Heater Blowermanx1962 02-18-2006, 05:52 PM I have a 95 S10 Blazer and the heater blower wont come on.. It wouldnt last night then after driving a little bit it came on this morning it worked fine, But now it wont come on at all any one have any ideas?? Teal95Jimmy 02-18-2006, 07:41 PM check the fuse and make sure there is a clean seat for the connection, then check under the hood and make sure the wires going to the blower are on tight and are clean spano 02-18-2006, 08:54 PM Disconnect the termial under the hood and clean the contacts, add terminal goo (correct term unknown) and should be O.K. I have had the same problem inermittianly it goes off and after cleaning and goo it has been fine.... Teal95Jimmy 02-18-2006, 09:16 PM Disconnect the termial under the hood and clean the contacts, add terminal goo (correct term unknown) and should be O.K. I have had the same problem inermittianly it goes off and after cleaning and goo it has been fine.... that terminal goo would be called dielctric grease manx1962 02-18-2006, 11:30 PM Thanks guys I will try that in the morning and give you an update tomorrow. Gotta have the heat its neg 10 here In Rapid City South Dakota... rlith 02-19-2006, 07:21 AM The other issue is the fan may simply be dead... I recently had to change mine out. Squealed like crazy when it ran, but it had a flat spot the the brushes would hit and the only way to get it to start would be to hit a pothole or what not. Automotive Network, Inc., Copyright ©2012
