speed sensor?Ridleyj329 02-14-2006, 04:30 PM my odometer doesnt work but the speedometer does. i been told that their both conected to the speed sensor. if this were true wouldnt they both be workin right now or should i still replace it and see what happnes? thanx saturnspeed_12 02-14-2006, 04:46 PM what year is your car? most all odometers are run off the speedometer in the cluster. if your car is 97 or older, maybe some 98s, then it has a mechanical odometer. gear probably went bad in the cluster. Ridleyj329 02-14-2006, 05:08 PM its a 94 SL1 SOHC saturnspeed_12 02-14-2006, 05:12 PM time to pull gauge cluster. Ridleyj329 02-14-2006, 05:15 PM so the speed sensor is fine and i should just replace the instument cluster? and that will get the speedo and odo both workin? saturnspeed_12 02-14-2006, 05:19 PM yeah it should. Ridleyj329 02-14-2006, 05:23 PM is it neccessary to have the odo work? :-D saturnspeed_12 02-14-2006, 05:26 PM well it depends. really no its not exactly needed. but then you might want to keep track of your miles in some way. to me, it be best to replace it. Ridleyj329 02-14-2006, 05:27 PM ok, thanx. hopefully i can find one cheap enough saturnspeed_12 02-14-2006, 05:29 PM ebay? i just found one on there for like $20 Ridleyj329 02-14-2006, 05:33 PM cool. ill check it out. thanx a bunch sierrap615 02-17-2006, 01:02 AM or search saturnfans.com for a link to buy just the broken gear in the odo. Automotive Network, Inc., Copyright ©2012
