Front Wiper Quit
FTVanHoy
02-19-2006, 04:23 PM
:banghead: I have a 1997 town & country the front wiper moter only works when you press for the washer to work then shuts off i tried new moter and colum switch but still dose not work all fusses and relays are good but book says has auto rest fusses some where any ideas?
Soccer dad
02-20-2006, 03:28 PM
I dont know where the auto reset fuses are, I can check my service manual later,but I went thru the same thing you did by replacing everything only to find out it was the BCM body control module,I paid about 50 bucks used for it.The BCM was the last thing I checked and should of been the first.You will find that out when you test for power and ground at the wiper harness connector,and go from there.
yogi_123rd
02-21-2006, 04:07 PM
Try disconnecting the battery for 30 seconds to reset the BCM.
The BCM can get into a screwy state that requires resetting.
