel too rich
P0191........ Injector Pressure sensor system performance
P0192........ Injector Pressure sensor circuit low input
P0193........ Injector Pressure sensor circuit high input
P0300........ Cylinder misfire detected (random)
P0301........ Cylinder number 1 misfire detected
P0302........ Cylinder number 2 misfire detected
P0303........ Cylinder number 3 misfire detected
P0304........ Cylinder number 4 misfire detected
P0305........ Cylinder number 5 misfire detected
P0306........ Cylinder number 6 misfire detected
P0321........ Crankshaft Position sensor circuit fault
P0325........ Knock sensor circuit fault
P0326........ Knock sensor circuit performance
P0327........ Knock sensor noise channel - low voltage
P0335........ Crankshaft Position sensor circuit
P0336........ Crankshaft reference signal circuit
P0341........ Camshaft Position sensor circuit
P0342........ Camshaft Position sensor circuit
P0401........ Exhaust Gas Recirculation (EGR) system flow insufficient
P0420........ Three Way Catalyst (TWC) system - low efficiency
P0441........ EVAP system - no flow during purge cycle
P0351........ COP ignition coil 1 primary circuit fault
P0352........ COP ignition coil 2 primary circuit fault
P0353........ COP ignition coil 3 primary circuit fault
P0354........ COP ignition coil 4 primary circuit fault
P0400........ EGR flow fault
P0401........ EGR insufficient flow detected
P0402........ EGR excessive flow detected
P0420........ Catalyst system efficiency below threshold (Bank 1)
P0421 ........ Catalyst system efficiency below threshold (Bank 1)
P0430........ Catalyst system efficiency below threshold (Bank 2)
P0431 ........ Catalyst system efficiency below threshold (Bank 2)
P0441 ........ EVAP incorrect purge flow
P0443........ EVAP VMV circuit fault
P0452........ EVAP fuel tank pressure sensor low input
P0453........ EVAP fuel tank pressure sensor high input
P0502........ VSS circuit low input
P0503........ VSS circuit range performance
P0506........ IAC system rpm lower than expected
P0507........ IAC system rpm higher than expected
P0530........ A/C refrigerant pressure sensor circuit
P0560........ System voltage out of range
P0600........ PCM serial data communication link fault
P0601 ........ PCM memory problem
P0602........ PCM control module programming error
P0650........ Quad driver module circuit
P0703........ TCC brake switch input circuit fault
P0705........ Transaxle Range sensor circuit malfunction
P0706........ Transaxle Range sensor performance
P0712........ Transaxle fluid temperature sensor circuit low input
P0713........ Transaxle fluid temperature sensor circuit high input
P0740........ TCC circuit fault
P0755........ Shift solenoid circuit fault
And here's some two-digit ones:
12........... Diagnostic mode
13 ........... Oxygen sensor or circuit
14 ........... Coolant sensor or circuit/high temperature indicated
15 ........... Coolant sensor or circuit/low temperature indicated
16 ........... System voltage out of range
19 ........... Crankshaft position sensor or circuit
21 ........... Throttle Position Sensor (TPS) or circuit - voltage high
22 ........... Throttle Position Sensor (TPS) or circuit - voltage low
23 ........... Mixture Control (M/C) solenoid or circuit (carbureted models)
23 ........... Manifold Air Temperature (MAT) sensor or circuit (1990 and earlier models)
23 ........... Intake Air Temperature (IAT) sensor circuit (fuel-injected models)
24........... Vehicle Speed Sensor (VSS) or circuit
25 ........... Manifold Air Temperature (MAT) sensor or circuit - high temperature indicated (1990 and earlier r
25 ........... Intake Air Temperature (IAT) sensor or circuit - high temperature indicated (1991 and later model
26 ........... Quad Driver module circuit
27 ........... Quad Driver module circuit
28 ........... Quad Driver module circuit
29 ........... Quad Driver module circuit
31 ........... Park/Neutral Position (PNP) switch circuit
32 ........... BARO sensor or circuit (carbureted models)
32 ........... EGR circuit (fuel-injected models)
33 ........... Manifold Absolute Pressure (MAP) sensor signal voltage high
33 ........... Mass Air Flow (MAP) sensor or circuit - excessive airflow indicated
34 ........... Manifold Absolute Pressure (MAP) sensor signal voltage low
34........... Mass Air Flow (MAF) sensor signal - low airflow indicated
35........... Idle Speed Control (ISC) switch or circuit (shorted) (carbureted models)
35 ........... Idle Air Control (IAC) valve or circuit
38........... Brake switch circuit
39........... Torque Converter Clutch (TCC) circuit
41 ........... No distributor signals to ECM, or faulty ignition module (carbureted models)
41 ........... Cylinder select error - MEM-CAL or ECM problem (fuel-injected models)
41 ........... Cam sensor circuit (3.8L engine)
42 ........... Bypass or Electronic Spark Timing (EST) circuit
43 ........... Low voltage at ECM terminal L (carbureted models)
43 ........... Knock sensor circuit
44 ........... Oxygen sensor or circuit - lean exhaust detected
45 ........... Oxygen sensor or circuit - rich exhaust detected
46 ........... Power steering pressure switch circuit
48........... Misfire diagnosis
51 ........... PROM, MEM-CAL or ECM problem
52 ........... CALPAK or ECM problem
53 ........... EGR fault (carbureted models only)
53 ........... System over-voltage (ECM over 17.7 volts)
54........... Mixture Control (M/C) solenoid or circuit (carbureted models)
54 ........... Fuel pump circuit (1986 and later models)
55 ........... Oxygen sensor circuit or ECM
55 ........... Fuel lean monitor (2.2L engine)
61 ........... Oxygen Sensor Signal Faulty (possible contaminated sensor)
62 ........... Transaxle gear switch signal circuits
63 ........... Manifold Absolute Pressure (MAP) sensor voltage high (low vacuum detected)
64 ........... Manifold Absolute Pressure (MAP) sensor voltage low (high vacuum detected)
66 ........... Air conditioning pressure sensor or circuit
That's all we've got for now... if there's more, bring em on!
Hoags
02-21-2006, 05:00 AM
I am glad to see this thread, but Sir Ridenour did not have to give me the credit, This is something that will help out all of the members.
To all GA Forum Members, please add any newer codes if there are new ones. I pulled these codes from my manual that goes up to the 1998 model. If there are more codes it will only benefit all of the members to have a complete listing.
Thanks,
Hoags
Thanks,
Hoags
Khemical
06-10-2006, 07:27 PM
Found the powertrain codes for GM models newer than 98
(long list)
P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1
P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2
P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1
P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM)
P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM)
P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2
P0068 - Throttle Body Airflow Performance (PCM)
P0100 - MAF Sensor Circuit Insufficient Activity
P0101 - Mass Air Flow (MAF) Sensor Performance
P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency
P0104 - Mass Air Flow Circuit Intermittent
P0105 - MAP Sensor Circuit Insufficient Activity
P0106 - Manifold Absolute Pressure (MAP) System Performance
P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0108 - Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0109 - Manifold Absolute Pressure Circuit Intermittent
P0110 - Intake Air Temperature (IAT) Sensor Circuit
P0111 - Intake Air Temperature (IAT) Sensor Performance
P0112 - Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0114 - Intake Air Temperature Circuit Intermittent
P0115 - Engine Coolant Temperature (ECT) Sensor Circuit
P0116 - Engine Coolant Temperature (ECT) Sensor Performance
P0117 - Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
P0118 - Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
P0119 - Engine Coolant Temperature Circuit Intermittent
P0120 - TP System Performance
P0121 - TP Sensor Circuit Insufficient Activity
P0122 - Throttle Position (TP) Sensor Circuit Low Voltage
P0123 - Throttle Position (TP) Sensor Circuit High Voltage
P0124 - Throttle Position Sensor 1 Circuit Intermittent
P0125 - Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
P0126 - Insufficient ECT for Stable Operation
P0128 - Coolant Thermostat Below Thermostat Regulating Temperature
P0130 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
P0131 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
P0132 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1
P0133 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
P0134 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1
P0136 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2
P0137 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
P0138 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2
P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2
P0140 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
P0141 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 2
P0142 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 3
P0143 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 3
P0144 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 3
P0145 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 Slow Response
P0146 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 3
P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3
P0150 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
P0151 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0152 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
P0153 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
P0154 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
P0155 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 1
P0156 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 2
P0157 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
P0158 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2
P0159 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 2
P0160 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
P0161 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 2
P0162 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3
P0163 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Low Voltage
P0164 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 High Voltage
P0165 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Slow Response
P0166 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 No Activity Detected
P0167 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 3
P0169 - Fuel Composition Sensor
P0170 - Fuel Trim Bank 1
P0171 - Fuel Trim System Lean Bank 1
P0172 - Fuel Trim System Rich Bank 1
P0173 - Fuel Trim Bank 2
P0174 - Fuel Trim System Lean Bank 2
P0175 - Fuel Trim System Rich Bank 2
P0176 - Fuel Composition Sensor Circuit
P0177 - Fuel Composition Sensor Circuit Performance
P0178 - Fuel Composition Sensor Circuit Low Voltage
P0179 - Fuel Composition Sensor Circuit High Voltage
P0180 - Fuel Temperature Sensor 1 Circuit
P0181 - Fuel Temp. Sensor 1 Circuit Performance
P0182 - Fuel Temperature Sensor Circuit Low Voltage
P0183 - Fuel Temperature Sensor Circuit High Voltage
P0184 - Fuel Temperature Sensor 1 Circuit Intermittent
P0185 - Fuel Temperature Sensor 2 Circuit
P0186 - Fuel Temp. Sensor 2 Circuit Performance
P0187 - Fuel Temperature Sensor 2 Circuit Low Voltage
P0188 - Fuel Temperature Sensor 2 Circuit High Voltage
P0189 - Fuel Temperature Sensor 2 Circuit Intermittent
P0190 - Fuel Rail Pressure Sensor Circuit
P0191 - Fuel Rail Pressure Sensor Circuit Performance
P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage
P0193 - Fuel Rail Pressure Sensor Circuit High Voltage
P0194 - Fuel Rail Pressure Sensor Circuit Intermittent
P0195 - Engine Oil Temperature Sensor
P0196 - Engine Oil Temperature Sensor Performance
P0197 - Engine Oil Temperature Sensor Low Voltage
P0198 - Engine Oil Temperature Sensor High Voltage
P0199 - Engine Oil Temperature Sensor Intermittent
P0200 - Injector Control Circuit
P0201 - Injector 1 Control Circuit
P0202 - Injector 2 Control Circuit
P0203 - Injector 3 Control Circuit
P0204 - Injector 4 Control Circuit
P0205 - Injector 5 Control Circuit
P0206 - Injector 6 Control Circuit
P0207 - Injector 7 Control Circuit
P0208 - Injector 8 Control Circuit
P0209 - Injector 9 Control Circuit
