Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 02-14-2006, 10:37 PM   #1
muzzy1maniac
muzzy1maniac's Avatar
muzzy1maniac Normal reputation
Hey Wolfox! Did you ever...
get those Iridium plugs? I remember a post a while back about some plugs you we going to try out. Did you and how did it work out??
2004 Explorer XLT
4.0L 4x4
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
muzzy1maniac is offline   Reply With Quote
Old 02-14-2006, 11:18 PM   #2
s10blazerman4x4
s10blazerman4x4's Avatar
s10blazerman4x4 Normal reputation
Send a message via AIM to s10blazerman4x4
Re: Hey Wolfox! Did you ever...
Watch out WOlfox he is very tired possibly.yeh i wanna know too lol.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3--> If GM engineered something to fail on this beast it has or will. Repairs include w/in first 30 days of owning it: P1870, left front wheel bearing, gas cap, rad cap, idler tensioner, seat handles, and the list goes on.
http://www.automotiveforums.com/vbul...d.php?t=890449
Chime in ^ with any suggestions.
s10blazerman4x4 is offline   Reply With Quote
Old 02-15-2006, 08:53 AM   #3
wolfox
wolfox's Avatar
wolfox Normal reputation
Send a message via Yahoo to wolfox
I haven't changed them out yet. The only reason why is because the current set of plugs in the truck aren't worn enough to warrant a change. As soon as they do wear out I will swap and let you guys know. My truck does not see a ton of mileage, except on weekends - I can and do walk to the office in the mornings.
wolfox is offline   Reply With Quote
Old 02-15-2006, 10:14 AM   #4
muzzy1maniac
Nice, I drive 42 miles each way. It's not too bad being all Xpressway but it still sucks when you're beat!
2004 Explorer XLT
4.0L 4x4
Old 02-15-2006, 09:15 PM   #5
wolfox
wolfox's Avatar
What sucks more is having to walk because you spent your gas money on Iridiums! I looked high and low,and found a set of them that would work for the GM 4.3 from Denso. A local store has them in droves since so many Hondas and such are carrying these plugs from the factory. $13 a piece! *sticker shock* <<faint>> But I figure I would wear out 4 sets of tires before I replaced those plugs! The trick is finding them in the proper heat range for the 4.3 smallblock 6. Ideally you want a plug that heats up to operating range within seconds of engine start - but not so hot that you suffer from pre-ignition. You can hit the Denso website and use their application guide to pick what you need.
Old 02-15-2006, 09:50 PM   #6
Eslhockey92g
Eslhockey92g's Avatar
Eslhockey92g Normal reputation
What are the benifits of Iridium Plugs??
Eslhockey92g is offline   Reply With Quote
Old 02-16-2006, 02:03 AM   #7
Rmbodie
Rmbodie's Avatar
Rmbodie Normal reputation
I bought NGK Irridium plugs for my T/A , but haven't installed yet either . I paid $ 7.00 each for these . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2002 Silverado 4x4 , 5.3 Vortec . Lifted ,Pumped,Humped,Thumped!
Rmbodie is offline   Reply With Quote
Old 02-16-2006, 07:50 AM   #8
wolfox
wolfox's Avatar
Iridium is an EXTREMELY hard, noble metal. It resists wear from heat, and more improtantly, the tips do not vaporize as fast from the arc crossing them. Essentially, it is a plug that runs MUCH longer, within tollerances than even platinum tipped plugs or nickel plated steel and copper of conventional plugs. Those are the benefits in a nutshell. Secondary benefits come from the shape of the electrode tip and in Denso's case, a U-channel electrode. THis allows for a sustained, hotter and more even spark kernel that is not so prone to "blowing out". This increases idle quality and overall efficiency of the engine slightly. Another design advantage is that the electrode tip is "sharpened" to a fine pont. It's tip is only like 1.2-1.3mm compared to a standard platinum tip or conventional plug that averages 2.2mm or so. ELectricity loves to gather and arc from sharp corners or small surfaces. The plug will fire with less than half the energy required to arc across the gap of a standard plug. Ignition systems that utilize an Ion sense ignition system (Like me 4 Cylinder Rodeo did) can adjust the spark intensity to match engine speed and load better. On standard systems, it will simply fire with more intensity without upgrading to an aftermarket coil pack. I found out much and amazing info by Googling up general info on Iridium based plugs. Denso and NGK alo released papers on the effects of iridium based plugs in PDF format. They're simply good mojo that works well in almost any application they are put into.
Old 02-16-2006, 08:47 AM   #9
Eslhockey92g
Very detailed info, thanx haha almost makes me wanna go out and ge a set for my blazer
Bookmarks
Google
Web AF
