Need FlyWheel bolts for 1991 S-10TinyRulz 02-15-2006, 09:23 PM I need 6 FlyWheel bolts for a 1991 Chevy S-10 it has the 2.5L 4 Cyl. 5 Spd. has anyone got any or where can I get some, PLEASE HELP!!!:banghead: OverBoardProject 02-15-2006, 09:31 PM Do you have even 1 origional? If so any good blot supply shop should be able to help you out. Otherwise a DIY autowreck TinyRulz 02-16-2006, 09:35 AM No I have none, but I know what size I need will any bolt work if it's the right size? OverBoardProject 02-16-2006, 09:55 AM Make sure that the grade is the same or higher herkyhawki 02-16-2006, 04:39 PM Visit any local transmission shop. They change alot of flywheels and will have the bolts on hand. dmbrisket 51 02-16-2006, 09:46 PM best bet is dealer, most shops dont keep those specialty bolts on hand, and they need to be the correct grade, to soft is bad, and to hard can be just as bad if not worse Automotive Network, Inc., Copyright ©2012