P0210 - Injector 10 Control Circuit
P0211 - Injector 11 Control Circuit
P0212 - Injector 12 Control Circuit
P0213 - Cold Start Injector 1
P0214 - Cold Start Injector 2
P0215 - Engine Shutoff Control Circuit
P0216 - Injection Timing Control Circuit
P0217 - Engine Overtemp Condition
P0218 - Transmission Fluid Overtemperature
P0219 - Engine Overspeed Condition
P0220 - APP Sensor 2 Circuit
P0221 - APP (Throttle Position) Sensor 2 Circuit Performance
P0222 - APP (Throttle Position) Sensor 2 Circuit Low Voltage
P0223 - APP (Throttle Position) Sensor 2 Circuit High Voltage
P0224 - Throttle Position Sensor 2 Intermittent
P0225 - APP Sensor 3 Circuit
P0226 - APP Sensor 3 Circuit Performance
P0227 - APP Sensor 3 Circuit Low Voltage
P0228 - APP Sensor 3 Circuit High Voltage
P0229 - Throttle Position Sensor 3 Intermittent
P0230 - Fuel Pump Relay Control Circuit
P0231 - Fuel Pump Feedback Circuit Low Voltage
P0232 - Fuel Pump Feedback Circuit High Voltage
P0233 - Fuel Pump Secondary Circuit Intermittent
P0234 - Turbocharger Engine Overboost Condition
P0235 - Turbocharger Boost Sensor 1 Circuit
P0236 - Turbocharger Boost System
P0237 - Turbocharger Boost Sensor Circuit Low Voltage
P0238 - Turbocharger Boost Sensor Circuit High Voltage
P0239 - Turbocharger Boost Sensor 2 Circuit
P0240 - Turbocharger Boost Sensor 2 Performance
P0241 - Turbocharger Boost Sensor 2 Circuit Low Voltage
P0242 - Turbocharger Boost Sensor 2 Circuit High Voltage
P0243 - Turbocharger Wastegate Solenoid 1
P0244 - Turbocharger Wastegate Solenoid 1 Performance
P0245 - Turbocharger Wastegate Solenoid 1 Low Voltage
P0246 - Turbocharger Wastegate Solenoid 1 High Voltage
P0247 - Turbocharger Wastegate Solenoid 2
P0248 - Turbocharger Wastegate Solenoid 2 Performance
P0249 - Turbocharger Wastegate Solenoid 2 Low Voltage
P0250 - Turbocharger Wastegate Solenoid 2 High Voltage
P0251 - Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 - Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 - Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 - Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 - Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 - Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 - Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 - Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 - Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 - Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 - Cylinder 1 Injector Circuit Low
P0262 - Cylinder 1 Injector Circuit High
P0263 - Cylinder 1 Contribution/Balance Fault
P0264 - Cylinder 2 Injector Circuit Low
P0265 - Cylinder 2 Injector Circuit High
P0266 - Cylinder 2 Contribution/Balance Fault
P0267 - Cylinder 3 Injector Circuit Low
P0268 - Cylinder 3 Injector Circuit High
P0269 - Cylinder 3 Contribution/Balance Fault
P0270 - Cylinder 4 Injector Circuit Low
P0271 - Cylinder 4 Injector Circuit High
P0272 - Cylinder 4 Contribution/Balance Fault
P0273 - Cylinder 5 Injector Circuit Low
P0274 - Cylinder 5 Injector Circuit High
P0275 - Cylinder 5 Contribution/Balance Fault
P0276 - Cylinder 6 Injector Circuit Low
P0277 - Cylinder 6 Injector Circuit High
P0278 - Cylinder 6 Contribution/Balance Fault
P0279 - Cylinder 7 Injector Circuit Low
P0280 - Cylinder 7 Injector Circuit High
P0281 - Cylinder 7 Contribution/Balance Fault
P0282 - Cylinder 8 Injector Circuit Low
P0283 - Cylinder 8 Injector Circuit High
P0284 - Cylinder 8 Contribution/Balance Fault
P0285 - Cylinder 9 Injector Circuit Low
P0286 - Cylinder 9 Injector Circuit High
P0287 - Cylinder 9 Contribution/Balance Fault
P0288 - Cylinder 10 Injector Circuit Low
P0289 - Cylinder 10 Injector Circuit High
P0290 - Cylinder 10 Contribution/Balance Fault
P0291 - Cylinder 11 Injector Circuit Low
P0292 - Cylinder 11 Injector Circuit High
P0293 - Cylinder 11 Contribution/Balance Fault
P0294 - Cylinder 12 Injector Circuit Low
P0295 - Cylinder 12 Injector Circuit High
P0296 - Cylinder 12 Contribution/Range Fault
P0300 - Engine Misfire Detected
P0301 - Cylinder 1 Misfire Detected
P0302 - Cylinder 2 Misfire Detected
P0303 - Cylinder 3 Misfire Detected
P0304 - Cylinder 4 Misfire Detected
P0305 - Cylinder 5 Misfire Detected
P0306 - Cylinder 6 Misfire Detected
P0307 - Cylinder 7 Misfire Detected
P0308 - Cylinder 8 Misfire Detected
P0309 - Cylinder 9 Misfire Detected
P0310 - Cylinder 10 Misfire Detected
P0311 - Cylinder 11 Misfire Detected
P0312 - Cylinder 12 Misfire Detected
P0313 - Misfire Detected With Low Fuel Level
P0315 - Crankshaft position (CKP) system variation values are not stored in the PCM memory
P0318 - Rough Road Sensor Circuit
P0320 - Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 - Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 - IC Module 4X Reference Circuit No Frequency
P0323 - Ignition/Distributor Engine Speed Input Circuit Intermittent
P0324 - Knock Sensor (KS) Module Performance
P0325 - PCM Knock Sensor Circuit
P0326 - Knock Sensor Circuit Excessive Spark Retard
P0327 - Knock Sensor Circuit Low Voltage
P0328 - Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 - Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 - Knock Sensor (KS) Circuit Bank 2
P0331 - Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 - Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 - Knock Sensor 2 Circuit High Input (Bank 2)
P0334 - Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 - CKP Sensor A Circuit Performance
P0336 - Crankshaft Position (CKP) Sensor A Performance
P0337 - Crankshaft Position (CKP) Sensor Circuit Low Duty Cycle
P0338 - Crankshaft Position (CKP) Sensor Circuit High Duty Cycle
P0339 - Crankshaft Position (CKP) Sensor Circuit Intermittent
P0340 - Camshaft Position (CMP) Sensor Circuit
P0341 - Camshaft Position (CMP) Sensor Performance
P0342 - Camshaft Position Sensor Circuit Low Input
P0343 - Camshaft Position Sensor Circuit High Input
P0344 - Camshaft Position Sensor Circuit Intermittent
P0350 - Ignition Coil Primary/Secondary Circuit Malfunction
P0351 - Ignition Coil 1 Control Circuit
P0352 - Ignition Coil 2 Control Circuit
P0353 - Ignition Coil 3 Control Circuit
P0354 - Ignition Coil 4 Control Circuit
P0355 - Ignition Coil 5 Control Circuit
P0356 - Ignition Coil 6 Control Circuit
P0357 - Ignition Coil 7 Control Circuit
P0358 - Ignition Coil 8 Control Circuit
P0359 - Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 - Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 - Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 - Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 - Timing Reference High Resolution Signal A Malfunction
P0371 - IC 24X Reference Circuit Too Many Pulses
P0372 - IC 24X Reference Circuit Missing Pulses
P0373 - Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 - Timing Reference High Resolution Signal A No Pulses
P0375 - Timing Reference High Resolution Signal B Malfunction
P0376 - Timing Reference High Resolution Signal B Too Many Pulses
P0377 - Timing Reference High Resolution Signal B Too Few Pulses
P0378 - Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 - Timing Reference High Resolution Signal B No Pulses
P0380 - Glow Plug/Heater Circuit "A" Malfunction
P0381 - Glow Plug/Heater Indicator Circuit Malfunction
P0382 - Exhaust Gas Recirculation Flow Malfunction
P0385 - Crankshaft Position (CKP) Sensor B Circuit
P0386 - Crankshaft Position (CKP) Sensor B Performance
P0387 - Crankshaft Position Sensor B Circuit Low Input
P0388 - Crankshaft Position Sensor B Circuit High Input
P0389 - Crankshaft Position Sensor B Circuit Intermittent
P0400 - Exhaust Gas Recirculation Flow Malfunction
P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient
P0402 - Exhaust Gas Recirculation Flow Excessive Detected
P0403 - Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
P0404 - Exhaust Gas Recirculation (EGR) Open Position Performance
P0405 - Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
P0406 - Exhaust Gas Recirculation Sensor A Circuit High
P0407 - Exhaust Gas Recirculation Sensor B Circuit Low
P0408 - Exhaust Gas Recirculation Sensor B Circuit High
P0410 - Secondary Air Injection (AIR) System
P0411 - Secondary Air Injection (AIR) System
P0412 - Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1
P0413 - Secondary Air Injection System Switching Valve A Circuit Open
P0414 - Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 - Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 - Secondary Air Injection System Switching Valve B Circuit Open
P0417 - Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1
P0419 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 2
P0420 - Catalyst System Low Efficiency
P0421 - Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 - Catalyst System Low Efficiency Bank 1
P0423 - Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 - Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 - Catalyst System Low Efficiency Bank 2
P0431 - Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 - Catalyst System Low Efficiency Bank 2
P0433 - Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 - Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 - Evaporative Emission (EVAP) System
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P0442 - Evaporative Emission (EVAP) System Small Leak Detected
P0443 - EVAP Purge Solenoid Valve 1 Control Circuit
P0444 - Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 - EVAP Vent Solenoid Valve Control System
P0447 - Evaporative Emission Control System Vent Control Circuit Open
P0448 - Evaporative Emission Control System Vent Control Circuit Shorted
P0449 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P0450 - Fuel Tank Pressure Sensor Circuit
P0451 - Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage
P0453 - Fuel Tank Pressure Sensor Circuit High Voltage
P0454 - Evaporative Emission Control System Pressure Sensor Intermittent
P0455 - Evaporative Emission (EVAP) System Leak Detected
P0460 - Fuel Level Sensor Circuit
P0461 - Fuel Level Sensor Performance
P0462 - Fuel Level Sensor Circuit Low Voltage
P0463 - Fuel Level Sensor Circuit High Voltage
P0464 - Fuel Level Sensor Circuit Intermittent
P0465 - Purge Flow Sensor Circuit Malfunction
P0466 - Purge Flow Sensor Circuit Range/Performance
P0467 - Purge Flow Sensor Circuit Low Input
P0468 - Purge Flow Sensor Circuit High Input
P0469 - Purge Flow Sensor Circuit Intermittent
P0470 - Exhaust Pressure Sensor Malfunction
P0471 - Exhaust Pressure Sensor Range/Performance
P0472 - Exhaust Pressure Sensor Low
P0473 - Exhaust Pressure Sensor High
P0474 - Exhaust Pressure Sensor Intermittent
P0475 - Exhaust Pressure Control Valve Malfunction
P0476 - Exhaust Pressure Control Valve Range/Performance
P0477 - Exhaust Pressure Control Valve Low
P0478 - Exhaust Pressure Control Valve High
P0479 - Exhaust Pressure Control Valve Intermittent
P0480 - Cooling Fan Relay 1 Control Circuit
P0481 - Cooling Fan Relay 2 Control Circuit
P0482 - Cooling Fan 3 Control Circuit Malfunction
P0483 - Cooling Fan Rationality Check Malfunction
P0484 - Cooling Fan Circuit Over Current
P0485 - Cooling Fan Power/Ground Circuit Malfunction
P0496 - Evaporative Emission (EVAP) System Flow During Non-Purge
P0500 - Vehicle Speed Sensor (VSS) Circuit
P0501 - Vehicle Speed Sensor Range/Performance
P0502 - Vehicle Speed Sensor (VSS) Circuit Low Input
P0503 - Vehicle Speed Sensor (VSS) Circuit Intermittent
P0505 - Idle Control System Malfunction
P0506 - Idle Speed Low
P0507 - Idle Speed High
P0510 - Closed Throttle Position Switch Malfunction
P0512 - Start Switch Circuit
P0520 - Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 - Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 - Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 - Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0526 - Cooling Fan Speed Sensor Circuit
P0530 - A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 - A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
P0533 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
P0534 - Air Conditioner Refrigerant Charge Loss
P0550 - Power Steering Pressure (PSP) Switch Circuit
P0551 - Power Steering Pressure Sensor Circuit Range/Performance
P0552 - Power Steering Pressure Sensor Circuit Low Input
P0553 - Power Steering Pressure Sensor Circuit High Input
P0554 - Power Steering Pressure Sensor Circuit Intermittent
P0560 - System Voltage
P0561 - System Voltage Unstable
