Brake Problemmajk 02-19-2006, 03:23 PM I have JIMMY 1998, AND I HAVE SOME PROBLEMS WITH BRAKE OR SOMETHING Sometime when i push the pedal brake i hear like scream and the pedal stoped 1-2 second and car going, and after 1-2 second pedal go down and car stop. I change the brake rotors and pads, and i have checked again and they told everthing is ok with brakes. they told is mayby problem with ABS or samething This is hapened sametyme THANKS rlith 02-20-2006, 07:03 AM I have JIMMY 1998, AND I HAVE SOME PROBLEMS WITH BRAKE OR SOMETHING Sometime when i push the pedal brake i hear like scream and the pedal stoped 1-2 second and car going, and after 1-2 second pedal go down and car stop. I change the brake rotors and pads, and i have checked again and they told everthing is ok with brakes. they told is mayby problem with ABS or samething This is hapened sametyme THANKS When it "Screams" is it more of a groan and does it bounce the pedal up and down? If so, yes, you're having probs with your ABS. More than likely your sensors need cleaned out or replaced. If they need replaced, you have to replace the entire hub assembly. Which brings up another possibility, it could be your hub(s). When you break, they are shifting and howling. Automotive Network, Inc., Copyright ©2012
