Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 02-18-2006, 05:19 PM   #1
peelerboy
peelerboy Normal reputation
2000 Windstar WON'T START! HELP!
Our next door neighbors/best friend's 2000 Windstar won't start. It won't even crank or click or anything for that matter! It's a V6 model with only 40k on the clock.
The battery appears to have a nice charge, because to turn on the headlights, they're VERY bright. You put the key in, turn it to the "run" position and you can hear the fuel pump instantly prime. All i.p. and hvac lights fire up and are bright, but when you turn the key all the way to start it NOTHING happens. All the lights remain lit when you attempt to crank, so it's not like the battery is poopin' out.
It kinda' reminds me of when the starter relay would go out on my `99 Mustang... full battery power but no crankability. The neighbors said that a couple weeks ago it had done this, but the husband went out and moved the shifter from park down to drive then back into park with a little additional effort so as to make sure it wasn't foolin' the neutral safety switch with slight disengagement and then it fired up. Not the case THIS time. It simply does nothing whether you're trying to start it in park OR neutral.
Any suggestions?? Please help if you do! Thanks in advance.
Dale
peelerboy is offline   Reply With Quote
Old 02-18-2006, 05:46 PM   #2
wiswind
wiswind Normal reputation
Re: 2000 Windstar WON'T START! HELP!
The "neutral safety" switch, also called Transmission Range Sensor (TRS) can cause the problem. This is connected, by a cable, to the gear select lever.
The TRS is mounted on TOP of the transmission. It is under the air filter and the flex hose that goes from the air filter to the engine. The TRS prevents the starter from working in any gear other than Neutral or Park.
As he got it to work by shifting through the gears, it sounds like this could be the cause. Try shifting to Neutral and see if it will start.
You can get a new TRS at a auto parts store for about $30 - $40.
It is not hard to change.
wiswind is offline   Reply With Quote
Old 02-18-2006, 07:09 PM   #3
peelerboy
Thanks for the reply, wiswind! If the TRS is the problem... would it not start in neutral as well? Because the van refuses to crank regardless of whether it's in park OR neutral. Thanks again!
Old 02-18-2006, 08:21 PM   #4
LeSabre97mint
LeSabre97mint's Avatar
LeSabre97mint Normal reputation
Dale
Dale
With the key on run try jumping the large lug on the starter solenoid with the smaller one with a screwdriver. Make sure you don't touch ground or there will be sparks flying. If the starter works the problem is else where. You should be able start the van this way.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
LeSabre97mint is offline   Reply With Quote
Old 02-18-2006, 09:38 PM   #5
peelerboy
Originally Posted by LeSabre97mint
Dale
Regards
Dan
Hey Dan! Thanks for the reply!!
I know exactly what you're suggesting, although used to pull this trick when the relay (solenoid?) was a separate unit mounted on the fenderwell. Is the solenoid you're referring to actually on the starter now? Because on my `99 Mustang (just one year older Ford), the relay is on the fenderwell.
Dale
Old 02-18-2006, 10:34 PM   #6
LeSabre97mint
Dale
Dale
The solenoid is on the starter.
Dan
SW MN
Old 02-18-2006, 11:55 PM   #7
peelerboy
Dale
Dan
Thank you, Dan! I'm on a mission first thing in the morning! By the way, if jumping the solenoid works and cranks the engine over for start up, does this mean that the TRS is my problem?
Dale
Old 02-19-2006, 06:22 AM   #8
wiswind
It could be the TRS, or very likely the solonoid on the starter, as you are bypassing BOTH. I was thinking of the TRS as he was able to start the engine by shifting through the gears first.
A sticking solonoid will cause the no start, as the solonoid has to pull in....before any power gets to the starter. The solonoid and TRS are in series (both must pass the power)...
There are a lot of posts of the TRS failing as far as the transmission performance is concerned, but not for no start problems....but always possible.
It is also possible that you will do this 1 time, and the problem will be solved...but I would be wondering when it might happen again.
Old 02-19-2006, 08:15 AM   #9
peelerboy
Hey guys, is there any way to isolate which part is faulty? (solenoid or TRS)
edit~
OH!... and one other thing, after looking up both a starter and the TRS on rockauto.com, I noticed they also referred to the TRS (or "neutral safety switch" as they called it) as a back-up light switch. Here's one of the parts they offered:
STANDARD MOTOR PRODUCTS Part # NS200
Automatic Transmission {NEUTRAL SAFETY/BACK-UP LIGHT SW.}
If this switch is defective, would the back-up lights not function as well?... or could it still perform it's function for the lights but not for the starting issue? Just trying to isolate.
Dale
Old 02-19-2006, 10:06 AM   #10
peelerboy
This just in... I crossed the solenoid on the starter and it fired right up. Checked the back-up lights and they do NOT work. We're runnin' up to the auto parts store right now to grab a new neutral safety switch! (confident that's our problem) Thank you SOOOOO much you guys for all your help!!!!!!
Dale
Old 02-19-2006, 11:06 PM   #11
LeSabre97mint
Dale
Dale
Glad to help. Let us know when you get it fixed!
Dan
SW MN
Bookmarks
Google
Web AF