P0562 - System Voltage Low (TCM)
P0563 - System Voltage High (TCM)
P0564 - Cruise Control Multi-Function Switch Circuit (PCM)
P0565 - Cruise Control On Signal Malfunction
P0566 - Cruise Control Off Signal Malfunction
P0567 - Cruise Control Resume Signal Malfunction
P0568 - Cruise Control Set Signal Malfunction
P0569 - Cruise Control Coast Signal Malfunction
P0570 - Cruise Control Accel Signal Malfunction
P0571 - Cruise Control Brake Switch Circuit
P0573 - Cruise Control/Brake Switch A Circuit High
P0574 - Vehicle Speed Too High - above 110 mph - Cruise Control Disabled
P0575 - Cruise Control Related Malfunction
P0576 - Cruise Control Related Malfunction
P0578 - Cruise Control Related Malfunction
P0579 - Cruise Control Related Malfunction
P0580 - Cruise Control Related Malfunction
P0600 - Serial Communication Link Malfunction
P0601 - Control Module Read Only Memory (ROM)
P0602 - Control Module Not Programmed
P0603 - Control Module Long Term Memory Reset
P0604 - Control Module Random Access Memory (RAM)
P0605 - Control Module Programming Read Only Memory (ROM)
P0606 - Control Module Internal Performance
P0607 - ECU Malfunction
P0608 - Control Module VSS Output "A" Malfunction
P0609 - Control Module VSS Output "B" Malfunction
P0610 - Control Module Vehicle Options Incorrect
P0615 - Starter Relay Control Circuit
P0616 - Starter Relay Control Circuit Low Voltage
P0617 - Starter Relay Control Circuit High Voltage
P0620 - Generator Control Circuit Malfunction
P0621 - Generator L-Terminal Circuit
P0622 - Generator F-Terminal Circuit
P0625 - Generator F-Terminal Circuit Low Voltage
P0626 - Generator F-Terminal Circuit High Voltage
P0628 - Fuel Pump Relay Control Circuit Low Voltage
P0629 - Fuel Pump Relay Control Circuit High Voltage
P0638 - Throttle Actuator Control (TAC) Command Performance
P0641 - PCM voltage out of tolerance condition on the 5-volt reference circuit
P0645 - Air Conditioning (A/C) Clutch Relay Control Circuit
P0646 - Air Conditioning (A/C) Clutch Relay Control Circuit
P0647 - Air Conditioning (A/C) Clutch Relay Control Circuit
P0650 - Malfunction Indicator Lamp (MIL) Control Circuit
P0651 - PCM voltage out of tolerance condition on the 5-volt reference circuit
P0654 - Engine RPM Output Circuit Malfunction
P0655 - Engine Hot Lamp Output Control Circuit Malfucntion
P0656 - Fuel Level Output Circuit Malfunction
P0660 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit
P0661 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit Low Voltage
P0662 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit High Voltage
P0685 - Engine Controls Ignition Relay Control Circuit (PCM)
P0691 - Cooling Fan Relay Control Circuit Low Voltage
P0693 - Cooling Fan Relay Control Circuit Low Voltage
P0692 - Cooling Fan Relay Control Circuit High Voltage
P0694 - Cooling Fan Relay Control Circuit High Voltage
P0700 - Transmission Control System Malfunction
P0701 - Transmission Control System Range/Performance
P0702 - Transmission Control System Electrical
P0703 - Brake Switch Circuit Malfunction
P0704 - Clutch Switch Input Circuit Malfunction
P0705 - Trans Range Switch Circuit
P0706 - Trans Range Switch Performance
P0707 - Transmission Range Sensor Circuit Low Input
P0708 - Transmission Range Sensor Circuit High Input
P0709 - Transmission Range Sensor Circuit Intermittent
P0710 - Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 - TFT Sensor Circuit Range/Performance
P0712 - Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
P0713 - Transmission Fluid Temperature (TFT) Sensor Circuit High Input
P0714 - Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 - Input/Turbine Speed Sensor Circuit Malfunction
P0716 - Input Speed Sensor Circuit Intermittent
P0717 - Input Speed Sensor Circuit Low Input
P0718 - Input/Turbine Speed Sensor Circuit Intermittent
P0719 - Brake Switch Circuit Low Input
P0720 - Output Speed Sensor Circuit Malfunction
P0721 - Output Speed Sensor Range/Performance
P0722 - Output Speed Sensor Circuit Low Input
P0723 - Output Speed Sensor Intermittent
P0724 - Brake Switch Circuit High Input
P0725 - Engine Speed Input Circuit
P0726 - Engine Speed Input Circuit Range/Performance
P0727 - Engine Speed Circuit No Signal
P0728 - Engine Speed Input Circuit Intermittent
P0730 - Incorrect Gear Ratio
P0731 - Incorrect 1st Gear Ratio
P0732 - Incorrect 2nd Gear Ratio
P0733 - Incorrect 3rd Gear Ratio
P0734 - Incorrect 4th Gear Ratio
P0735 - Gear 5 Incorrect ratio
P0736 - Reverse incorrect gear ratio
P0740 - TCC Enable Solenoid Circuit Electrical
P0741 - TCC System Stuck Off
P0742 - TCC System Stuck On
P0743 - TCC Enable Solenoid Circuit Electrical
P0744 - Torque Converter Clutch Circuit Intermittent
P0745 - Pressure Control Solenoid Malfunction
P0746 - Pressure Control Solenoid Performance or Stuck Off
P0747 - Pressure Control Solenoid Stuck On
P0748 - Pressure Control Solenoid Circuit Electrical
P0749 - Pressure Control Solenoid Intermittent
P0750 - Shift Solenoid A Malfunction
P0751 - 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear
P0752 - 1-2 Shift Solenoid Valve Performance - No Second or Third Gear
P0753 - 1-2 Shift Solenoid Circuit Electrical
P0754 - Shift Solenoid A Intermittent
P0755 - Shift Solenoid B Malfunction
P0756 - 2-3 Shift Solenoid Valve Performance - No First or Second Gear
P0757 - 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear
P0758 - 2-3 Shift Solenoid Circuit Electrical
P0759 - Shift Solenoid B Intermittent
P0760 - Shift Solenoid C Malfunction
P0761 - Shift Solenoid C Performance or Stuck Off
P0762 - Shift Solenoid C Stuck On
P0763 - Shift Solenoid C Electrical
P0764 - Shift Solenoid C Intermittent
P0765 - Shift Solenoid D Malfunction
P0766 - Shift Solenoid D Performance or Stuck Off
P0767 - Shift Solenoid D Stuck On
P0768 - Shift Solenoid D Electrical
P0769 - Shift Solenoid D Intermittent
P0770 - Shift Solenoid E Malfunction
P0771 - Shift Solenoid E Performance or Stuck Off
P0772 - Shift Solenoid E Stuck On
P0773 - Shift Solenoid E Electrical
P0774 - Shift Solenoid E Intermittent
P0780 - Shift Malfunction
P0781 - 1-2 Shift Malfunction
P0782 - 2-3 Shift Malfunction
P0783 - 3-4 Shift Malfunction
P0784 - 4-5 Shift Malfunction
P0785 - 3-2 Shift Solenoid Circuit Electrical
P0786 - Shift/Timing Solenoid Range/Performance
P0787 - Shift/Timing Solenoid Low
P0788 - Shift/Timing Solenoid High
P0789 - Shift/Timing Solenoid Intermittent
P0790 - Normal/Performance Switch Circuit Malfunction
P0801 - Reverse Inhibit Control Circuit Malfunction
P0803 - 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 - 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P0850 - Park/Neutral Position (PNP) Switch Circuit
P0856 - Powertrain Indicated Traction Control Malfunction
P0894 - Transmission Component Slipping
P0897 - PCM detects a calculated transmission fluid life of 10 percent or less
P0962 - Line Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM)
P0963 - Line Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM)
P0966 - Clutch Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM)
P0967 - Clutch Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM)
P0970 - Shift Pressure control (PC) Solenoid Control Circuit Low Voltage (TCM)
P0971 - Shift Pressure Control (PC) Solenoid Control High Voltage (TCM)
P0973 - PCM detects an open or short to ground in the 1-2 SS valve circuit
P0974 - PCM detects a continuous short to voltage in the 1-2 SS valve circuit
P0976 - PCM detects a continuous open or short to ground in the 2-3 SS valve circuit
P0977 - PCM detects a continuous short to voltage in the 2-3 SS valve circuit
P0979 - Shift Solenoid (SS) 3 Control Circuit Low Voltage (TCM)
P0980 - Shift Solenoid (SS) 3 Control Circuit High Voltage (TCM)
P0982 - Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM)
P0983 - Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM)
P0985 - Shift Solenoid (SS) 5 Control Circuit Low Voltage (TCM)
P0986 - Shift Solenoid (SS) 5 Control Circuit High Voltage (TCM)
P1031 - Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
P1032 - Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
P1101 - Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow
P1105 - Secondary Vacuum Sensor Circuit
P1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108 - BARO to MAP Sensor Comparison Too High
P1109 - Secondary Port Throttle System
P1111 - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 - Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113 - Intake Resonance Switchover Solenoid Control Circuit
P1114 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
P1115 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
P1116 - ECT Signal Unstable or Intermittent
P1117 - Engine Coolant Temp. Signal Out-Of-Range Low
P1118 - Engine Coolant Temp. Signal Out-Of-Range High
P1119 - ECT Signal Out-Of-Range With TFT Sensor
P1120 - Throttle Position (TP) Sensor 1 Circuit
P1121 - Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122 - Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1125 - Accelerator Pedal Position (APP) System
P1130 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1
P1131 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2
P1132 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1134 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
P1135 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1
P1136 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1
P1137 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
P1138 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage
P1139 - Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2
P1140 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2
P1141 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P1143 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage
P1144 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage
P1145 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3
P1153 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P1154 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
P1155 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1
P1156 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1
P1157 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage
P1158 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage
P1159 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2
P1161 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 2 Sensor 2
P1163 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean System or Low Voltage
P1164 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Rich or High Voltage
P1165 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 3
P1170 - Bank to Bank Fuel Trim Offset
P1171 - Fuel System Lean During Acceleration
P1172 - Fuel Transfer Pump Flow Insufficient
P1185 - Engine Oil Temperature Circuit
P1186 - EOT Circuit Performance
P1187 - EOT Sensor Circuit Low Voltage
P1188 - EOT Sensor Circuit High Voltage
P1189 - Engine Oil Pressure (EOP) Switch Circuit
P1190 - Engine Vacuum Leak
P1191 - Intake Air Duct Air Leak
P1200 - Injector Control Circuit
P1201 - (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance
P1202 - (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency
P1203 - (Alt. Fuel) Gas Mass Sensor Circuit High Frequency
P1211 - Mass Air Flow Circuit Intermittent High
P1212 - Mass Air Flow Circuit Intermittent Low
P1214 - Injection Pump Timing Offset
P1215 - Ground Fault Detection Indicated
P1216 - Fuel Solenoid Response Time Too Short
P1217 - Fuel Solenoid Response Time Too Long
P1218 - Injection Pump Calibration Circuit
P1219 - Throttle Position Sensor Reference Voltage
P1220 - Throttle Position (TP) Sensor 2 Circuit
P1221 - Fuel Pump Secondary Circuit Low
P1222 - Injector Control Circuit Intermittent
P1225 - Injector Circuit Cylinder 2 Intermittent
P1228 - Injector Circuit Cylinder 3 Intermittent
P1231 - Injector Circuit Cylinder 4 Intermittent
P1234 - Injector Circuit Cylinder 5 Intermittent
P1237 - Injector Circuit Cylinder 6 Intermittent
P1240 - Injector Circuit Cylinder 7 Intermittent
P1243 - Injector Circuit Cylinder 8 Intermittent
P1245 - Intake Plenum Switchover Valve
P1250 - Early Fuel Evaporation Heater Circuit
P1257 - Supercharger System Overboost
P1258 - Engine Coolant Overtemperature - above 268°F - Protection Mode Active
P1260 - Last Test Failed Failed SCC ENTER:More Info.
