Getting my cylinder head back...therealrayman 02-16-2006, 08:14 AM I'm picking it up either today or tomorrow morning. The total bill turned out to be about 250 + change. -Compression test. -Resurfaced. -Replaced exhaust valve. -Five angle valve job. -Head gasket set purchased along with the services too. Tomorrow or saturday the head thats on my car now will be ready to pull also :licka: . I finally managed to get the camshaft bolt off (i don't have an impact wrench or anything, i managed to lock a wrench on the crank bolt, and used a 3 foot pipe as an extension on the camshafts socket wrench :screwy: ). Got all the headbolts out too. Only reason its not out is i think theres a coolant line or two on the underside of the intake manifold that i haven't disconnected. That and i haven't removed those 3-4 vaccuum lines connected to those hard pipes....I'll probably have to color code those cuz i'm hose retarded sometimes...:uhoh: Somebody said i can pick up a vacuum hose diagram at the nissan dealer? Do they charge for it or is it just something they'll photocopy for me? Talk to you guys later. slideways... 02-16-2006, 09:07 AM they can just print it out for you. btw nice price on the head rebuild. cost me almost that much and i got a stock angle valve job, although i had to replace all 4 exhaust valves and springs...that was probably the diff oh and mark the heater hoses because the diagram for that isnt as complete or easy to read as the vacuum diagram. i always use a screwdriver to wedge and hold the cam while i use a ratchet on the cam gear, works ok too. rps13freak 02-19-2006, 01:46 AM there a place that my friend got his dont down here in miami that does SOHC for 130 and DOHC for 160 Automotive Network, Inc., Copyright ©2012
