2004 alero loosing gas really fast
nowlight
02-12-2006, 08:51 PM
My 2004 alero sucks alot of gas, I only drive it about 10k a day and I will need to fill it up almost once a week. It seems that every time that I start, the gase guage goes lower and lower.
V6 model.
Anyone know whats up with it, love this car to death and really want to know whats happing with it.
JTrujillo86
02-13-2006, 01:18 AM
I think you meant to say 10 miles a day...
Anyway, if you're only driving so few of miles, then they're probably city miles, right? My car isn't the greatest in the city, either. I have a 2002 Alero V6. If I drive stricktly city, then I get usually 20 MPG. Highway is very good, however, at around 31 MPG.
Some things to check out would be the air filter and fuel filter. I'm not sure how many miles you have on your car, but if you're nearing 30K miles, it wouldn't kill to change the fuel filter. The air filter should be changed about every 10-15K miles.
Also, how hard do you accelerate from a stop? How hard do you brake? These things have a huge impact on your MPG.
- Jeremy
JohnGTP
02-13-2006, 02:58 PM
At start up and before a car warms up is when your gas consumption is at it's worst..... but if you're only getting 50-70miles to a tank of gas then you have a serious issue somewhere. Does it smell like gas around your car??
dunit1017
02-13-2006, 05:42 PM
I'm so glad I found someone who thinks the same thing...my dad thinks I'm an idiot for saying that...My 2004 Alero is also a V6 and is terrible on gas...I can't say I get that few MPG, but its very close...I love the car to death as well, but that is one thing I can't stand about it. One possible way to find out your real MPG would be to fill the gas tank completley and set your trip to zero...then, let the tank get as low as possible, and before you fill it back up, check the trip and see how many miles you have gotten...thats just one way I have heard of doing it. Hope it helps.
nowlight
02-13-2006, 07:36 PM
No I ment k, I live in canada. I really dont understand it I have good mpg driving but for my its when I start my car is when I go through alot of gas?
JTrujillo86
02-13-2006, 08:34 PM
Keep an eye on the gauge. Sometimes when I start my car, the gauge reads lower than when I shut my car off, but once the car gets going and gets warmed up, the gauge will move up a little bit. Like the previous post said, every time you get a new tank of gas, zero out your tripometer and see how far you go on a tank.
- Jeremy
nowlight
02-13-2006, 09:14 PM
I will do that next time, and will post back. But is this "normal" for a 04?
dunit1017
02-13-2006, 10:07 PM
Just for the record, my Alero also does what Jeremy's does. When the car is off, the guage says the gas tank is lower than it actually is. When the car gets warmed up, it gradually goes higher.
JTrujillo86
02-14-2006, 01:32 AM
For my 2002 V6, which is the same engine you have, I USUALLY get 24 MPG with mixed mileage if I drive normally. All city driving, I usually get 20 MPG. All highway, I have gotten 33, almost 34 MPG, but normally get about 30. What kills the city driving, especially for you since you drive short trips, is the constant shutting on and shutting off of the engine. A vehicle uses as much fuel at start up as it does sitting in traffic for 2 minutes.
- Jeremy
P.S. - Normally, I go about 290-300 miles before I fill up...that's with mostly highway driving, with a little city mixed in there.
JTrujillo86
02-14-2006, 01:35 AM
One last thing - keep in mind you're driving an American 12 valve V6 pushrod engine...they're not necessarily known for they're great gas mileage. Don't expect the same MPG as say a 2004 Honda Accord with a 24 valve V6 DOHC/SOHC engine.
- Jeremy
vamc
02-14-2006, 06:13 PM
What kind of oct. are you using? If I use 87 oct. i get about, give or take, 3 mile less then when i use 94 oct. This is my experence with the gas.
JTrujillo86
02-15-2006, 03:35 AM
Umm....I didn't think you could safely use 94 octane with these engines...I thought the highest octane you can use is 91. Am I wrong?
- Jeremy
vamc
02-15-2006, 01:53 PM
Well, you can safely run up to 100oct. but you run the risk of kiling your o2 sencer. I never heard of 94 not being safe. we run 93-94 oct in all of our cars and no prob.94 is completely safe.
nowlight
02-15-2006, 01:55 PM
I dont know what octane 91 is but in canada i use the the cheapest verson of gas.
JohnGTP
02-15-2006, 02:35 PM
You can run the highest octane that you want and it won't damage your O2's. Your performance may suffer but you will only damage your O2's if you run leaded high octane fuel.
PotIsYourFriend
02-15-2006, 03:36 PM
I'm still confused about the first post.. What is 10k? It can't be 10,000 miles unless it's strapped to a rocket engine and it can't be 10km since thats about 6 miles which would make him driving 42 miles on a full tank.. Which seems like there would be a leak in the gas tank if anything else...
Unless there's a metric prefix I forgot about...
nowlight
02-25-2006, 07:21 AM
Yes I did mean km, Iam looking at about 130-140km on a full tank of gas. But I also have a car starter that I use because its winter and get to -25C average in the morning.
PotIsYourFriend
02-25-2006, 01:11 PM
Well 80 or so miles on a full tank is weird and I have no clue why that is..
gmtechnician
02-25-2006, 01:39 PM
If you only drive the car 10 kilometers per day the engine never gets warmed up to operating temperature. This can carbon the engine internally and it will consume alot more gas. I don't know how many km's on your car but if your getting close to 100,000 km I would put new spark plugs in it. I myself get better mileage with esso and sunoco gas. Shell gas mileage sucks.
Does your temperature gauge go up are stay down at the 40? Thermostat can cause this but usually sets a SES light on and a code for this. Warming your car up uses alot of fuel. Why don't you try a week without using the car starter. I bet you'll see great results. Some times after market accessories such as car starters and alarm systems tend to make the computer dump more fuel also.
nowlight
03-22-2006, 01:30 AM
I just ran the tank almost dry and I got about 200kl per a full tank. I really dont know that that will translate into miles.
skrizan
03-22-2006, 10:29 AM
That is only 120 miles!!! Or about 10 miles per gallon on 12 gallons! Ouch!! I am only getting 18-19 which is terrible also, but 10??? You have a serious problem. No leaks? Does it run like crap?
vamc
03-22-2006, 09:59 PM
i figure i got about 80miles a day to work and back total trip and when i get back on the third day i have a quarter of a tank left. give or take.
Rob_M
03-31-2006, 10:59 AM
Using fuel with higher octane than regular unleaded (typically 87 octane in the U.S. at lower elevations) won't hurt your car. It will, however, cause significant damage to your wallet! It is completely unneccesary in an Alero.
Make sure you are accurately calculating your mileage.
1. Fill the tank with fuel until the pump automatically shuts off. Do not top off the tank.
2. Reset the trip odometer.
3. Drive the vehicle. You don't have to drive it until the fuel gauge is on "E". The gauge reading has absolutely nothing to do with computing the mileage. It doesn't matter if the tank is still half full or completely empty as long as you've used a reasonable portion of whatever fuel is in the tank.
4. Refill the tank until the pump automatically shuts off. Do not top off.
5. Record the mileage (or km) on your trip odometer.
6. Record the number of gallons (or litres) of fuel it took to fill the tank.
7. Divide the mileage (or km) by the number of galllons (or litres) and you will have sucessfully calculated the actual fuel economy of your car in mi/gal (or km/l).
8. Repeat if you want to establish an average over time or periodically check the mileage.
vamc
04-02-2006, 09:36 PM
If you always run 87 oct. you can get a lot of carbon build up. Just my expierence.