P1270 - Accelerator Pedal Position Sensor A/D Converter Error
P1271 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation
P1272 - Accelerator Pedal Position Sensor 2
P1273 - "Accelerator Pedal Position Sensor 1
P1274 - Injectors Wired Incorrectly
P1275 - Accelerator Pedal Position (APP) Sensor 1 Circuit
P1276 - Accelerator Pedal Position Sensor 1 Circuit Performance
P1277 - Accelerator Pedal Position Sensor 1 Circuit Low Voltage
P1278 - Accelerator Pedal Position Sensor 1 Circuit High Voltage
P1280 - Accelerator Pedal Position (APP) Sensor 2 Circuit
P1281 - Accelerator Pedal Position Sensor 2 Circuit Performance
P1282 - Accelerator Pedal Position Sensor 2 Circuit Low Voltage
P1283 - Accelerator Pedal Position Sensor 2 Circuit High Voltage
P1285 - Accelerator Pedal Position Sensor 3 Circuit
P1286 - Accelerator Pedal Position Sensor 3 Circuit Performance
P1287 - Accelerator Pedal Position Sensor 3 Circuit Low Voltage
P1288 - Accelerator Pedal Position Sensor 3 Circuit High Voltage
P1300 - Ignitor Circuit
P1305 - Ignition Coil 2 Primary Feedback Circuit
P1310 - Ignition Coil 3 Primary Feedback Circuit
P1315 - Ignition Coil 4 Primary Feedback Circuit
P1320 - IC 4X Reference Circuit Intermittent
P1321 - Electronic Ignition System Fault Line
P1322 - EI System or Ignition Control Extra or Missing
P1323 - IC 24X Reference Circuit Low Frequency
P1324 - Crank RPM Too Low
P1335 - CKP Circuit
P1336 - Crankshaft Position (CKP) System Variation Not Learned
P1345 - Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
P1346 - Intake Camshaft Position [CMP] Sensor System Performance
P1350 - Ignition Control System
P1351 - Ignition Coil Control Circuit High Voltage
P1352 - IC Output High/Pulse Detected when GND_Cyl. 2
P1353 - IC Output High/Pulse Detected when GND_Cyl. 3
P1354 - IC Output High/Pulse Detected when GND_Cyl. 4
P1355 - IC Output High/Pulse Detected when GND_Cyl. 5
P1356 - IC Output High/Pulse Detected when GND_Cyl. 6
P1357 - IC Output High/Pulse Detected when GND_Cyl. 7
P1358 - IC Output High/Pulse Detected when GND_Cyl. 8
P1359 - Ignition Coil Group 1 Control Circuit
P1360 - Ignition Coil Group 2 Control Circuit
P1361 - Ignition Coil Control Circuit Low Voltage
P1362 - IC Cylinder 2 Not Toggling After Enable
P1363 - IC Cylinder 3 Not Toggling After Enable
P1364 - IC Cylinder 4 Not Toggling After Enable
P1365 - IC Cylinder 5 Not Toggling After Enable
P1366 - IC Cylinder 6 Not Toggling After Enable
P1367 - IC Cylinder 7 Not Toggling After Enable
P1368 - IC Cylinder 8 Not Toggling After Enable
P1370 - IC 4X Reference Circuit Too Many Pulses
P1371 - IC 4X Reference Circuit Too Few Pulses
P1372 - Crankshaft Position (CKP) Sensor A-B Correlation
P1374 - 3X Reference Circuit
P1375 - IC 24X Reference Circuit High Voltage
P1376 - Ignition Ground Circuit
P1377 - IC Cam Pulse To 4X Reference Pulse
P1380 - Misfire Detected - Rough Road Data Not Available
P1381 - Misfire Detected - No Communication with Brake Control Module
P1390 - Wheel Speed Sensor 1 - G - Sensor Circuit
P1391 - Wheel Speed Sensor 1 - G - Sensor Circuit Performance
P1392 - Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
P1393 - Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
P1394 - Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent
P1395 - Wheel Speed Sensor 2 - G - Sensor Circuit
P1396 - Wheel Speed Sensor 2 - G - Sensor Circuit Performance
P1397 - Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
P1398 - Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
P1399 - Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent
P1403 - Exhaust Gas Recirculation System Valve 1
P1404 - Exhaust Gas Recirculation (EGR) Closed Position Performance
P1405 - Exhaust Gas Recirculation System Valve 3
P1406 - EGR Valve Pintle Position Circuit
P1407 - EGR Air Intrusion in Exhaust Supply to EGR Valve
P1408 - Intake Manifold Pressure Sensor Circuit
P1409 - EGR Vacuum System Leak
P1410 - Fuel Tank Pressure System
P1415 - Secondary Air Injection (AIR) System Bank 1
P1416 - Secondary Air Injection (AIR) System Bank 2
P1418 - Secondary Air Injection System Relay A Control Circuit High
P1420 - Intake Air Low Pressure Switch Circuit Low Voltage
P1421 - Intake Air Low Pressure Switch Circuit High Voltage
P1423 - Intake Air High Pressure Switch Circuit High Voltage
P1431 - Fuel Level Sensor 2 Circuit Performance
P1432 - Fuel Level Sensor 2 Circuit Low Voltage
P1433 - Fuel Level Sensor 2 Circuit High Voltage
P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge
P1442 - EVAP Vacuum Sw. High Voltage During Ign. On
P1450 - Barometric Pressure Sensor Circuit
P1451 - Barometric Press. Sensor Performance
P1460 - Cooling Fan Control System
P1480 - Cooling Fan 1 Control Circuit High
P1481 - Cooling Fan Speed Sensor Circuit
P1482 - Cooling Fan Speed Output Circuit
P1483 - Engine Cooling System Performance
P1484 - Cooling Fan System Performance
P1500 - Starter Signal Circuit
P1501 - Theft Deterrent System
P1501 - Vehicle Speed Sensor Circuit Intermittent
P1502 - Theft Deterrent Fuel Enable Signal Not Received
P1503 - Theft Deterrent Fuel Enable Signal Not Correct
P1504 - Vehicle Speed Output Circuit
P1508 - Idle Speed Low - Idle Air Control (IAC) System Not Responding
P1509 - Idle Speed High - Idle Air Control (IAC) System Not Responding
P1510 - Throttle Control System Performance - Throttle Limitation Active
P1511 - Throttle Control System - Backup System Performance
P1514 - Airflow to TP Sensor Correlation High
P1515 - Electronic Throttle System Throttle Position
P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
P1517 - Electronic Throttle Module
P1518 - Electronic Throttle Module to PCM Communication
P1519 - Throttle Actuator Control (TAC) Module Internal Circuit
P1520 - Transmission Range Switch Circuit
P1521 - Transmission Engaged at High Throttle Angle
P1522 - Park/Neutral to Drive/Reverse at High RPM
P1523 - Throttle Closed Position Performance
P1524 - Throttle Closed Position Performance
P1525 - Throttle Body ServiceRequired
P1526 - Minimum Throttle Position Not Learned
P1527 - Transmission Range to Pressure Switch Correlation
P1528 - Governor
P1529 - Heated Windshield Request Problem
P1530 - Throttle Actuator Control (TAC) Module Internal Circuit
P1531 - A/C Low Side Temperature Sensor Fault
P1532 - A/C Evaporator Temp. Sens. Circuit Low Voltage
P1533 - A/C Evaporator Temp. Sens. Circuit High Voltage
P1534 - A/C High Side Temp. Sensor Low Voltage
P1535 - A/C High Side Temperature Sensor Circuit
P1536 - Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
P1537 - A/C Request Circuit Low Voltage
P1538 - A/C Request Circuit High Voltage
P1539 - A/C Clutch Status Circuit High Voltage
P1540 - Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
P1541 - A/C High Side Over Temperature
P1542 - A/C System High Pressure High Temperature
P1543 - A/C System Performance
P1544 - A/C Refrigerant Condition Very Low
P1545 - Air Conditioning (A/C) Clutch Relay Control Circuit
P1546 - A/C Clutch Status Circuit Low Voltage
P1547 - A/C System Performance Degraded
P1548 - A/C Recirculation Circuit
P1551 - Throttle Valve Rest Position Not Reached During Learn
P1554 - Cruise Control Feedback Circuit
P1555 - Electronic Variable Orifice Output
P1558 - Cruise Control Servo Indicates Low
P1559 - Cruise Control Power Management Mode
P1560 - Transaxle Not in Drive - Cruise Control Disabled
P1561 - Cruise Vent Solenoid
P1562 - Cruise Vacuum Solenoid
P1563 - Cruise Vehicle Speed/Set Speed Difference Too High
P1564 - Vehicle Acceleration Too High - Cruise Control Disabled
P1565 - Cruise Servo Position Sensor
P1566 - Engine RPM Too High - Cruise Control Disabled
P1567 - Active Banking Control Active - Cruise Control Disabled
P1568 - Cruise Servo Stroke Greater than Commanded in Cruise
P1569 - Cruise Servo Stroke High While not in Cruise
P1570 - Traction Control Active - Cruise Control Disabled
P1571 - Traction Control Torque Request Circuit
P1572 - ASR Active Circuit Low Too Long
P1573 - PCM/EBTCM Serial Data Circuit
P1574 - Stoplamp Switch Circuit
P1575 - Extended Travel Brake Switch Circuit
P1576 - BBV Sensor Circuit High Voltage
P1577 - BBV Sensor Circuit Low Voltage
P1578 - BBV Sensor Circuit Low Vacuum
P1579 - P/N to D/R at High Throttle Angle - Power Reduction Mode Active
P1580 - Cruise Move Circuit Low Voltage
P1581 - Cruise Move Circuit High Voltage
P1582 - Cruise Direction Circuit Low Voltage
P1583 - Cruise Direction CircuitHigh Voltage
P1584 - Cruise Control Disabled
P1585 - Cruise Control Inhibit Output Circuit
P1586 - Cruise Control Brake Switch 2 Circuit
P1587 - Cruise Control Clutch Control Circuit Low
P1588 - Cruise Control Clutch Control Circuit High
P1599 - Engine Stall or Near Stall Detected
P1600 - TCM Internal Watchdog Operation
P1601 - Serial Comm. Problem With Device 1
P1602 - Knock Sensor (KS) Module Performance
P1603 - Loss of SDM Serial Data
P1604 - Loss of IPC Serial Data
P1605 - Loss of HVAC Serial Data
P1606 - Serial Communication Problem With Device 6
P1607 - Serial Communication Problem With Device 7
P1608 - Serial Communication Problem With Device 8
P1609 - Loss Of TCS Serial Data
P1610 - Loss of PZM Serial Data
P1611 - Loss of CVRTD Serial Data
P1612 - Loss of IPM Serial Data
P1613 - Loss of DIM Serial Data
P1614 - Loss of RIM Serial Data
P1615 - Loss of VTD Serial Data
P1617 - Engine Oil Level Switch Circuit
P1619 - Engine Oil Life Monitor Reset Circuit
P1620 - Low Coolant Circuit
P1621 - Control Module Long Term Memory Performance
P1622 - Cylinder Select
P1623 - Transmission Temp Pull-Up Resistor
P1624 - Customer Snapshot Requested - Data Available
P1625 - TCM System Reset
P1626 - Theft Deterrent Fuel Enable Signal Not Received
P1627 - A/D Performance
P1628 - ECT Pull-Up Resistor
P1629 - Theft Deterrent System - Cranking Signal
P1630 - Theft Deterrent Learn Mode Active
P1631 - Theft Deterrent Start Enable Signal Not Correct
P1632 - Theft Deterrent Fuel Disable Signal Received
P1633 - Ignition 0 Switch Circuit
P1634 - Ignition 1 Switch Circuit
P1635 - 5 Volt Reference Circuit
P1636 - PCM Stack Overrun
P1637 - Generator L-Terminal Circuit
P1638 - Generator F-Terminal Circuit
P1639 - 5 Volt Reference 2 Circuit
P1640 - Driver-1-Input High Voltage
P1641 - Malfunction Indicator Lamp (MIL) Control Circuit
P1642 - Vehicle Speed Output Circuit
P1643 - Engine Speed Output Circuit
P1644 - Traction Control Delivered Torque Output Circuit
P1645 - Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
P1646 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P1647 - Driver 1 Line 7
P1650 - Control Module Output B Circuit
P1651 - Fan 1 Relay Control Circuit
P1652 - Powertrain Induced Chassis Pitch Output Circuit
P1653 - Oil Level Lamp Control Circuit
P1654 - Cruise Control Inhibit Output Circuit
P1655 - EVAP Purge Solenoid Control Circuit
P1656 - Driver 2 Line 6
P1657 - 1-4 Upshift Solenoid Control Circuit
P1658 - Starter Enable Relay Control Circuit
P1660 - Cooling Fan Control Circuits
P1661 - MIL Control Circuit
P1662 - Cruise Lamp Control Circuit
