Update....Mr. Luos 02-17-2006, 08:19 PM I hate my car. Cylinder #7 appears to have a dead injector or a dead coil. Easy fix...just not cheap. I have driven my car. Just not more than about 45 minutes of total run time yet. The last month has seen about nothing get done. F'ing cold. I was running WAY lean on most cylinders...thank god I didn't truely get on it. I had a nasty vacuum leak inbetween the heads and the intake. My own fault too....forgot that the stock LS1 valley cover bolts can't be used with the FAST intake. OR....it holds the intake up just a hair. Must have been tired/drunk when I put those bolts in. Right now.... New lower height FAST bolts are in. New fuel filter is in. Plugs need re-installed. Intake needs re-installed. True duals are hung up. Base performance tune is on the car. I still have 2 months before Bandimere opens up....so if I get even a little work done over the next month I will be happy. Duals....in the tightest spot....the UMI tunnel braced torque arm. They aren't mandrel bent. Probably a loss of 2-3 HP. Which I can take. http://home.comcast.net/~mrluos/Swap177.JPG Underhood....green wire is for a gauge not connected yet.... http://home.comcast.net/~mrluos/Swap174.JPG Should have more soon. 3 day weekend....should have the intake, plugs, etc all back on. Discuss. :lol: TerminalVelocity 02-17-2006, 08:24 PM I hate when things go wrong like that, nice to hear your going to have it up soon (?)! -The Stig- 02-17-2006, 10:02 PM vroom. G-man422 02-17-2006, 10:05 PM Good luck w/ the fixing and ordering, etc. Mr. Luos 02-17-2006, 10:05 PM vroom. Hopefully soon. :banghead: xXxRocker5150 02-18-2006, 01:49 AM did you try TV's "WORK!!!!" method... I'm sure you'd shave off at least a few hours. 2000LS1Z28 02-18-2006, 02:27 AM Looks really clean. I think i'll have my engine cleaned sometime soon. Sorry to hear about all the bad luck. I'm sure you'll get everything running in time for Bandimere Raceway. Just don't expect to run 11's at that track, as it's altitude will suck the power out of that engine. Mr. Luos 02-18-2006, 09:43 AM Not looking for 11's here. Mid 12 at around 115 MPH though. -Jayson- 02-18-2006, 10:48 AM sweetness, now get us some videos of that thing running G-man422 02-18-2006, 10:55 AM ^ yes, ASAP. Mr. Luos 02-18-2006, 11:04 AM Did I ever post the clip of it idling? Chiquae07 02-18-2006, 12:23 PM yes u did. i dont rememeber what thread it was called tho Automotive Network, Inc., Copyright ©2012
