1995 SL1 idles rough and stallsroadxing 02-14-2006, 07:55 PM I need some help. i just bought a '95 sl1 and got it home, replaced a few body panels, put a new battery in and the fisrt time i tryed to drvie it it wont even stay runnig long enought to warm up. so i went and bought new plugs and wire, oild, air fitler andwent to start it again. it seemed to be running pretty good however after a few mintues of idleing, when it goes from cold to warm idle it wants to die, at the same time the cooling fan kicks on. it may not be related but i thought i would mention it. Most of the time if i give it some gas right when the idle drops and before it dies it says runnig so a minute or so longer and it wants to die again, give it some gas ect. Sometimes once you do this a few times it runs great. Still havent got it out on the road since its not all that reliable. So what do you think it is. Since i just put a battery in there is only the 12 error code repeating over and over and im stumped. thanks for any and all help Cat Fuzz 02-14-2006, 09:31 PM Check your vacuum lines and PCV hose for leaks. Sounds like a vacuum leak somewhere. roadxing 02-16-2006, 07:01 PM Well, today i looked around and couldnt find anything wrong with and of the vacuum lines. The PCV is alittle sticky but its not the worst i'v ever seen then i started the car and it ran alright for a few minutes then stalled as usual. Well then come the problem, i started the car again and it just ran horroble. Smoked alot, ran rough and then, finally the check engine light came on. So i tuned it off and ran the self-diagnostics and got a code "32". Tryed to start it a few more times, still running rough and smoking and continuing to get the check engine light and the code 32. So that means something wrong with some part of the EGR. Could this be all of my troubles?? i am very thankful for any help. saturnspeed_12 02-16-2006, 11:14 PM possibly. just make 100% sure the vacuum line to it isnt damaged. other then that im getting that egr needs replaced. Automotive Network, Inc., Copyright ©2012