P1663 - Oil Life Lamp Control Circuit
P1664 - 1-4 Upshift Lamp Control Circuit
P1665 - Driver 3 Line 5
P1666 - Driver 3 Line 6
P1667 - Reverse Inhibit Solenoid Control Circuit
P1669 - ABS Unit Expected
P1670 - Driver 4
P1671 - Driver 4 Line 1
P1672 - Low Engine Oil Level Lamp Control Circuit
P1673 - Engine Hot Lamp Control Circuit
P1674 - Tachometer Control Circuit
P1675 - EVAP Vent Solenoid Control Circuit
P1676 - Driver 4 Line 6
P1677 - Driver 4 Line 7
P1680 - Driver 5 (ECU Malfunction)
P1681 - Driver 5 Line 1
P1682 - Driver 5 Line 2
P1683 - Driver 5 Line 3
P1684 - Driver 5 Line 4
P1685 - Driver 5 Line 5
P1686 - Driver 5 Line 6
P1687 - Driver 5 Line 7
P1689 - Delivered Torque Circuit Fault
P1690 - ECM Loop Overrun
P1691 - Coolant Gage Circuit Low Voltage
P1692 - Coolant Gage Circuit High Voltage
P1693 - Tachometer Circuit Low Voltage
P1694 - Tachometer Circuit High Voltage
P1695 - Remote Keyless Entry Circuit Low
P1696 - Remote Keyless Entry Voltage High
P1700 - Transmission Control Module (TCM) Requested MIL Illumination
P1701 - Trans. MIL Request Circuit
P1705 - P/N Signal Output Circuit
P1719 - Incorrect Shifting Detected (TCM)
P1740 - Torque Reduction Signal Circuit
P1743 - TP Signal from ECM
P1760 - TCM Supply Voltage Interrupted
P1779 - Engine Torque Delivered to TCM Signal
P1780 - Park/Neutral Position [PNP] Switch Circuit
P1781 - Engine Torque Signal Circuit
P1790 - Transmission Control Module Checksum
P1791 - Transmission Control Module Loop
P1791 - Throttle/Pedal Position Signal (2000+)
P1792 - Transmission Control Module Reprogrammable Memory
P1792 - ECM to TCM Engine Coolant Signal
P1793 - Transmission Control Module Stack Overrun
P1793 - Wheel Speed Signal (2000+)
P1795 - CAN Bus - Throttle Body Position
P1800 - TCM Power Relay Control Circuit
P1801 - Performance Selector Switch Failure
P1804 - Ground Control Relay
P1810 - TFP Valve Position Switch Circuit
P1811 - Maximum Adapt and Long Shift
P1812 - Transmission Over Temperature Condition
P1813 - Torque Control
P1814 - Torque Converter Overstressed
P1815 - Transmission Range Switch - Start In Wrong Range
P1816 - TFP Valve Position Sw. - Park/Neu. With Drive Ratio
P1817 - TFP Valve Position Sw. - Reverse With Drive Ratio
P1818 - TFP Valve Position Sw. - Drive Without Drive Ratio
P1819 - Internal Mode Switch - No Start\Wrong Range
P1820 - Internal Mode Switch Circuit A Low
P1822 - Internal Mode Switch Circuit B High
P1823 - Internal Mode Switch Circuit P Low
P1825 - Internal Mode Switch - Invalid Range
P1826 - Internal Mode Switch Circuit C - High
P1831 - Pressure Control (PC) Solenoid Power Circuit - Low Voltage
P1832 - Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
P1833 - A/T Solenoids Power Circuit - Low Voltage
P1834 - Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage
P1835 - Kick-Down Switch Circuit
P1836 - Kick-Down Switch Failed Open
P1837 - Kick-Down Switch Failed Short
P1842 - 1-2 Shift Solenoid Circuit Low Voltage
P1843 - 1-2 Shift Solenoid Circuit High Voltage
P1844 - Torque Reduction Signal Circuit Desired By TCM
P1845 - 2-3 Shift Solenoid Circuit Low Voltage
P1847 - 2-3 Shift Solenoid Circuit High Voltage
P1850 - Brake Band Apply Solenoid Circuit
P1851 - Brake Band Apply Solenoid Performance
P1852 - Brake Band Apply SolenoidLow Voltage
P1853 - Brake Band Apply Solenoid High Voltage
P1860 - TCC PWM Solenoid Circuit Electrical
P1864 - Torque Converter Clutch Circuit
P1865 - 4-5 Shift Solenoid (SS) Valve Control Circuit High Voltage
P1866 - Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage
P1867 - Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage
P1868 - Transmission Fluid Life
P1870 - Transmission Component Slipping
P1871 - Undefined Gear Ratio
P1873 - TCC Stator Temp. Switch Circuit Low
P1874 - TCC Stator Temp. Switch Circuit High
P1875 - 4WD Low Switch Circuit Electrical
P1884 - TCC Enable/Shift Light Circuit
P1886 - Shift Timing Solenoid
P1887 - TCC Release Switch Circuit
P1890 - ECM Data Input Circuit
P1890 - Throttle Position Signal Input
P1891 - Throttle Position Sensor PWM Signal Low
P1892 - Throttle Position Sensor PWM Signal High
P1893 - Engine Torque Signal Low Voltage
P1894 - Engine Torque Signal High Voltage
P1895 - TCM to ECM Torque Reduction Circuit
P2008 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit
P2009 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage
P2010 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage
P2066 - Fuel Level Sensor 2 Performance
P2067 - Fuel Level Sensor 2 Circuit Low Voltage
P2068 - Fuel Level Sensor 2 Circuit High Voltage
P2096 - Post Catalyst Fuel Trim System Low Limit
P2097 - Post Catalyst Fuel Trim System High Limit
P2098 - Post Catalyst Fuel Trim System Low Limit
P2099 - Post Catalyst Fuel Trim System High Limit
P2100 - Throttle Actuator Control (TAC) Motor Control Circuit
P2101 - Control Module Throttle Actuator Position Performance
P2105 - Throttle Actuator Control (TAC) System - Forced Engine Shutdown
P2107 - Throttle Actuator Control (TAC) Module Internal Circuit
P2108 - Throttle Actuator Control (TAC) Module Performance
P2119 - Throttle Closed Position Performance
P2120 - Accelerator Pedal Position (APP) Sensor 1 Circuit
P2121 - Accelerator Pedal Position (APP) Sensor 1 Performance
P2122 - Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
P2123 - Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
P2125 - Accelerator Pedal Position (APP) Sensor 2 Circuit
P2127 - Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
P2128 - Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
P2135 - Throttle Position (TP) Sensor 1-2 Correlation
P2138 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation
P2176 - Minimum Throttle Position Not Learned
P2500 - Generator L-Terminal Circuit Low Voltage
P2501 - Generator L-Terminal Circuit High Voltage
P2535 - Ignition 1 Switch Circuit High Voltage (PCM)
P2610 - ECU Malfunction
P2763 - Short to voltage in the TCC Solenoid
P2764 - Open or Short to ground in the TCC PWM solenoid valve circuit
P2A00 - HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 (PCM)
P2A01 - HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 2 (PCM)
P3000 - Hacking AWH Data
(long list)
P1335 - CKP Circuit
P1528 - Governor
P1670 - Driver 4
xeroinfinity
09-02-2006, 10:13 AM
Heres the ODB-I procedure .
This is a picture of the Assembly Line Diagnostic Link (ALDL) connector or Data Link Connector (DLC). These two connectors are located just under the steering wheel, might be covered up with a cover btw. Either of these could have been used on your 1985-98 pontiac GA.
http://i28.photobucket.com/albums/c242/xeroinfinity/SeCond%20Hand/85-98GMDLC.jpg
Codes can be read by grounding test terminal B. The terminal is most easily grounded by connecting it to terminal A (internal ECM ground). This is the terminal to the right of terminal B on the top row of the ALDL connector.
Once the terminals have been connected, the ignition switch must be moved to the ON position with the engine not running.
The Service Engine Soon or Check Engine light should be flashing. If it isn't, turn the ignition OFF and remove the jumper wire. Turn the ignition ON and confirm that light is now on. If it is not, replace the bulb and try again. If the bulb still will not light, or if it does not flash with the test terminal grounded, the system should be diagnosed by an experienced technician. If the light is OK, proceed as follows.
The codes stored in memory may be read through counting the flashes of the dashboard warning lamp. The dash warning lamp should begin to flash Code 12. The code will display as one flash, a pause and two flashes. Code 12 is not a fault code. It is used as a system acknowledgment or handshake code, its presence indicates the PCM can communicate as requested. Code 12 is used to begin every diagnostic sequence. Some vehicles also use Code 12 after all diagnostic codes have been sent.
After Code 12 has been transmitted 3 times, the fault codes, if any, will each be transmitted 3 times. The codes are stored and transmitted in numeric order from lowest to highest.
The order of codes in the memory does not indicate the order of occurrence.
If there are no codes stored, but a driveability or emissions problem is evident, the system should be diagnosed by an experienced technician.
If one or more codes are stored, record them.
Switch the ignition OFF when finished with code retrieval or scan tool readings.
On some models, 94-96, they will need scanned with a scan tool.
xeroinfinity
09-11-2006, 01:41 PM
Here are ODB 1 Codes.
Ridenour Might have listed some above but thiers more.
13 Oxygen Sensor(O2s)Circuit - open circuit
14 Engine Coolant Temperature(ETC)Sensor Circuit-high temperature
15 Engine Coolant Temperature(ETC)Sensor Circuit-cold temperature
16 System Voltage High
17 Camshaft Postion Sensor Circuit Error
19 Intermittent 7X Reference Signal
21 Throttle Position(TP) Sensor Circuit-signal voltage high
22 Throttle Position(TP) Sensor Circuit-signal voltage low
23 Intake Air Temperature(IAT)Sensor Circuit low Temperature
24 Vehicle Speed Sensor(VSS)Circuit
25 Intake Air Temperature(IAT)Sensor Circuit high Temperature
26 Quad Driver(QDM)Circuit
27 Quad Driver Module(QMD1)
28 Quad Driver Module(QMD2)
31 PRNDL Error
31 Turbo Wastegate Overboost- 2.0L VIN M
32 Exhaust Gas Recirculation(EGR) Valve
33 Manifold Absolute Pressure(MAP) Sensor circuit signal voltage high
33 Mass Air Flow Sensor Circuit-high frequency
34 Manifold Absolute Pressure(MAP) Sensor circuit signal voltage low
34 Mass Air Flow Sensor Circuit-low frequency
35 Idle speed Error
36 Ignition Control 24X Signal Circuit Error
37 TCC Brake switch Error
38 Brake switch Circuit
39 Torque Converter Clutch Circuit
41 1X Peferance Circuit
41 Ignition Control(IC) Timing Circuit Error(3100 VIN M)
42 Knock Sensor(KS) Circuit - spark timing
42 Ignition Control Bypass Erro(3100 VIN M)
43 Knock Sensor(KS) Circuit - spark control
44 Oxygen Sensor(O2s) Circuit - lean exhaust indicated
45 Oxygen Sensor(O2s) Circuit - rich exhaust indicated
46 Power Steering Pressure Switch Circuit
51 EPROM Error
53 Battery Voltage Error
54 Fuel Pump Circuit
55 Fuel Lean Monitor
58 Transaxle Fluid Temp(TFT) Sensor- high temperature
59 Transaxle Fluid Temp(TFT) Sensor- low temperature
65 Fuel Injector Circuit-low current
66 AC Refrigerant Pressure sensor circuit - low pressure
70 AC Refrigerant Pressure sensor circuit - high pressure
72 Loss of Serial Data
72 Vehicle Speed Sensor(VSS) Circuit- signal erro(3100 VIN M)
75 Digital EGR #1 Solenoid Error
76 Digital EGR #2 Solenoid Error
77 Digital EGR #2 Solenoid Error
79 Trnasaxle Fluid Overtemp
80 Transaxle Component Error
82 Ignition Control 3X - Signal Error
85 EPROM Error -Faulty or incorrect Calibration
86 Analog/digital Error
87 EEPROM Error
90 TCC Error
96 trans System Voltage Low
98 Invalid PCM PRogram
99 Invalid PCM Program
31 PRNDL Error
35 Idle speed Error
51 EPROM Error
87 EEPROM Error
90 TCC Error
xeroinfinity
10-26-2006, 04:19 PM
Here is the "B" body codes.
