swaping lightbulbs
96cbring
02-12-2006, 08:22 PM
ok so i just got my new car a 92 lx and i bought sum new lightbulbs but i cant get the old ones off how do i take them off there like stuck on sum1 help
AccordCodger
02-13-2006, 09:20 PM
They are held with retaining rings which are sometimes hard to loosen. I had to use a piece of wood and a small hammer to carefully tap them loose.
mpumas
02-15-2006, 07:25 PM
And they only turn one way to remove the bulbs. The way to turn is marked on the ring. (counterclockwise) and about 15 degrees. The low beam bulb is different from the high beam bulb so look at the electrical connector to match the slot keys. One slot is low beam, 2 is high beam.
96cbring
02-16-2006, 10:03 PM
i was able to get the fukers off it was a pain now i have to take the battery off 2do the other side but w.e. i kno how 2 do it now thanks guys
mpumas
02-17-2006, 07:40 PM
Try just removing the radiator overfill bottle and see if you can get the bulbs off. Also don't get any fingerprints or oil on the bulb. If you do, wipe down with alcohol to get the grease off.
