Attention 95 4runner Owners!!!bigpest88 02-18-2006, 11:34 PM Yesterday I went to my local TOYOTA dealer to check my "Chech Engine" light and I found out that there was a recall on my trucks Steering rod. So if I was you, I would check it out.:wave: ChRiZ SidneyCanada 02-26-2006, 08:22 AM Next time you want the check engine light comes on don't take it to the dealership you can pull the codes yourself and sometimes not all faults show a check engine light unless you pull the codes and some faults don't even show code either you must measure the voltages & resistances at each ECU (EFIV computer) wire and compare with the factory service manual. The steering rod is recalled so let them replace it,it has nothing to do with the check engine light. About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered. To pull the ECU codes: All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it: http://autorepair.about.com/library/ts/obd-i/bl-dtcs-36.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-53.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-71.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-90.htm http://www.off-road.com/toyota/tech/codes/index.html http://lcengineering.com/TechNotes/TechNote12.htm http://lcengineering.com/TechNotes/TechNote13.htm http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Engine.html http://www.mad-mechanic.com/toyota/toyotaobd.shtml#obtaincode http://www.freewebs.com/th3duke/22RE-ECU.mht http://www.troublecodes.net/Toyota http://members.igateway.net/~pscott/enginecodes.html http://www.autobook.co.kr/data_links/toyota_trouble_codes.htm http://www.autoshop101.com/forms/h27.pdf http://www.showmesome.info/hilux/info/manuals/1KZ-TE/Page0096.htm http://www.efisakh.narod.ru/at_toyota.htm http://www.usatransdoctor.com/foreigntoyota.htm Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio. In North America the 22R & 22R-E s are used in the following: 22R 1981-82 Toyota Corona 1981-83 Celica 1981-87 Toyota pickup (up to 1990 on 2wd) 1984-87 Toyota 4-Runner 22R-E 1983-85 Celica 1985-95 Toyota pickup 1985-95 Toyota 4-Runner Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Clymers,Bentley and Toyota repair books. There is also free AutoZone service manuals at: http://www1.autozone.com/servlet/UiBroker?ForwardPage=/az/repair_info/repair_guide/repair_guide.jsp 1985 Toyota 4-Runner/pickup Factory Service manual: http://www.jasuza.com/1985toyotatruckfsm.pdf 1993 Toyota Pickup Service Manual: http://personal.utulsa.edu/~nathan-buchanan/93fsm 2003 (2001-2004) Toyota Tacoma Factory Service Manual: http://fsm.afraid.org/ http://www.junglecode.com/toyota/tacoma/2003_fsm http://65.200.1.6/FSM/ FSM (factory service manual)can be acquired in several ways: Toyota Material Distribution Center 750 West Victoria St Rancho Dominguez/Compton,CA 90220-5538 USA Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST) Ph:1-800-443-7656 (inside CA) Ph:1-310-818-4630 (in or outside CA) Speak to Beverly or Deloris http://techinfo.toyota.com/public/main/mdc.html http://www.4crawler.com/4x4/FSM.shtml 1)buy a used one off e-bay 2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual 3)some public libraries sell their old books as they are not in demand any longer 4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale 5)some junk yards may have one laying around 6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips" 7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view. For scanned pages of factory service manuals for other engines: http://www.sor.com/torque.html http://www.brian894x4.com/Scannedmanual.html http://www.birfield.com/modules.php?name=Content&pa=showpage&pid=77 http://toyotadiesel.com/photopost/showgallery.php?cat=507 http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf http://www.showmesome.info/hilux/info/manuals/1KZ-TE http://surf.mactherapy.com/1KZ-TE.pdf http://surf.mactherapy.com/parts http://www.spyderchat.com/1zzfe.pdf http://files.matrixvibe.net/docs/1zzfe.pdf http://landcruiser.free.fr/mans http://surf.mactherapy.com http://www.turbosupras.com/pages/technical/tsrm.htm http://www.lieblweb.com/tacoma/Mechanical/96TacomaDiagrams/index.htm http://perso.wanadoo.fr/adherence.4x4/liens_techniques.htm http://perso.wanadoo.fr/adherence.4x4/index.htm http://www.asatraction4x4.cl/html http://www.toyotasurf.asn.au/techsite/downloads.htm http://www.grubinski.com/grubinski/automotive/toyota.manuals http://www.carsoft.ru/files/4runner95di.exe http://www.hotrodder.com/kwkride/tech.html http://aarc.epnet.com/application/8578/8578.htm http://aarc.epnet.com/application/9316/9316.htm (1997–2000=4-Runner,pickup,T100,Tacoma,Tundra,Landcruiser) http://www.bedlib.org/ebsco.html then click on “AARC” or “Auto repair reference center” Sidney® ™ Repairs tv's,vcr's,home/car audio out of my home E-mail:sidneybek@yahoo.com Dartmouth,Nova Scotia Canada 1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 247 000 KM http://groups.google.com/group/hfx.forsale/browse_thread/thread/43940ce83231ab85/4e4c696fbf04837f?q=sidney+tv+repair&rnum=1#4e4c696fbf04837f http://www.iwaynet.net/~nesda/May02/May18.html http://www.iwaynet.net/~nesda/SonyAudMod.html http://www.newark.com/product-details/image/mcm/image/32-9495.jpg http://www.tipsmaster.ca/hottips-1.HTM http://www.tipsmaster.ca/1011-TV32C50-007.jpg http://www.iwaynet.net/~nesda/June03/June0315.html http://www.iwaynet.net/~nesda/Apr03/Apr033.html O |\ __O _|_| \ (\__/) (='.'=) (")_(") ..> ...> ...> ...> .(....\............../....).. ..\....\........... /..../.. ...\....\.._.._../..../.... ....\..../....l..`\_./.... ..../....l....l....(..`\.... ...l.....l.._.l.._.\....\... ...l.....l__.l__.l''\....\.. ...\...................\../.. .....\__________/..... () () ^ () () / \ ^ ^ () () / \ \ ^ / \ | | / \ \ \____________ o o ) | | /_________\___\__\__________|_____| bigpest88 02-26-2006, 08:45 PM I took it to the dealer because my vacume lines were all messed up and they fixed, and the light went away. But while i was there, they told me there was a recall on the truck and did it for me while it was there. I know that the light has nuthing to do with the steering rod. But i was just letting you all know about the recall. Automotive Network, Inc., Copyright ©2012