DTC B0001 PCM Discrete Input Speed Signal Error
DTC B0004 PCM Discrete Input Speed Signal Not Present
DTC B0005 In Park Switch Circuit Malfunction
DTC B0016 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
DTC B0017 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Open
DTC B0018 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
DTC B0022 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
DTC B0024 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
DTC B0026 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open
DTC B0028 RF/Passenger Side Deployment Loop Resistance Low
DTC B0029 RF/Passenger Side Deployment Loop Open
DTC B0030 RF/Passenger Side Deployment Loop Short to Ground/Voltage Out of Range
DTC B0035 ADS Closed/Shorted to Ground
DTC B0036 ADS Open/Missing/Shorted to Battery
DTC B0037 AUX switch closed/shorted to ground
DTC B0038 AUX switch open/shorted to battery
DTC B0040 LF/Driver Side Deployment Loop Resistance Low
DTC B0041 LF/Driver Side Deployment Loop Open
DTC B0045 LF Side Deploy Loop Short to Ground/Voltage Out of Range
DTC B0051 Deployment Commanded
DTC B0053 Deployment Commanded with Loop Malfunctions Present
DTC B0057 RF/Passenger Pretensioner Deployment Loop Resistance Low
DTC B0058 RF/Passenger Pretensioner Deployment Loop Open
DTC B0059 RF/Passenger Pretensioner Deployment Loop Short to Ground/Voltage Out of Range
DTC B0064 LF/Driver Pretensioner Deployment Loop Resistance Low
DTC B0065 LF/Driver Pretensioner Deployment Loop Open
DTC B0066 LF/Driver Pretensioner Deployment Loop Short to Ground/Voltage Out of Range
DTC B0073 Supplemental Deployment Loop #1 Resistance Low
DTC B0074 Supplemental Deployment Loop #1 Open
DTC B0075 Supplemental Deployment Loop #1 Short to Ground/Voltage Out of Range
DTC B0077 LF/Driver SIS Malfunction
DTC B0078 RF/Passenger SIS Malfunction
DTC B0079 Incorrect LF/Driver SIS Installed
DTC B0080 Discard LF/Driver SIS
DTC B0081 Incorrect RF/Passenger SIS Installed
DTC B0082 Discard RF/Passenger SIS
DTC B0086 Supplemental Deployment Loop #2 Resistance Low
DTC B0087 Supplemental Deployment Loop #2 Open
DTC B0088 Supplemental Deployment Loop #2 Short to Ground/Voltage Out of Range
DTC B0090 Active switch voltage out of range
DTC B0091 Active switch: wrong state
DTC B0092 PPS passenger detection error
DTC B0093 PPS/CPS self-test malfunction
DTC B0094 CPS childseat detection error
DTC B0095 SDM-PPS/CPS mismatch malfunction
DTC B0126 Right Panel Discharge Temperature Fault
DTC B0131 Right Heater Discharge Temperature Fault
DTC B0159 Outside Air Temperature Sensor Circuit Range/Performance
DTC B0164 Passenger Compartment Temperature Sensor #1 (Single Sensor or LH) Circuit Range/Performance
DTC B0169 In-car Temp Sensor Failure (passenger -not used)
DTC B0174 Output Air Temperature Sensor #1 (Upper; Single or LH) Circuit Range/Performance
DTC B0179 Output Air Temperature Sensor #2 (Lower; Single or LH) Circuit Range/Performance
DTC B0184 Solar Load Sensor #1 CKT Range
DTC B0189 Solar Load Sensor #2 CKT Range
DTC B0248 Mode Door Inoperative Error
DTC B0249 Heater/Defrost/AC Door Range Error
DTC B0268 A/I Door Inoperative Error
DTC B0269 Air Inlet Door Range Error
DTC B0408 Temperature Control #1 (Main/Front) Circuit Malfunction
DTC B0409 Air Mix Door #1 Range Error
DTC B0419 Air Mix Door #2 Range Error
DTC B0423 Air Mix Door #2 Inoperative Error
DTC B0428 Air Mix Door #3 Inoperative Error
DTC B0429 Temperature Control #3 Rear Circuit Range/Performance
DTC B0510 RH Panel Discharge Temp Sensor Failure
DTC B0515 RH Heater Discharge Temp Sensor Failure
DTC B0520 Rear Discharge Temp Sensor Failure
DTC B0530 Fuel Level Sensor Stuck
DTC B0532 Fuel Sensor Shorted To Ground
DTC B0533 Fuel Sensor Open/Shorted To B+
DTC B0688 Security System Indicator Circuit High
DTC B0768 Service Indicator Circuit High
DTC B0846 +5 Volt Reference Out of Range
DTC B0856 Battery 2 Out of Range
DTC B1000 ECU Malfunction
DTC B1001 Option Configuration Error
DTC B1004 Keep Alive Memory (KAM)
DTC B1007 EEPROM Write Error
DTC B1009 EEPROM Checksum Error
DTC B1013 ROM Checksum Error
DTC B1014 Program ROM Checksum Error
DTC B1015 Passenger Deploy. Loop Resistance High
DTC B1016 Passenger Deployment Loop Resistance Low
DTC B1017 Passenger Deployment Loop Open
DTC B1018 Passenger Deployment Loop Short to GND
DTC B1019 Passenger Deploy. Loop Short to Voltage
DTC B1021 Driver Deployment Loop Resistance High
DTC B1022 Driver Deployment Loop Resistance Low
DTC B1024 Driver Deployment Loop Short to Ground
DTC B1025 Driver Deployment Loop Short to Voltage
DTC B1026 Driver Deployment Loop Open
DTC B1035 Discr. Sensor Closed or Short to GND
DTC B1036 Discr. Sensor Open or Short to Voltage
DTC B1051 Frontal Air Bag and Preten Deployment
DTC B1053 Deployment Commanded w/Loop Malfunction
DTC B1054 Infl Rst IP Module Switch CKT Failure
DTC B1061 Lamp Circuit Failure
DTC B1071 Internal SDM Failure
DTC B1115 Passenger Deploy. Loop Resistance High
DTC B1116 Passenger Deploy. Loop Resistance Low
DTC B1117 Passenger Deployment Loop Open
DTC B1121 Driver Deployment Loop Resistance High
DTC B1122 Driver Deployment Loop Resistance Low
DTC B1124 Driver/Pass. Deploy. Loop Short to GND
DTC B1125 Driver/Pass Deploy Loop Short to Voltage
DTC B1126 Driver Deployment Loop Open
DTC B1131 Pass. Pretensioner Loop Resistance High
DTC B1132 Pass. Pretensioner Loop Resistance Low
DTC B1134 Passenger Pretensioner Loop Open
DTC B1135 Discr. Sensor Closed or Short to GND
DTC B1136 Discr. Sensor Open or Short to Voltage
DTC B1141 Driver Pretensioner Loop Resistance High
DTC B1142 Driver Pretens. Deploy. Loop Res. Low
DTC B1144 Driver/Pass Pretens. Loop Short to GND
DTC B1145 Driver/Pass Pretens. Loop Short to Volt
DTC B1146 Driver Pretensioner Loop Open
DTC B1147 Driver Side Air Bag System Malfunction
DTC B1148 Pass. Side Air Bag System Malfunction
DTC B1151 Deployment Commanded - Frontal
DTC B1152 Data Area Full
DTC B1153 Deployment Commanded w/Loop Malfunction
DTC B1155 SDM Calibration Mismatch
DTC B1159 Loss of Serial Data-Key Not Received
DTC B1160 Loss of Serial Data - VIN Not Received
DTC B1161 Lamp Circuit Failure
DTC B1163 Loss of Serial Data-No Lamp Response
DTC B1171 Internal SDM Failure
DTC B1245 CD Changer Not Responding
DTC B1271 Theft Lock Enabled
DTC B1310 Ambient Air Temperature Sensor Failure
DTC B1311 Outside Air Temp Sensor Short Circuit
DTC B1312 High Side Temp Sensor Open Circuit
DTC B1313 High Side Temp Sensor Short Circuit
DTC B1314 Evaporator Inlet Temp Sensor Open CKT
DTC B1315 Evaporator Inlet Temp Sensor Short CKT
DTC B1316 In Car Temperature Sensor Open Circuit
DTC B1317 In Car Air Temperature Sensor
DTC B1318 LH Sun Load Sensor Fault
DTC B1319 Sunload Sensor Short Circuit
DTC B1321 A/C Low Side Temperature Sensor Fault
DTC B1324 A/C Refrigerant Overpressure
DTC B1327 Device Power Circuit Low
DTC B1328 Device Power Circuit High
DTC B1328 RH Sun Load Sensor Fault
DTC B1330 Left A/C Discharge Sensor Fault
DTC B1331 Right A/C Discharge Sensor Fault
DTC B1332 Left Heater Discharge Sensor Fault
DTC B1333 Right Heater Discharge Sensor Fault
DTC B1340 Air Mix Door One Movement Fault
DTC B1341 Air Mix Door Two Movement Fault
DTC B1343 Air Inlet Door Movement Fault
DTC B1344 HTR/DEF/AC Door Movement Fault
DTC B1347 Very Low A/C Refrigerant Warning
DTC B1348 Very Low A/C Refrigerant Pressure
DTC B1350 Engine Coolant Over-Temperature
DTC B1390 Device Voltage Reference Input CKT Malf
DTC B1396 Device Voltage Reference Output 1 Circuit Range Performance
DTC B1399 Loss of KDD Communications
DTC B1422 Device Power Moding Malfunction
DTC B1438 IPC High Voltage Output Overcurrent to IPM
DTC B1513 Charging System Volts Low
DTC B1514 Charging System Volts High
DTC B1552 Keep Alive Memory (KAM) Error
DTC B1556 IPC EEPROM Odo/Configuration Error
DTC B1557 EEPROM Calibration Error
DTC B1558 BCM EPROM Checksum Error
DTC B1586 Mirror Horiz. Pos Sensor-Out of Range/Open
DTC B1591 Mirror Vert. Pos Sensor-Out of Range/Open
DTC B1652 Loss of Keep Alive Memory (KAM)
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1697 Mirror Switch Input Shorted to Ground
DTC B1698 Mirror Switch L Up Input Stuck High
DTC B1702 Mirror Switch Input Shorted to Ground
DTC B1703 Mirror Switch L Down Input Stuck High
DTC B1707 Mirror Switch Input Shorted to Ground
DTC B1708 Mirror Switch R Up Input Stuck High
DTC B1712 Mirror Switch Input Shorted to Ground
DTC B1713 Mirror Switch R Down Input Stuck High
DTC B1717 Mirror Power Fold Control Switch Shorted Low
DTC B1718 Power Folding Mirror Switch Input Circuit High
DTC B1735 Driver Seat Front Up Switch CKT Malf
DTC B1740 Driver Seat Front Down Switch CKT Malf
DTC B1745 Driver Seat Rear Up Switch CKT Malf
DTC B1750 Driver Seat Rear Down Switch CKT Malf
DTC B1755 Driver Seat Asm Forward Switch CKT Malf
DTC B1760 Driver Seat Asm Rearward Switch CKT Malf
DTC B1760 CD Changer Not Responding
DTC B1780 Theft Lock Enabled
DTC B1805 Ignition Switch Problem
DTC B1815 Driver Recline Forward Switch CKT Malf
DTC B1820 Driver Recline Rearward Switch CKT Malf
DTC B1825 Driver Recline Sensor CKT Malfunction
DTC B1830 Driver Lumbar Forward Switch CKT Malf
DTC B1835 Driver Lumbar Rearward Switch CKT Malf
DTC B1840 Driver Lumbar Up Switch CKT Malf
DTC B1845 Driver Lumbar Down Switch CKT Malf
DTC B1850 Driver Lumbar Horiz Sensor CKT Malf
DTC B1860 Driver Lumbar Vert Sensor CKT Malf
DTC B1870 Driver Belt Tower Up Switch CKT Malf
DTC B1875 Driver Belt Tower Down Sw CKT Malf
DTC B1900 Driver Belt Tower Vert Sen CKT Malf
DTC B1910 Generator L-Terminal Open Circuit
DTC B1911 Generator L-Terminal Problem
DTC B1913 Heated Seat Switch - Mode Input Shorted to Battery
DTC B1918 Heated Seat Switch - Temperature Input Shorted to Battery
DTC B1970 Exterior Lamp Power
DTC B1971 Inadvertent Power
DTC B1972 Low Power Driver Fault
DTC B1973 High Power Control Fault
DTC B1981 Battery Voltage Low
DTC B1982 Device Power Circuit High
DTC B1983 Device Power Circuit Low
DTC B2101 Recline Aft Switch Failed
DTC B2102 Recline Forward Switch Failed
DTC B2103 Rear Vertical Down Switch Failed
DTC B2104 Rear Vertical Up Switch Failed
DTC B2105 Horizontal Aft Switch Failed
DTC B2106 Horizontal Forward Switch Failed
DTC B2107 Front Vertical Down Switch Failed
DTC B2108 Front Vertical Up Switch Failed
DTC B2109 Lumbar Aft Switch Failed
DTC B2110 Lumbar Forward Switch Failed
DTC B2111 Lumbar Down Switch Failed
DTC B2112 Lumbar Up Switch Failed
DTC B2115 Recline Sensor Failed
DTC B2116 Rear Vertical Sensor Failed
DTC B2117 Horizontal Sensor Failed
DTC B2118 Front Vertical Sensor Failed
DTC B2119 Lumbar Forward/Aft Sensor Failed
DTC B2120 Lumbar Up/Down Sensor Failed
DTC B2130 Driver Memory 1 Select Switch Circuit Malfunction
DTC B2131 Driver Memory 2 Select Switch Circuit Malfunction
DTC B2132 Driver Memory Exit Exit/Off Switch Circuit Malfunction
DTC B2133 Driver Memory Set Switch Circuit Malfunction
DTC B2140 Mirror Up Control Switch Circuit Malfunction
DTC B2141 Mirror Down Control Switch Circuit Malfunction
DTC B2142 Mirror Left Control Switch Circuit Malfunction
DTC B2143 Mirror Right Control Switch Circuit Malfunction
DTC B2144 Left Front Mirror Vertical Position Sensor Circuit Low
DTC B2145 Left Front Mirror Vertical Position Sensor Circuit High
DTC B2146 Left Front Mirror Horizontal Position Sensor Circuit Low
DTC B2147 Left Front Mirror Horizontal Position Sensor Circuit High
DTC B2148 Right Front Mirror Vertical Position Sensor Circuit Low
DTC B2149 Right Front Mirror Vertical Position Sensor Circuit High
DTC B2150 Right Front Mirror Horizontal Position Sensor Circuit Low
DTC B2151 Right Front Mirror Horizontal Position Sensor Circuit High
DTC B2175 Tilt/Telescope Module Manual Switch Fail
DTC B2200 LF Window Switch Stuck in Up Position
DTC B2201 LF Window Switch Stuck in Down Position
DTC B2202 RF Window Switch Stuck in Up Position
DTC B2203 RF Window Switch Stuck in Down Position
DTC B2204 LR Window Switch Stuck in Up Position
DTC B2205 LR Window Switch Stuck in Down Position
DTC B2206 RR Window Switch Stuck in Up Position
DTC B2207 RR Window Switch Stuck in Down Position
DTC B2212 RF Switch on LF Door Stuck Up Position
DTC B2213 RF Switch on LF Door Stuck Down Position
DTC B2214 LR Switch on LF Door Stuck Up Position
DTC B2215 LR Switch on LF Door Stuck Down Position
DTC B2216 RR Switch on LF Door Stuck Up Position
DTC B2217 RR Switch on LF Door Stuck Down Position
DTC B2220 LF Door Lock/Unlock Switch Stuck in Lock
DTC B2221 LF Door Lock/Unlock Switch Stuck UnLock
DTC B2222 RF Door Lock/Unlock Switch Stuck in Lock
DTC B2223 RF Door Lock/Unlock Switch Stuck UnLock
DTC B2224 LR Door Lock/Unlock Switch Stuck in Lock
DTC B2226 RR Door Lock/Unlock Switch Stuck in Lock
DTC B2240 Memory 1 Switch Failed
DTC B2241 Memory 2 Switch Failed
DTC B2242 Memory Exit Switch Failed
DTC B2243 Memory Set Switch Failed
DTC B2310 Hand Set Failure
DTC B2311 TRU Failure
DTC B2312 Software Failure
DTC B2355 Driver Front Vertical Sensor Malf
DTC B2365 Driver Rear Vertical Sensor Malf
DTC B2375 Driver Seat Asm Horiz Sensor CKT Malf
DTC B2419 Twilight Photocell Circuit Problem
DTC B2420 Twilight Delay Pot Failure
DTC B2422 Interior Lamp Rheostat Failure
DTC B2460 Navigation Antenna Selector Circuit High Current
DTC B2461 Navigation ECU Synchronous Signal Error
DTC B2462 GPS Signal Error
DTC B2463 Navigation CD Player - No Disk
DTC B2464 Navigation CD Player - Decoding Error
DTC B2465 Navigation CD Player - Data Error
DTC B2466 Navigation VICS Memory Error
DTC B2468 Navigation Display Head (NDH) Malfunction
DTC B2470 Daytime Running Lamps Fault
DTC B2471 Interior Lamp Fault
DTC B2472 Low Beam Fault
DTC B2473 High Beam Fault
DTC B2474 Navigation Display Head (NDH) Back Lighting Malfunction
DTC B2475 Navigation Display Head (NDH) Auxiliary Input Malfunction
DTC B2476 Cellular Phone Select Service Switch Malfunction
DTC B2476 Parklamp Fault
DTC B2477 Reverse Lamp Relay Shorted to Ground
DTC B2478 Reverse Lamp Shorted to Battery
DTC B2502 Auto Trans Shift Lock Control Shorted to Ground
DTC B2503 Park Gear (Auto Trans Shift Lock Control) Relay Shorted to Batt
DTC B2510 Steering Wheel Controls HVAC Key Stuck
DTC B2511 Steering Wheel Controls Conv Key Stuck
DTC B2512 Strng Wheel Controls Illegal A/D Values
DTC B2515 Strg Whl Cont Illegal Resistance Value
DTC B2550 Storage Mode Entered
DTC B2556 Interior Lamp Rheostat Circuit Range
DTC B2560 RKE Message Validation Error
DTC B2641 Delayed Exterior Lighting Ctrl CKT Range
DTC B2646 Ambient Light Sensor Circuit Range
DTC B2710 PASSKey Open/Shorted Pellet
DTC B2711 PASSKey Open/Shorted Pellet After Good Key
DTC B2719 CTD-Trunk Tamper Switch Fault
DTC B2725 ATC Mode Switch Circuit Malfunction
DTC B2734 Coded Key Controller Memory Failure
DTC B2750 PASSKey Data Communication Failure
DTC B2757 Driver Memory 1 Select Switch CKT Low
DTC B2762 Driver Memory 2 Select Switch CKT Low
DTC B2767 Memory Set Switch Failed Low
DTC B2772 Driver Memory Exit Switch Circuit Low
DTC B2780 Wrong Resistor Before Good
DTC B2781 Wrong Resistor After Good
DTC B2782 PASSKey Pellet Resistance Not Programmed
DTC B2783 Key Code/Password Corrupted in Memory
DTC B2805 Steering Whl Controls HVAC Sw CKT Malf
DTC B2810 Steering Whl Ctrl Entertainment CKT Malf
DTC B2853 Telescope Forward Switch Circuit Malfunction
DTC B2858 Telescope Rearward Switch Circuit Malfunction
DTC B2860 Telescope Position Sensor Range
DTC B2862 Telescope Position Sensor Low
DTC B2873 Tilt Up Switch Circuit Malfunction
DTC B2878 Tilt Down Switch Circuit Malfunction
DTC B2880 Tilt Position Sensor Range
DTC B2882 Tilt Position Sensor Low
DTC B2891 Tilt/Telescope Motor Over Current
DTC B2904 Tilt/Telescope 4-way Position Switch Circuit Malfunction
DTC B2947 Security System Sensor Power CKT Low
DTC B2948 Security System Sensor Power CKT High
DTC B2955 Security System Sensor Data CKT Malf
DTC B2957 Security System Sensor Data Circuit Low
DTC B2958 Security System Sensor Data Circuit High
DTC B2960 Sec Sys Sensor Data Incorrect but Valid
DTC B3028 Starter Relay Interface Short to Ground
DTC B3029 Starter Relay Interface Open/Short to B+
DTC B3031 Key Decoder Device in Assem Learn Mode
DTC B3033 Security System Indicates Tamper
DTC B3055 Key Not Present
DTC B3069 RF/LF Door Key Unlock Circuit Low
DTC B3108 Transmitter Synchronization Failure
DTC B3142 LF Unlock Switch Circuit Low
DTC B3147 Passenger Unlock Switch Circuit Low
DTC B3152 LF Lock Switch Circuit Low
DTC B3157 Passenger Lock Switch Circuit Low
DTC B3172 Window Up Switch Circuit Low
DTC B3177 Window Down Switch Circuit Low
DTC B3203 Rear Window Lockout Switch Input Circuit High
DTC B3282 Window Switch-Express Input Shorted to Ground
DTC B3287 LR Window Switch Express Down Circuit Low
DTC B3292 RR Window Switch Express Down Circuit Low
DTC B3377 LF Window Up Switch Circuit Low
DTC B3382 LF Window Down Switch Circuit Low
DTC B3387 RF Window Up Switch Circuit Low
DTC B3392 RF Window Down Switch Circuit Low
DTC B3397 LR Window Up Switch Circuit Low
DTC B3452 LR Window Down Switch Circuit Low
DTC B3457 RR Window Up Switch Circuit Low
DTC B3462 RR Window Down Switch Circuit Low
DTC B3467 LF Window Express Down Circuit Low
DTC B3472 RF Window Express Down Circuit Low
DTC B3477 LR Window Express Down Circuit Low
DTC B3482 RR Window Express Down Circuit Low
DTC B3517 LR Door Sw Express Up/Down Window Contact Shorted to GND
DTC B3522 RR Door Sw Express Up/Down Window Contact Shorted to GND
DTC B3527 Window Lockout Switch Circuit Low
DTC B3793 Memory Seat Module Over Current
xeroinfinity
01-02-2007, 01:14 PM
GM U Network OBD Trouble Codes
DTC U1000 Class 2 Communication Malfunction
DTC U1001-U1254 Loss of XXX Communications
DTC U1002 Loss of serial communications for class 2 devices
DTC U1003 Loss of serial communications for class 2 devices
DTC U1004 Loss of serial communications for class 2 devices
DTC U1005 Loss of serial communications for class 2 devices
DTC U1006 Loss of serial communications for class 2 devices
DTC U1007 Loss of serial communications for class 2 devices
DTC U1008 Loss of serial communications for class 2 devices
DTC U1009 Loss of serial communications for class 2 devices
DTC U1010 Loss of serial communications for class 2 devices
DTC U1011 Loss of serial communications for class 2 devices
DTC U1012 Loss of serial communications for class 2 devices
DTC U1013 Loss of serial communications for class 2 devices
DTC U1014 Loss of serial communications for class 2 devices
DTC U1015 Loss of serial communications for class 2 devices
DTC U1016 Loss of Class 2 Communication with VCM
DTC U1016 Loss of Communications with PCM
DTC U1017 Loss of serial communications for class 2 devices
DTC U1018 Loss of serial communications for class 2 devices
DTC U1019 Loss of serial communications for class 2 devices
DTC U1020 Loss of serial communications for class 2 devices
DTC U1021 Loss of serial communications for class 2 devices
DTC U1022 Loss of serial communications for class 2 devices
DTC U1023 Loss of serial communications for class 2 devices
DTC U1024 Loss of serial communications for class 2 devices
DTC U1025 Loss of serial communications for class 2 devices
DTC U1026 Loss of ATC Class 2 Communication
DTC U1027 Loss of serial communications for class 2 devices
DTC U1028 Loss of serial communications for class 2 devices
DTC U1029 Loss of serial communications for class 2 devices
DTC U1030 Loss of serial communications for class 2 devices
DTC U1031 Loss of serial communications for class 2 devices
DTC U1032 Loss of serial communications for class 2 devices
DTC U1033 Loss of serial communications for class 2 devices
DTC U1034 Loss of serial communications for class 2 devices
DTC U1035 Loss of serial communications for class 2 devices
DTC U1036 Loss of serial communications for class 2 devices
DTC U1037 Loss of serial communications for class 2 devices
DTC U1038 Loss of Serial Communications for Class 2 Devices
DTC U1039 Loss of Serial Communications for Class 2 Devices
DTC U1040 Loss of Class 2 Communications with ABS
DTC U1041 Loss of EBCM Communication
DTC U1042 Lost Communications with Brake/Traction Control System
DTC U1043 Loss of Serial Communications for Class 2 Devices
DTC U1044 Loss of Serial Communications for Class 2 Devices
DTC U1045 Loss of Serial Communications for Class 2 Devices
DTC U1046 Loss of Serial Communications for Class 2 Devices
DTC U1047 Loss of Serial Communications for Class 2 Devices
DTC U1048 Loss of Serial Communications for Class 2 Devices
DTC U1049 Loss of Serial Communications for Class 2 Devices
DTC U1050 Loss of Serial Communications for Class 2 Devices
DTC U1051 Loss of Serial Communications for Class 2 Devices
DTC U1052 Loss of Serial Communications for Class 2 Devices
DTC U1053 Loss of Serial Communications for Class 2 Devices
DTC U1054 Loss of Serial Communications for Class 2 Devices
DTC U1055 Loss of Serial Communications for Class 2 Devices
DTC U1056 Loss of Communications with RSS
DTC U1057 Loss of Serial Communications for Class 2 Devices
DTC U1058 Loss of Serial Communications for Class 2 Devices
DTC U1059 Loss of Serial Communications for Class 2 Devices
DTC U1060 Loss of Serial Communications for Class 2 Devices
DTC U1161 Loss of PDM Serial Data
DTC U1062 Loss of Serial Communications for Class 2 Devices
DTC U1163 Loss of RRDM Serial Data
DTC U1064 Loss of Communications with DIM
DTC U1065 Loss of Communications with IPM
DTC U1066 Loss of Communications with RIM
DTC U1067 Loss of Serial Communications for Class 2 Devices
DTC U1068 Loss of Serial Communications for Class 2 Devices
DTC U1069 Loss of Serial Communications for Class 2 Devices
DTC U1170 Loss of Driver Door Sw Asm Serial Data
DTC U1071 Loss of Serial Communications for Class 2 Devices
DTC U1072 Loss of Serial Communications for Class 2 Devices
DTC U1073 Loss of Serial Communications for Class 2 Devices
DTC U1074 Loss of Serial Communications for Class 2 Devices
DTC U1075 Loss of Serial Communications for Class 2 Devices
DTC U1076 Loss of Serial Communications for Class 2 Devices
DTC U1077 Loss of Serial Communications for Class 2 Devices
DTC U1078 Loss of Serial Communications for Class 2 Devices
DTC U1079 Loss of Serial Communications for Class 2 Devices
DTC U1080 Loss of Serial Communications for Class 2 Devices
DTC U1081 Loss of Serial Communications for Class 2 Devices
DTC U1082 Loss of Serial Communications for Class 2 Devices
DTC U1083 Loss of Serial Communications for Class 2 Devices
DTC U1084 Loss of Serial Communications for Class 2 Devices
DTC U1085 Loss of Serial Communications for Class 2 Devices
DTC U1086 Loss of Serial Communications for Class 2 Devices
DTC U1087 Loss of Serial Communications for Class 2 Devices
DTC U1088 Loss of Communications with SDM
DTC U1089 Loss of Serial Communications for Class 2 Devices
DTC U1090 Loss of Serial Communications for Class 2 Devices
DTC U1091 Loss of Serial Communications for Class 2 Devices
DTC U1092 Loss of Serial Communications for Class 2 Devices
DTC U1093 Loss of Serial Communications for Class 2 Devices
DTC U1094 Loss of Serial Communications for Class 2 Devices
DTC U1095 Loss of Serial Communications for Class 2 Devices
DTC U1096 Loss of Communications with IPC
DTC U1097 Loss of Serial Communications for Class 2 Devices
DTC U1098 Loss of Serial Communications for Class 2 Devices
DTC U1099 Loss of Serial Communications for Class 2 Devices
DTC U1100 Loss of Serial Communications for Class 2 Devices
DTC U1101 Loss of Serial Communications for Class 2 Devices
DTC U1102 Loss of Serial Communications for Class 2 Devices
DTC U1103 Loss of Serial Communications for Class 2 Devices
DTC U1104 Loss of Serial Communications for Class 2 Devices
DTC U1105 Loss of Serial Communications for Class 2 Devices
DTC U1106 Loss of Serial Communications for Class 2 Devices
DTC U1107 Loss of Serial Communications for Class 2 Devices
DTC U1108 Loss of Serial Communications for Class 2 Devices
DTC U1109 Loss of Serial Communications for Class 2 Devices
DTC U1110 Loss of Serial Communications for Class 2 Devices
DTC U1111 Loss of Serial Communications for Class 2 Devices
DTC U1112 Loss of Serial Communications for Class 2 Devices
DTC U1113 Loss of Serial Communications for Class 2 Devices
DTC U1114 Loss of Serial Communications for Class 2 Devices
DTC U1115 Loss of Serial Communications for Class 2 Devices
DTC U1116 Loss of Serial Communications for Class 2 Devices
DTC U1117 Loss of Serial Communications for Class 2 Devices
DTC U1118 Loss of Serial Communications for Class 2 Devices
DTC U1119 Loss of Serial Communications for Class 2 Devices
DTC U1120 Loss of Serial Communications for Class 2 Devices
DTC U1121 Loss of Serial Communications for Class 2 Devices
DTC U1122 Loss of Serial Communications for Class 2 Devices
DTC U1123 Loss of serial communications for class 2 devices
DTC U1124 Loss of serial communications for class 2 devices
DTC U1125 Loss of serial communications for class 2 devices
DTC U1126 Loss of serial communications for class 2 devices
DTC U1127 Loss of serial communications for class 2 devices
DTC U1128 Loss of Communications with IRC
DTC U1129 Loss of Communications with AMP
DTC U1130 Loss of serial communications for class 2 devices
DTC U1131 Loss of serial communications for class 2 devices
DTC U1132 Loss of serial communications for class 2 devices
DTC U1133 Loss of serial communications for class 2 devices
DTC U1134 Loss of serial communications for class 2 devices
DTC U1135 Loss of serial communications for class 2 devices
DTC U1136 Loss of serial communications for class 2 devices
DTC U1137 Loss of serial communications for class 2 devices
DTC U1138 Loss of serial communications for class 2 devices
DTC U1139 Loss of serial communications for class 2 devices
DTC U1140 Loss of serial communications for class 2 devices
DTC U1141 Loss of serial communications for class 2 devices
DTC U1142 Loss of serial communications for class 2 devices
DTC U1143 Loss of serial communications for class 2 devices
DTC U1144 Loss of Communications with PHN
DTC U1145 Loss Of NAV Communications
DTC U1146 Loss Of Onstar Communiction
DTC U1147 Loss of serial communications for class 2 devices
DTC U1148 Loss of serial communications for class 2 devices
DTC U1149 Loss of serial communications for class 2 devices
DTC U1150 Loss of serial communications for class 2 devices
DTC U1151 Loss of serial communications for class 2 devices
DTC U1152 Loss Of ACM Serial Data Communication
DTC U1152 Loss of Data HCM
DTC U1153 Loss of Communications with CCP
DTC U1154 Loss of serial communications for class 2 devices
DTC U1155 Loss of serial communications for class 2 devices
DTC U1156 Loss of serial communications for class 2 devices
DTC U1157 Loss of serial communications for class 2
DTC U1158 Loss of serial communications for class 2 devices
DTC U1159 Loss of serial communications for class 2 devices
DTC U1160 Loss of Communications with DDM
DTC U1161 Loss of PASS Door Module SBI
DTC U1162 Loss of Rear Driver Door Module SBI
DTC U1163 Loss of Rear PASS Door Module SBI
DTC U1164 Loss Of DIM Serial Data Communication
DTC U1165 Loss of serial communications for class 2 devices
DTC U1166 Loss of Communications with SCM
DTC U1167 Loss of serial communications for class 2 devices
DTC U1168 Loss Of TTM Communications
DTC U1169 Loss of Communications with MMM
DTC U1170 Loss of Driver Door Switch SBI
DTC U1171 Loss of serial communications for class 2 devices
DTC U1172 Loss of serial communications for class 2 devices
DTC U1173 Loss of serial communications for class 2 devices
DTC U1174 Loss of serial communications for class 2 devices
DTC U1175 Loss of serial communications for class 2 devices
DTC U1176 Loss Of RFA Communications
DTC U1177 Loss of serial communications for class 2 devices
DTC U1178 Loss of serial communications for class 2 devices
DTC U1179 Loss of serial communications for class 2 devices
DTC U1180 Loss of serial communications for class 2 devices
DTC U1181 Loss of serial communications for class 2 devices
DTC U1182 Loss of serial communications for class 2 devices
DTC U1183 Loss of serial communications for class 2 devices
DTC U1184 Loss of serial communications for class 2 devices
DTC U1185 Loss of serial communications for class 2 devices
DTC U1186 Loss of serial communications for class 2 devices
DTC U1187 Loss of serial communications for class 2 devices
DTC U1188 Loss of serial communications for class 2 devices
DTC U1189 Loss of serial communications for class 2 devices
DTC U1190 Loss of serial communications for class 2 devices
DTC U1191 Loss of serial communications for class 2 devices
DTC U1192 Loss of VTD Class 2 Serial Data Com
DTC U1193 Loss of VIM Class 2 Communication
DTC U1194 Loss of serial communications for class 2 devices
DTC U1195 Loss of serial communications for class 2 devices
DTC U1196 Loss of serial communications for class 2 devices
DTC U1197 Loss of serial communications for class 2 devices
DTC U1198 Loss of serial communications for class 2 devices
DTC U1199 Loss of serial communications for class 2 devices
DTC U1200 Loss of serial communications for class 2 devices
DTC U1201 Loss of serial communications for class 2 devices
DTC U1202 Loss of serial communications for class 2 devices
DTC U1203 Loss of serial communications for class 2 devices
DTC U1204 Loss of serial communications for class 2 devices
DTC U1205 Loss of serial communications for class 2 devices
DTC U1206 Loss of serial communications for class 2 devices
DTC U1207 Loss of serial communications for class 2 devices
DTC U1208 Loss of serial communications for class 2 devices
DTC U1209 Loss of serial communications for class 2 devices
DTC U1210 Loss of serial communications for class 2 devices
DTC U1215 Loss of serial communications for class 2 devices
DTC U1220 Loss of serial communications for class 2 devices
DTC U1225 Loss of serial communications for class 2 devices
DTC U1230 Loss of serial communications for class 2 devices
DTC U1235 Loss of serial communications for class 2 devices
DTC U1240 Loss of serial communications for class 2 devices
DTC U1245 Loss of serial communications for class 2 devices
DTC U1250 Loss of serial communications for class 2 devices
DTC U1251 Loss of serial communications for class 2 devices
DTC U1252 Loss of serial communications for class 2 devices
DTC U1253 Loss of serial communications for class 2 devices
DTC U1254 Loss of serial communications for class 2 devices
DTC U1255 Class 2 Communication Malfunction
DTC U1255 Serial Data Line Malfunction
DTC U1300 Class 2 Short to Ground
DTC U1301 Class 2 Short to Battery
DTC U1304 Loss Of UART Communications
DTC U1305 Class 2 Data Link Low or High
DTC U1500 Inter-Device Dedicated Bus Malfunction
DTC U2000 Invalid BFC Transmitted SPI Data
DTC U2001 Invalid IPC Transmitted SPI Data
DTC U2002 SPI Data-In Low
DTC U2003 SPI Data-In High
DTC U2004 SPI Data-Out Low
DTC U2005 SPI Data-Out High
DTC U2006 SPI Clock-Out Low
DTC U2007 SPI Clock-Out High
DTC U2050 SIR PPS/CPS Communications Link malfunction
DTC U2100 CAN Bus OFF
DTC U2100 CAN-BUS Communication Malfunction
DTC U2102 More Controllers on Bus than Programmed
DTC U2103 Fewer Controllers On Bus Than Programmed
DTC U2104 CAN Bus Reset Counter Overrun
DTC U2105 CAN Bus Error ECM
DTC U2105 Lost Comm with Engine Control System
DTC U2106 Lost Comm with Trans Control System
DTC U2107 Lost Communications with Body Control System
DTC U2108 CAN Bus Error ABS
DTC U2108 Lost Comm with ABS Control System
DTC U2150 Navigation ECU Gateway Communication Error
DTC U2151 Navigation ECU Communication Malfunction
DTC U2153 VICS ECU Communication Error
